Date/Time: Mon, 21 Apr 2025 13:14:38 +0000
PnL is not correct, trading from 2 different computers
View Count: 175
[2025-02-25 20:27:30] |
tradewerx - Posts: 8 |
Hello, I trade from 2 seperate computers (laptop at home, desktop at office). I left a position open at the office, and covered it at home. Ever since then, my FlattoFlat PnL is being calculated incorrectly on the TradeWindow. Broker statements and Trade activity is correct. How can i reset the Trade Window PnL to reflect actual PnL? Thank you |
[2025-02-25 21:21:46] |
Sierra_Chart Engineering - Posts: 19285 |
Refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-26 10:42:52] |
User135243 - Posts: 67 |
Yes it would be really nice if SC had a solution for this (maybe with a cloud-solution), that both pc's would show the correct Trade Activity Log. It seems at the moment it is not possible and the TAS just show the trades done on the current pc. I guess it will work with Teton connection, but many use Rithmic, perhaps it will be possible in the future (yes I know SC is not happy with Rithmic, I use Denali data and just connect the Rithmic-accounts to trade). I'm really happy with SC and that I came back to SC after some years :). Before I used TradeNav for a while and there I had to connect the other pc (using remote) at the end of the trading-day and I had everything on both pc's, but it's a pity that this is not possible with SC. |
[2025-02-26 15:37:10] |
John - SC Support - Posts: 39362 |
This is a limitation on the Rithmic side. If you connect and the information is not downloaded, then this is due to Rithmic not supplying it.
[2025-02-26 15:44:09] |
Load fills for current day only did the trick... for the time being. I am connected to Denali w/ Teton. Thank you
[2025-02-27 19:59:55] |
If you are using the Sierra Chart Teton order routing service or the Sierra Chart Trading Evaluator service, order fill history is available for years. And accessible in any installation of Sierra Chart.
