Date/Time: Mon, 21 Apr 2025 18:01:42 +0000
Attached order keyboard shortcut
View Count: 106
[2025-02-24 15:58:10] |
samlok43 - Posts: 5 |
I have several attached order configurations saved. Is there a way for me to assign a shortcut key to my specific order configurations? I trade rapidly and I click wrong order configuration sometimes in the heat of the moment. I, like most, am a lot more precise with keyboard than with mouse. Thank you
[2025-02-24 17:48:34] |
John - SC Support - Posts: 39380 |
Refer to the following (note item #9 that gives the information related to keyboard shortcuts): Control Bar: Control Bar Trade Window Configuration Buttons For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
