Date/Time: Mon, 21 Apr 2025 18:01:42 +0000
Suggestions For Improving Rectangle Tool
View Count: 94
[2025-02-24 16:30:28] |
Deenius - Posts: 22 |
I would like to suggest a few improvements to the rectangle tool. I often work with this tool in TradingView, where it is refined to perfection. However, since I like to backtest on Sierra Chart, I would appreciate it if it worked equally well on this platform. This tool has gained popularity recently and is widely used by most traders. Therefore, I believe that many of your users will appreciate my suggestions for improvement. For me, working with this tool and its visual appearance are very important. Please add these settings: * Midline Width * Midline Color * Midline Style * Text Color I'd also like to point out that when the text alignment is set to "center," it overlaps with the midline and is, therefore, not clearly visible. I have attached a screenshot showing this problem. I have also attached a sample of the rectangle tool from TradingView in that screenshot. This is the form I would like to achieve. Thank you very much. |
