Date/Time: Mon, 21 Apr 2025 18:13:42 +0000
How to close partial with a hotkey
View Count: 108
[2025-02-24 17:11:34]
DonForex - Posts: 1
Hi , for example if i go long/short with 5 contracts and i want to close 2 of them with a hotkey , how i can do it? Thanks
[2025-02-24 18:16:21]
John - SC Support - Posts: 39380
You would send an opposing order for the quantity you want to close out. You would also want to enable "Scale Out" in order to ensure that working orders are also modified for the amount you are closing. Refer to the following:
Attached Orders: Scaling Out
