Date/Time: Mon, 21 Apr 2025 13:17:35 +0000
Log Massages Error DLL.
View Count: 106
[2025-02-25 10:57:22]
Tin43 - Posts: 141
2025-02-25 05:22:09.347 | Disallowing loading of DLL: C:\SierraChart\Data\RangeBarTradingSystem.dll
2025-02-25 05:22:09.347 | Setting study DLL module function objects to indicate DLL is not loaded: C:\SierraChart\Data\RangeBarTradingSystem.dll
2025-02-25 05:22:09.347 | Unloaded DLL: C:\SierraChart\Data\RangeBarTradingSystem.dll. Handle: e1b0000
2025-02-25 05:22:58.487 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2025-02-25 05:22:58.487 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (4) | New receive buffer size: 0
2025-02-25 05:22:58.487 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (4) | Connecting to IP: 67.214.125.8.
2025-02-25 05:23:03.058 | The compiler response is empty.
2025-02-25 05:23:03.062 | Setting study DLL module function objects to indicate DLL is not loaded: C:\SierraChart\Data\RangeBarTradingSystem.dll
2025-02-25 05:23:03.062 | Study DLL module not found for: C:\SierraChart\Data\RangeBarTradingSystem.dll
2025-02-25 05:23:03.314 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (4) | CloseSocket call.
2025-02-25 05:23:03.314 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close.
2025-02-25 05:23:03.461 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (4) | Socket gracefully closed by remote side.
2025-02-25 05:23:03.461 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (4) | Closed.
I compiled a trading system. Took one trade, then no more trades.
Is this related somehow?
[2025-02-25 16:00:26]
Sierra_Chart Engineering - Posts: 19285
This log is not helpful for us. We need to see the build output from the build custom studies DLL window.
[2025-02-25 18:12:33]
Tin43 - Posts: 141
Sorry, don't know what happened, but seems solved!
