Date/Time: Mon, 21 Apr 2025 13:14:34 +0000
Small Error in the
View Count: 141
[2025-02-23 15:45:35] |
HumblyTrading - Posts: 201 |
Hello SC Team, This is just to notify you that the names are incorrect (I think) in the Keyboard Shortcut Window for "Custom Drawing Tool Keyboard Shortcuts." When you click on the actual Custom Drawing Tool 1, 2, 3, etc, the window to change the command on the right will read "Custom Text Drawing Tool Keyboard Shortcuts >> Custom Text Tool 151 - Custom Text Drawing 151." This is not a big deal, just notifying you of its existence. Thank you, Mike |
[2025-02-23 20:59:15] |
Sierra_Chart Engineering - Posts: 19285 |
Thank you. We will check.
[2025-02-24 08:42:33] |
This is not a small error. This is a serious issue, with the internal configuration of keyboard shortcuts of these type/category and it will be resolved in the next release.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-02-24 09:13:16
[2025-02-25 23:03:16] |
Thanks.
