Date/Time: Mon, 21 Apr 2025 13:11:42 +0000
CANT CONNECT TO THE SERVER
View Count: 84
[2025-02-26 15:25:32]
User480354 - Posts: 9
HI
FROM YESTERDAY I CANT USE THE SIERRA SYSTEM . I CANT CONECT TO THE REGULAR SERVER AS I USE TO BE ALLWAYS .
I GET THE ATTACHED MASSAGE .https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=116020 :
WHEN I TRIED TO CHANGE THE DATA SERVER TO "SC DATA - ALL SERVICES (DATA) I GET JUST BLACK SCREENS WITH NO DATA
ASKING FOR YOR PROMPPT ASSIST TO SOLVE THE PROVBLRM
THANKS
DOTAN DAHAN
imageצילום מסך 2025-02-26 172053.png / V - Attached On 2025-02-26 15:21:40 UTC - Size: 36.25 KB - 29 views
[2025-02-26 16:22:43]
i wanted to inform that when changing to SC Data - all services , all the data is with 10 min delay 'so i cant trade ...
waiting for your prompt replay
thanks
[2025-02-26 17:13:52]
John - SC Support - Posts: 39362
Refer to the following:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
[2025-02-26 19:20:47]
Sierra_Chart Engineering - Posts: 19285
To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks in Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
