Date/Time: Mon, 21 Apr 2025 13:08:36 +0000
AddAsUserDrawnDrawing Documentation Error?
View Count: 122
[2025-02-25 23:56:11] |
ForgivingComputers.com - Posts: 1042 |
A chart drawing added with AddAsUserDrawnDrawing set to 1 is not saved to a Chartbook like an actual user drawn drawing would be.
From <https://www.sierrachart.com/index.php?page=doc/ACSILDrawingTools.html#s_UseTool_ChartNumber> It appears it is saved with the chartbook, which is what you would expect for a User Drawn Drawing. |
[2025-02-26 08:07:46] |
Sierra_Chart Engineering - Posts: 19285 |
They should not be saved unless s_UseTool::AllowSaveToChartbook is set to 1. Do you see otherwise?
[2025-02-26 15:45:27] |
Understood. I do have _UseTool::AllowSaveToChartbook set to 1. Thank you. |
