Date/Time: Mon, 21 Apr 2025 13:14:36 +0000
HOt Keys for Hand and Cross hair
View Count: 77
[2025-02-24 21:34:05] |
Artieb60 - Posts: 10 |
I cannot find out where to change my hot keys for cross hair. I want to change it to J instead of C. Please help. Thank you, A |
[2025-02-25 15:27:36] |
John - SC Support - Posts: 39362 |
Refer to the following: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) Note that we do not recommend using a single character for a keyboard shortcut, as that can be confused by the operating system as the key input and not as the keyboard shortcut. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
