Date/Time: Mon, 21 Apr 2025 13:11:44 +0000
Chart resizing
View Count: 89
[2025-02-25 17:35:37] |
User937068 - Posts: 24 |
Hi John I'm currently on Interactive scale range and Scale Range: Automatic and chart is auto resizing based on visible candle bars. if i switch to Set X & Y Constant Relantionship then chart is moving along with current price. Where is the setting to have a static chart that can be moved in any direction without changing candles size and resizing to be done with scroll wheeel? |
[2025-02-25 21:39:41] |
John - SC Support - Posts: 39362 |
You would want to use one of the "Constant Range" or "User Defined Range" options for the Scale. Refer to the following: Chart Scale and Scale Adjusting: Constant Range (Scale Range) Chart Scale and Scale Adjusting: User Defined (Scale Range) Note the options associated with the Constant Range, as you may find one of them is more specific to what you are wanting. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-26 13:52:34] |
I didnt saw the Scale Settings menu :) Is there a Global Scale settings to be applied to all Charts? Thank you. Date Time Of Last Edit: 2025-02-26 13:54:49
[2025-02-26 16:36:50] |
No, there is not a "Global Scale Setting" that can be applied to all charts. But once you have a chart setup the way you want, you can use that as a template. Refer to the following: Using Chart Templates For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-27 12:58:40] |
Got it. Thank you |
