Date/Time: Fri, 20 Sep 2024 05:49:25 +0000
Align 2 Charts Emini & NYSE Tick
View Count: 993
[2014-09-22 17:19:11] |
User59724 - Posts: 71 |
My main chart is the S&P emini, and below that I have another chart of the TICK-NYSE, but I can't them to align perfectly and to stay that way in different time frames. How do I do that? Thanks.
[2014-09-22 19:11:20] |
What is the timeframe per bar of the chart itself?
[2014-09-22 20:01:09] |
1 minute right now. But I will also use 2 min, 3 min, 5 min, 15 min, 30 min, 60 min, and 1 day.
[2014-09-22 20:27:55] |
We see no reason why there would be an alignment problem. What study are you using to overlay the market statistics charts on the other chart? You should be using Overlay (Bar). Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-24 03:48:01] |
Got. I didn't know about the Overlay (Bar). Wow, that works perfect. Thanks.
