Date/Time: Mon, 21 Apr 2025 13:14:36 +0000
Grid lines appear to be offset a bit
View Count: 139
[2025-02-24 17:46:19] |
QnReally - Posts: 188 |
SC, On my Chart DOM chart the grid lines don't align horizontally with the correct value on the price scale. Please see https://www.sierrachart.com/image.php?Image=1740419069620.png for details. I am running v2741. Am I doing something incorrect? Thanks. |
[2025-02-24 18:21:41] |
John - SC Support - Posts: 39362 |
Please get us an image of your entire chart by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-24 18:51:32] |
I think I followed the same instructions for this one I posted -- https://www.sierrachart.com/image.php?Image=1740419069620.png Please let me know if you would like something different. Thanks. |
[2025-02-24 23:04:57] |
What you are seeing is normal. When you extend the grid lines into the DOM then it offsets a bit so that the line is not drawn over the actual price at which the line is drawn. Refer to the following: Global Trade Settings Windows: Extend Chart Horizontal Grid onto Chart DOM (Global Settings >> Chart DOM Settings >> Other >> Other Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
