Date/Time: Mon, 21 Apr 2025 13:11:37 +0000
BTC data problem
View Count: 118
[2025-02-25 18:41:05] |
User991499 - Posts: 2 |
Hi, I can't load the data of BTC to my charts. What other symbol I can use for BTC/USD. ( I can load it but it has some difficullity)
[2025-02-25 18:41:19] |
John - SC Support - Posts: 39362 |
Exactly what symbol are you using?
[2025-03-03 17:24:59] |
BTCUSD_PERP_BINANCE
[2025-03-03 18:16:37] |
We are not seeing any issue with this symbol at this time. What exactly is the problem you are having?
[2025-03-03 21:19:21] |
Sierra_Chart Engineering - Posts: 19285 |
This should not be relevant to the issue. However, update Sierra Chart to the current version. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
