Date/Time: Mon, 21 Apr 2025 13:14:33 +0000
Closed position in IBKR app, fills not displaying in Sierra Chart
View Count: 117
[2025-02-24 23:49:30]
sean3000 - Posts: 65
I opened a position in Sierra Chart and closed it later in the IBKR app because I was away from my computer.
The closing order fill is not displaying on my chart. I can see that the position is closed in my IBKR account.
I have tried these steps with no success:
- Reconnected to data feed
- Logged out then back in to IB Gateway
- Trade Orders window >> Edit >> Refresh Trade Data
- Data/Trade Service Settings > > Service Settings >> Instance Client ID set to 0
- Chart Settings >> Trading >> Order Fills Number of Days to Load set to 250
- Chart Settings >> Trading >> Load Order Fills for Current Day Only set to No
I have my IBKR account connected in TradingView and both executions are showing up there.
[2025-02-25 15:36:57]
John - SC Support - Posts: 39362
You need to enter the order fill manually. Refer to the following:
Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log)
Alternatively, you could change the "Chart >> Chart Settings >> Trading >> Order Fills Start Date-Time" to be after that particular trade, so your Daily P/L will show properly, but that trade will still not show properly in your Trade Activity Log. Refer to the following:
Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu)
[2025-02-26 03:19:43]
Thank you. So Sierra Chart does not have the ability to retrieve historical order fills from my IBKR account if the position was closed outside of Sierra Chart?
Is there a way to avoid this issue in the future if I have to close a trade when I'm away from my computer?
[2025-02-26 15:17:09]
We try to get the information from Interactive Brokers, but it is not always available. Refer to the following:
Interactive Brokers Trading Service: Orders Entered from Trader Workstation do Not Appear in Sierra Chart
Apart from what is given in the link above, there is no other "solution".
