Date/Time: Mon, 21 Apr 2025 13:08:36 +0000
[Programming Help] - Inquiry Regarding Rapid Order Submission in ACSIL Automated Trading Study
View Count: 94
[2025-02-26 07:17:52]
User329576 - Posts: 14
I am developing an automated trading study using ACSIL. I am encountering an issue when attempting to send multiple orders in rapid succession. Specifically, only the first order is accepted, and subsequent orders sent within a short time interval are not executed.
From my observations, it appears that orders submitted too quickly may be rejected (orders with a "short" internal order ID seem not to be processed), even though logically, it should be possible to have multiple orders accepted in quick sequence.
Could you please advise if this behavior is expected under normal conditions? Have you encountered similar issues with rapid order submissions via ACSIL? If so, are there any known workarounds or settings to enable multiple orders to be accepted when sent in rapid succession?
Additionally, if you require any further details (such as logs, code snippets, or specific order parameters), I would be happy to provide them.
Thank you for your assistance.
Best regards,
Date Time Of Last Edit: 2025-02-26 07:18:19
[2025-02-26 14:51:48]
ondafringe - Posts: 322
You should be able to place multiple orders in rapid succession.
Check these settings in the Set Default block of code:
sc.MaximumPositionAllowed = n;
sc.AllowMultipleEntriesInSameDirection = true;
sc.AllowOnlyOneTradePerBar = false;
sc.AllowEntryWithWorkingOrders = true;
There are others, but check those first.
Date Time Of Last Edit: 2025-02-26 16:03:08
