Date/Time: Mon, 21 Apr 2025 13:11:39 +0000
cant compress chart
View Count: 66
[2025-02-26 17:18:26] |
ss1776 - Posts: 19 |
hi. i am not sure why my recon tape chart wont compress to go back in time (left side of chart) . x axis wont compress. i have to use scrollbar everytime. which i dont want to do. please help . |
[2025-02-26 17:38:31] |
John - SC Support - Posts: 39362 |
Refer to the following for how to change the Bar Spacing: Working With Charts: Changing Bar Spacing If these are not working for you, then we need to know what you did and what occurred (if anything). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
