Date/Time: Mon, 21 Apr 2025 13:14:33 +0000
ETH OHLC levels displayed on RTH chart
View Count: 98
[2025-02-25 15:59:20]
User224223 - Posts: 3
Hi all,
This is my first post here. I've tried looking up prior posts relating to this but none of them directly address this.
I'm using the Daily OHLC study to plot the prior trading session high and low based on RTH and ETH. I apply the study twice with one having the "Use Day Session Only" setting enabled and the other disabled. The ETH levels show normally when the overnight session is visible (screenshot 1). However, when I use only the regular trading session, only the RTH levels are visible (screenshot 2). Is there a way to display the ETH levels on the RTH chart without using the overnight session?
Thank you.
image1.png / V - Attached On 2025-02-25 15:56:26 UTC - Size: 56.95 KB - 28 views
image2.png / V - Attached On 2025-02-25 15:56:36 UTC - Size: 38.43 KB - 25 views
[2025-02-25 16:42:13]
John - SC Support - Posts: 39362
You would need to have another chart that includes the ETH hours and use the study on that chart and then overlay that study to the RTH chart.
In this case, you would want to set the Input for "Match Source Bars to Destination Bars" for the "Study/Price Overlay" is set to "No". Refer to the following:
Study/Price Overlay Study
[2025-02-26 14:53:50]
Thanks John. Appreciate the quick reply. I'll give that a shot.
