Date/Time: Mon, 21 Apr 2025 18:16:45 +0000
Where is the data coming from for the Equities Footprint?
View Count: 111
[2025-02-24 15:50:43]
jsandlan - Posts: 57
Does the Equities Footprint use trades or tick by tick data?
If neither, what is the name / type of data being fed into the Footprint for equities?
Also, what is the source of the data used by the Footprint?
Date Time Of Last Edit: 2025-02-24 15:51:36
[2025-02-24 17:46:19]
John - SC Support - Posts: 39381
Data for the Numbers Bars study comes from actual trades. Therefore, this data will be affected by the "Intraday Data Storage Time Unit", which should be set to 1 tick if you are using the Numbers Bars study. Refer to the following:
Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings)
You can also use the Numbers Bars study to force this. Refer to the following:
Numbers Bars: Require 1 Tick Intraday Data Storage Time
We are not sure what you are asking here. The data comes from whatever data source you are using.
