Date/Time: Tue, 04 Nov 2025 17:11:16 +0000
About Multi-species Trading Templates
View Count: 258
[2025-02-24 10:12:50]
User886314 - Posts: 19
Hi Engineer, I would like to know if it is possible to overlay multiple trades on the main chart of sierra chart, if so how should I do it, looking forward to hearing from you?
[2025-02-24 17:17:10]
John - SC Support - Posts: 42755
If you are asking to show the Order Fills from different symbols on a chart, then the answer is that you can not do this. For one thing, the prices will vary widely, so even if you did overlay them, the fills would be at very different prices and not visible.
If you are asking something else, then we are not certain what it is. Please give us more information on what you are wanting to do.
[2025-02-26 13:19:18]
Hello John, last time I asked you about the main chart can not be stacked with a variety of trading varieties of the problem, I would like to more clearly to you to describe my problem, my problem is that my chart thin main chart is the gold trading varieties, in this case I can not be in the gold trading varieties of the basis of stacking the other trading varieties, such as: crude oil, treasury bonds, I look forward to your reply, thank you!
[2025-02-26 16:34:52]
If you are wanting to display other symbols on the same chart, then refer to the following study:
Add Additional Symbol
