Date/Time: Mon, 21 Apr 2025 13:14:33 +0000
Footprint not duplicating correctly
View Count: 68
[2025-02-25 13:33:34]
User110225 - Posts: 23
Hello
I hope you are all well.
I would be really grateful for help with my footprint chart
My footprint chart is based on renko bars in ticks. When I try to duplicate this chart, the system duplicates the chart and produces another identical chart (which is what I want), it then immediately downloads the data again and converts the chart from a renko chart to a 3 min time based chart.
If I go into chart settings > bar period > and change the bar period type back to renko bar in ticks and set the bar period value to 3 ticks, the system reloads the data and produces the desired chart, and then immediately converts it back to a 3 min time based chart.
This also happens happens to any other footprint chart that I duplicate across from another chartbook.
I have check the study settings and they all seem to be the same, I cannot work out why this is happening.
Please help.
Best wishes
Chris
[2025-02-25 16:08:14]
John - SC Support - Posts: 39362
You most likely have the chart linking setup for the Bar Period and when you duplicate to another chartbook it is then picking up the linking for a different chart. Refer to the following:
Chart Settings: Chart Linking (Chart >> Chart Settings >> Linking menu)
The other possibility is that the chart has a dependency on another chart, and then when duplicating to another chartbook, that other chart has a different bar period. This is similar to the above but would be due to a study. Refer to the following:
Unable to Change the Bar Time Period for Charts
