Date/Time: Sat, 26 Sep 2026 22:16:22 +0000
Histogram of TICK-NQ
View Count: 636
[2025-02-23 01:42:09]
cmack1011 - Posts: 201
Could you please direct me to info on how to create a positive/negative histogram of/underneath the TICK-NQ chart? Thx
[2025-02-23 18:35:43]
cmet - Posts: 743
1. Add the attached dll to your Sierrachart/Data directory (alternatively, you can compile the attached cpp file yourself).
3. Run Sierrachart
3. Load NQ Tick Chart
4. Add Custom Study > "Plot Histogram"
Date Time Of Last Edit: 2025-02-24 02:20:55
attachmentPlotHist.cpp - Attached On 2025-02-23 18:35:09 UTC - Size: 904 B - 258 views
attachmentPlotHist_64.dll - Attached On 2025-02-23 18:35:18 UTC - Size: 104 KB - 256 views
[2025-02-24 02:15:42]
Thx for sending. After placing the .ccp file into the data file, I'm getting this error message when I open the "Add Custom Studies" file and I can't find the .ccp file in the directory: Please advise
2025-02-24 02:07:06.755 | Trade activity files set size: 187
2025-02-24 02:07:06.846 | Reading Internal Order ID file.
2025-02-24 02:07:06.850 | Reading Trade Orders file.
2025-02-24 02:07:06.851 | Reading Trade Positions file.
2025-02-24 02:07:06.853 | Reading Trade Account Data files.
2025-02-24 02:07:06.866 | Software version: 2734 64-bit
2025-02-24 02:07:06.866 | Primary Thread ID: 11876
2025-02-24 02:07:06.866 | Usage end date: 2025-06-19
2025-02-24 02:07:06.866 | Enabled for: Advanced Features 2.
2025-02-24 02:07:06.866 | Enabled for: Sierra Chart Historical Data Service.
2025-02-24 02:07:06.866 | Enabled for: Denali Real-Time Exchange Data Feed.
2025-02-24 02:07:06.866 | Enabled for: Delayed Denali Exchange Data Feed.
2025-02-24 02:07:06.866 | Enabled for exchange2: CME
2025-02-24 02:07:06.866 | Enabled for exchange2: NASDAQ TotalView US stock data
2025-02-24 02:07:06.866 | Enabled for exchange2: US Equities Consolidated Tape
2025-02-24 02:07:06.866 | Enabled for exchange2: US Equities Consolidated Tape with Depth
2025-02-24 02:07:06.866 | Allow Support for Sierra Chart Data Feeds is enabled.
2025-02-24 02:07:06.866 | Current selected Data/Trading service: DTC - Sub Instance
2025-02-24 02:07:06.866 | Custom symbol settings values: enabled
2025-02-24 02:07:06.866 | Chart Update Interval: 400
2025-02-24 02:07:06.866 | Intraday Data Storage Time Unit: 0
2025-02-24 02:07:06.866 | Time Zone: +00:00:00 (UTC+00)
2025-02-24 02:07:06.866 | 2025-02-24 02:07:06 Local computer time in UTC
2025-02-24 02:07:06.866 | 2025-02-24 02:07:06 Local computer time in SC Time Zone
2025-02-24 02:07:06.866 | 2025-02-24 02:06:54 Server time in UTC
2025-02-24 02:07:06.866 | Local computer UTC time and Server UTC time difference: 11 seconds.
2025-02-24 02:07:06.866 | Notice: Your computer's clock is off by 11 seconds. Set the 'Global Settings >> NTP Settings >> NTP Client Enable' to 'Yes'.
2025-02-24 02:07:06.866 | Program path: C:\SierraChartOctopi\SierraChartInstance_2\
2025-02-24 02:07:06.866 | Data Files path: C:\SierraChartOctopi\SierraChartInstance_2\Data\
2025-02-24 02:07:06.866 | OS Version Number: 10.0
2025-02-24 02:07:06.866 | Locale Setting: C
2025-02-24 02:07:06.866 | DLLs: ETFISv3.dll, ETFISv3_64.dll, ETOFSv3_64.dll, libzmq-mt-4_3_5.dll, OctoPi_Trader_64.dll, TWFX_FREE_64.dll, TWFX_FREE_SWS_64.dll, TWFX_FREE_ZZS_64.dll, UserContributedStudies_64.dll
2025-02-24 02:07:06.866 | Allowed protected custom studies: Emoji Trading Free Indicator Sampler v3, TWFX_Free
2025-02-24 02:07:06.866 | Crash reporter started: true
2025-02-24 02:07:06.905 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2025-02-24 02:07:06.940 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2025-02-24 02:07:06.940 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2025-02-24 02:07:07.012 | Received 5 login tokens.
2025-02-24 02:07:09.369 | Requested user files to download.
2025-02-24 02:07:09.651 | File to download: TWFX_FREE_SWS_64.dll. Action: 1
2025-02-24 02:07:09.654 | File to download: TWFX_FREE_ZZS_64.dll. Action: 1
2025-02-24 02:07:09.656 | File to download: TWFX_FREE_64.dll. Action: 1
2025-02-24 02:07:09.664 | User files to download complete
2025-02-24 02:07:11.368 |
2025-02-24 02:07:11.372 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2025-02-24 02:07:11.372 | DTC Client socket (1) | Creating socket.
2025-02-24 02:07:11.373 | DTC Client socket (1) | New receive buffer size: 0
2025-02-24 02:07:11.373 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2025-02-24 02:07:11.375 | DTC - Sub Instance | Network connection to server complete.
2025-02-24 02:07:11.375 | DTC - Sub Instance | Starting socket receive thread.
2025-02-24 02:07:11.375 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2025-02-24 02:07:11.376 | DTC - Sub Instance | Setting DTC encoding to Binary VLS
2025-02-24 02:07:11.376 | DTC - Sub Instance | Sending logon request message.
2025-02-24 02:07:11.377 | DTC - Sub Instance | Received logon response.
2025-02-24 02:07:11.377 | DTC - Sub Instance | Server Name: SC DTC Server. Build=52257.
2025-02-24 02:07:11.377 | DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8
2025-02-24 02:07:11.377 | DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=sc_futures_direct.dtc.trading|SymbolSettings=sc_futures_direct.dtc.trading.
2025-02-24 02:07:11.377 | DTC - Sub Instance | Trading is supported.
2025-02-24 02:07:11.377 | DTC - Sub Instance | Order cancel and replace is supported.
2025-02-24 02:07:11.377 | DTC - Sub Instance | OCO Orders supported.
2025-02-24 02:07:11.377 | DTC - Sub Instance | Bracket Orders supported.
2025-02-24 02:07:11.377 | DTC - Sub Instance | MarketDepthIsSupported: 1
2025-02-24 02:07:11.377 | DTC - Sub Instance | Connected to server complete.
2025-02-24 02:07:11.378 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-02-24 02:07:14.592 | Files to Open on Startup | File does not exist: C:\SierraChartOctopi\SierraChartInstance_2\Data\ExampleChartbook.cht
2025-02-24 02:08:05.793 | TRIN-NASDAQ [CB] 60 Min #3 | Reloading chart.
2025-02-24 02:08:05.793 | TRIN-NASDAQ [CB] 60 Min #3 | No contract months found for symbol. Unable to build continuous futures contract chart.
2025-02-24 02:08:05.793 | TRIN-NASDAQ [CB] 60 Min #3 | There are no continuous futures contract symbols. Loading data normally.
2025-02-24 02:08:05.808 | NVOL-NQ [CB] 10 Min #4 | Reloading chart.
2025-02-24 02:08:05.808 | NVOL-NQ [CB] 10 Min #4 | No contract months found for symbol. Unable to build continuous futures contract chart.
2025-02-24 02:08:05.808 | NVOL-NQ [CB] 10 Min #4 | There are no continuous futures contract symbols. Loading data normally.
2025-02-24 02:08:05.847 | Tick-NQ [CB] 10 Min #1 | Reloading chart.
2025-02-24 02:08:05.847 | Tick-NQ [CB] 10 Min #1 | No contract months found for symbol. Unable to build continuous futures contract chart.
2025-02-24 02:08:05.847 | Tick-NQ [CB] 10 Min #1 | There are no continuous futures contract symbols. Loading data normally.
2025-02-24 02:08:05.881 | ADR-NQ [CB] 10 Min #5 | Reloading chart.
2025-02-24 02:08:05.881 | ADR-NQ [CB] 10 Min #5 | No contract months found for symbol. Unable to build continuous futures contract chart.
2025-02-24 02:08:05.881 | ADR-NQ [CB] 10 Min #5 | There are no continuous futures contract symbols. Loading data normally.
2025-02-24 02:08:05.916 | NISS-NQ [CB] 10 Min #2 | Reloading chart.
2025-02-24 02:08:05.916 | NISS-NQ [CB] 10 Min #2 | No contract months found for symbol. Unable to build continuous futures contract chart.
2025-02-24 02:08:05.916 | NISS-NQ [CB] 10 Min #2 | There are no continuous futures contract symbols. Loading data normally.
2025-02-24 02:08:05.957 | TRIN-NQ [CB] 5 Min #6 | Reloading chart.
2025-02-24 02:08:05.957 | TRIN-NQ [CB] 5 Min #6 | No contract months found for symbol. Unable to build continuous futures contract chart.
2025-02-24 02:08:05.957 | TRIN-NQ [CB] 5 Min #6 | There are no continuous futures contract symbols. Loading data normally.
2025-02-24 02:08:06.004 | UDVR-NQ [CB] 10 Min #7 | Reloading chart.
2025-02-24 02:08:06.004 | UDVR-NQ [CB] 10 Min #7 | No contract months found for symbol. Unable to build continuous futures contract chart.
2025-02-24 02:08:06.004 | UDVR-NQ [CB] 10 Min #7 | There are no continuous futures contract symbols. Loading data normally.
2025-02-24 02:08:06.048 | UDVR-SP [CB] 5 Min #8 | Reloading chart.
2025-02-24 02:08:06.048 | UDVR-SP [CB] 5 Min #8 | No contract months found for symbol. Unable to build continuous futures contract chart.
2025-02-24 02:08:06.048 | UDVR-SP [CB] 5 Min #8 | There are no continuous futures contract symbols. Loading data normally.
2025-02-24 02:08:06.086 | ADR-SP [CB] 10 Min #9 | Reloading chart.
2025-02-24 02:08:06.086 | ADR-SP [CB] 10 Min #9 | No contract months found for symbol. Unable to build continuous futures contract chart.
2025-02-24 02:08:06.086 | ADR-SP [CB] 10 Min #9 | There are no continuous futures contract symbols. Loading data normally.
2025-02-24 02:08:06.113 | NQH25_FUT_CME [CB] 10 Min #10 | Reloading chart.
2025-02-24 02:08:06.114 | Starting DelayedDownloadMonitoringTimer
2025-02-24 02:08:06.114 | Starting HDTimeoutTimer
2025-02-24 02:08:06.115 | Added historical Intraday data request for NQH25_FUT_CME to the queue.
2025-02-24 02:08:06.118 | Triggering next historical data download in queue.
2025-02-24 02:08:06.140 | NQH25_FUT_CME [CB] 10 Min #10 | Performing continuous chart historical Daily data download for symbol NQH25_FUT_CME starting at last date in file.
2025-02-24 02:08:06.140 | Added historical Daily data request for NQH25_FUT_CME to the queue.
2025-02-24 02:08:06.152 | NQH25_FUT_CME [CB] 10 Min #10 | Waiting for historical downloads to complete with the IDs: 1, 2,
2025-02-24 02:08:06.180 | NQH25_FUT_CME [CB] 5 Min #11 | Reloading chart.
2025-02-24 02:08:06.188 | NQH25_FUT_CME [CB] 5 Min #11 | Waiting for historical downloads to complete with the IDs: 1, 2,
2025-02-24 02:08:06.232 | TICK-NQ [CB] 10 Min #12 | Reloading chart.
2025-02-24 02:08:06.232 | TICK-NQ [CB] 10 Min #12 | No contract months found for symbol. Unable to build continuous futures contract chart.
2025-02-24 02:08:06.232 | TICK-NQ [CB] 10 Min #12 | There are no continuous futures contract symbols. Loading data normally.
2025-02-24 02:08:06.261 | NVOL-NQ [CB-D] 10 Min #4 | Chart data loading complete.
2025-02-24 02:08:06.264 | Using symbol data fast lookup vector
2025-02-24 02:08:06.265 | HD Request # 1 | Downloading Intraday chart data for NQH25_FUT_CME to the file NQH25_FUT_CME.scid. Service: cme
2025-02-24 02:08:06.266 | HD Request # 1 | Download start date-time: 2025-02-24 02:03:35.000000. File last date-time: 2025-02-24 02:03:35.535000
2025-02-24 02:08:06.266 | HD Request # 1 | Using server: ds28.sierracharts.com port 10149
2025-02-24 02:08:06.267 | Socket (2) | Creating socket.
2025-02-24 02:08:06.267 | Socket (2) | New receive buffer size: 0
2025-02-24 02:08:06.267 | Socket (2) | Connecting to IP: 67.214.125.5.
2025-02-24 02:08:06.272 | TRIN-NASDAQ [CB-D] 60 Min #3 | Chart data loading complete.
2025-02-24 02:08:06.275 | NISS-NQ [CB-D] 10 Min #2 | Chart data loading complete.
2025-02-24 02:08:06.278 | ADR-NQ [CB-D] 10 Min #5 | Chart data loading complete.
2025-02-24 02:08:06.281 | Tick-NQ [CB-D] 10 Min #1 | Chart data loading complete.
2025-02-24 02:08:06.284 | TRIN-NQ [CB-D] 5 Min #6 | Chart data loading complete.
2025-02-24 02:08:06.287 | ADR-SP [CB-D] 10 Min #9 | Chart data loading complete.
2025-02-24 02:08:06.290 | UDVR-SP [CB-D] 5 Min #8 | Chart data loading complete.
2025-02-24 02:08:06.325 | DTC - Sub Instance | Starting real-time market data updates for: TRIN-NASDAQ. ID: 2 Service code: statscalc
2025-02-24 02:08:06.325 | DTC - Sub Instance | Requesting security definition data for: TRIN-NASDAQ. ID: 2
2025-02-24 02:08:06.325 | Added historical Intraday data request for TRIN-NASDAQ to the queue.
2025-02-24 02:08:06.325 | Intraday data recording state for symbol TRIN-NASDAQ is set to download 'Pending'.
2025-02-24 02:08:06.325 | Triggering next historical data download in queue.
2025-02-24 02:08:06.327 | DTC - Sub Instance | Starting real-time market data updates for: NVOL-NQ. ID: 3 Service code: statscalc
2025-02-24 02:08:06.327 | DTC - Sub Instance | Requesting security definition data for: NVOL-NQ. ID: 3
2025-02-24 02:08:06.327 | Added historical Intraday data request for NVOL-NQ to the queue.
2025-02-24 02:08:06.327 | Intraday data recording state for symbol NVOL-NQ is set to download 'Pending'.
2025-02-24 02:08:06.327 | Triggering next historical data download in queue.
2025-02-24 02:08:06.330 | DTC - Sub Instance | Starting real-time market data updates for: Tick-NQ. ID: 4 Service code: statscalc
2025-02-24 02:08:06.330 | DTC - Sub Instance | Requesting security definition data for: Tick-NQ. ID: 4
2025-02-24 02:08:06.330 | Added historical Intraday data request for Tick-NQ to the queue.
2025-02-24 02:08:06.330 | Intraday data recording state for symbol Tick-NQ is set to download 'Pending'.
2025-02-24 02:08:06.330 | Triggering next historical data download in queue.
2025-02-24 02:08:06.333 | DTC - Sub Instance | Setting external service identifier for symbol TRIN-NASDAQ to 1
2025-02-24 02:08:06.333 | DTC - Sub Instance | Received security definition for symbol TRIN-NASDAQ
2025-02-24 02:08:06.335 | DTC - Sub Instance | Starting real-time market data updates for: ADR-NQ. ID: 5 Service code: statscalc
2025-02-24 02:08:06.335 | DTC - Sub Instance | Requesting security definition data for: ADR-NQ. ID: 5
2025-02-24 02:08:06.335 | Added historical Intraday data request for ADR-NQ to the queue.
2025-02-24 02:08:06.335 | Intraday data recording state for symbol ADR-NQ is set to download 'Pending'.
2025-02-24 02:08:06.335 | Triggering next historical data download in queue.
2025-02-24 02:08:06.335 | DTC - Sub Instance | Setting external service identifier for symbol NVOL-NQ to 2
2025-02-24 02:08:06.335 | DTC - Sub Instance | Received security definition for symbol NVOL-NQ
2025-02-24 02:08:06.335 | DTC - Sub Instance | Setting external service identifier for symbol Tick-NQ to 3
2025-02-24 02:08:06.335 | DTC - Sub Instance | Received security definition for symbol Tick-NQ
2025-02-24 02:08:06.347 | TICK-NQ [CB-D] 10 Min #12 | Chart data loading complete.
2025-02-24 02:08:06.349 | DTC - Sub Instance | Starting real-time market data updates for: NISS-NQ. ID: 6 Service code: statscalc
2025-02-24 02:08:06.349 | DTC - Sub Instance | Requesting security definition data for: NISS-NQ. ID: 6
2025-02-24 02:08:06.349 | Added historical Intraday data request for NISS-NQ to the queue.
2025-02-24 02:08:06.349 | Intraday data recording state for symbol NISS-NQ is set to download 'Pending'.
2025-02-24 02:08:06.349 | Triggering next historical data download in queue.
2025-02-24 02:08:06.350 | DTC - Sub Instance | Setting external service identifier for symbol ADR-NQ to 4
2025-02-24 02:08:06.350 | DTC - Sub Instance | Received security definition for symbol ADR-NQ
2025-02-24 02:08:06.353 | DTC - Sub Instance | Starting real-time market data updates for: TRIN-NQ. ID: 7 Service code: statscalc
2025-02-24 02:08:06.353 | DTC - Sub Instance | Requesting security definition data for: TRIN-NQ. ID: 7
2025-02-24 02:08:06.353 | Added historical Intraday data request for TRIN-NQ to the queue.
2025-02-24 02:08:06.353 | Intraday data recording state for symbol TRIN-NQ is set to download 'Pending'.
2025-02-24 02:08:06.353 | Triggering next historical data download in queue.
2025-02-24 02:08:06.354 | DTC - Sub Instance | Setting external service identifier for symbol NISS-NQ to 5
2025-02-24 02:08:06.354 | DTC - Sub Instance | Received security definition for symbol NISS-NQ
2025-02-24 02:08:06.354 | DTC - Sub Instance | Setting external service identifier for symbol TRIN-NQ to 6
2025-02-24 02:08:06.354 | DTC - Sub Instance | Received security definition for symbol TRIN-NQ
2025-02-24 02:08:06.357 | HD Request # 1 | Setting DTC encoding to Binary VLS
2025-02-24 02:08:06.357 | HD Request # 1 | Sending historical data logon request message.
2025-02-24 02:08:06.370 | UDVR-NQ [CB-D] 10 Min #7 | Chart data loading complete.
2025-02-24 02:08:06.397 | DTC - Sub Instance | Starting real-time market data updates for: UDVR-NQ. ID: 8 Service code: statscalc
2025-02-24 02:08:06.397 | DTC - Sub Instance | Requesting security definition data for: UDVR-NQ. ID: 8
2025-02-24 02:08:06.397 | Added historical Intraday data request for UDVR-NQ to the queue.
2025-02-24 02:08:06.397 | Intraday data recording state for symbol UDVR-NQ is set to download 'Pending'.
2025-02-24 02:08:06.397 | Triggering next historical data download in queue.
2025-02-24 02:08:06.398 | DTC - Sub Instance | Setting external service identifier for symbol UDVR-NQ to 7
2025-02-24 02:08:06.398 | DTC - Sub Instance | Received security definition for symbol UDVR-NQ
2025-02-24 02:08:06.438 | HD Request # 1 | Requesting Intraday data. Start date-time: 2025-02-24 02:03:35. Record interval: 0. Symbol: NQH25
2025-02-24 02:08:06.444 | DTC - Sub Instance | Starting real-time market data updates for: UDVR-SP. ID: 9 Service code: statscalc
2025-02-24 02:08:06.444 | DTC - Sub Instance | Requesting security definition data for: UDVR-SP. ID: 9
2025-02-24 02:08:06.444 | Added historical Intraday data request for UDVR-SP to the queue.
2025-02-24 02:08:06.444 | Intraday data recording state for symbol UDVR-SP is set to download 'Pending'.
2025-02-24 02:08:06.444 | Triggering next historical data download in queue.
2025-02-24 02:08:06.445 | DTC - Sub Instance | Setting external service identifier for symbol UDVR-SP to 8
2025-02-24 02:08:06.445 | DTC - Sub Instance | Received security definition for symbol UDVR-SP
2025-02-24 02:08:06.477 | HD Request # 1 | Decompressing data.
2025-02-24 02:08:06.490 | DTC - Sub Instance | Starting real-time market data updates for: ADR-SP. ID: 10 Service code: statscalc
2025-02-24 02:08:06.490 | DTC - Sub Instance | Requesting security definition data for: ADR-SP. ID: 10
2025-02-24 02:08:06.490 | Added historical Intraday data request for ADR-SP to the queue.
2025-02-24 02:08:06.490 | Intraday data recording state for symbol ADR-SP is set to download 'Pending'.
2025-02-24 02:08:06.490 | Triggering next historical data download in queue.
2025-02-24 02:08:06.492 | DTC - Sub Instance | Setting external service identifier for symbol ADR-SP to 9
2025-02-24 02:08:06.492 | DTC - Sub Instance | Received security definition for symbol ADR-SP
2025-02-24 02:08:06.521 | HD Request # 1 | Receiving Intraday data for NQH25_FUT_CME starting at 2025-02-24 02:03:35.535000
2025-02-24 02:08:06.522 | Socket (2) | CloseSocket call.
2025-02-24 02:08:06.523 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-02-24 02:08:06.523 | Historical data download thread signaled to stop.
2025-02-24 02:08:06.523 | HD Request # 1 | Timestamp of first Intraday data file record written: 2025-02-24 02:03:47.142000.
2025-02-24 02:08:06.523 | HD Request # 1 | Received 476 Intraday data records from 2025-02-24 02:03:35.535000 to 2025-02-24 02:07:55.048000 (4.3 minutes. Delay: 11.5 seconds) and wrote 475 records for NQH25_FUT_CME
2025-02-24 02:08:06.543 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2025-02-24 02:07:55.048000
2025-02-24 02:08:06.543 | HD Request # 1 | Completion time: 0s.
2025-02-24 02:08:06.543 | HD Request # 1 | Intraday data download complete for NQH25_FUT_CME. Unique request ID: 1
2025-02-24 02:08:06.543 | Removing historical data download ID 1.
2025-02-24 02:08:06.543 | Real-time Intraday chart data file updates started for NQH25_FUT_CME
2025-02-24 02:08:06.543 | Intraday chart data file opened for NQH25_FUT_CME
2025-02-24 02:08:06.543 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2025-02-24 02:08:06.543 | Triggering next historical data download in queue.
2025-02-24 02:08:06.544 | HD Request # 2 | Downloading Historical Daily chart data for NQH25_FUT_CME. Starting date: 2025-02-19. Service: DTCSubInstance
2025-02-24 02:08:06.544 | HD Request # 2 | Using server: 127.0.0.1 port 11098
2025-02-24 02:08:06.546 | Socket (3) | Creating socket.
2025-02-24 02:08:06.546 | Socket (3) | New receive buffer size: 0
2025-02-24 02:08:06.546 | Socket (3) | Connecting to IP: 127.0.0.1.
2025-02-24 02:08:06.554 | DTC - Sub Instance | Real-time data for symbol ADR-NQ has been restored.
2025-02-24 02:08:06.554 | DTC - Sub Instance | Real-time data for symbol ADR-SP has been restored.
2025-02-24 02:08:06.554 | DTC - Sub Instance | Real-time data for symbol NISS-NQ has been restored.
2025-02-24 02:08:06.554 | DTC - Sub Instance | Real-time data for symbol NVOL-NQ has been restored.
2025-02-24 02:08:06.554 | DTC - Sub Instance | Real-time data for symbol Tick-NQ has been restored.
2025-02-24 02:08:06.554 | DTC - Sub Instance | Real-time data for symbol TRIN-NASDAQ has been restored.
2025-02-24 02:08:06.554 | DTC - Sub Instance | Real-time data for symbol TRIN-NQ has been restored.
2025-02-24 02:08:06.554 | DTC - Sub Instance | Real-time data for symbol UDVR-NQ has been restored.
2025-02-24 02:08:06.554 | DTC - Sub Instance | Real-time data for symbol UDVR-SP has been restored.
2025-02-24 02:08:06.559 | HD Request # 2 | Setting DTC encoding to Binary VLS
2025-02-24 02:08:06.559 | HD Request # 2 | Sending historical data logon request message.
2025-02-24 02:08:06.560 | HD Request # 2 | Requesting historical Daily data starting at 2025-02-19.
2025-02-24 02:08:06.560 | Socket (2) | Socket gracefully closed by remote side.
2025-02-24 02:08:06.560 | Socket (2) | Closed.
2025-02-24 02:08:06.561 | HD Request # 2 | Data is being downloaded from a remote source. Download will start when this is done.
2025-02-24 02:08:06.672 | DTC - Sub Instance | Setting external service identifier for symbol ADR-NQ to 113
2025-02-24 02:08:06.672 | DTC - Sub Instance | Received security definition for symbol ADR-NQ
2025-02-24 02:08:06.672 | DTC - Sub Instance | Setting external service identifier for symbol ADR-SP to 109
2025-02-24 02:08:06.672 | DTC - Sub Instance | Received security definition for symbol ADR-SP
2025-02-24 02:08:06.672 | DTC - Sub Instance | Setting external service identifier for symbol NISS-NQ to 60
2025-02-24 02:08:06.672 | DTC - Sub Instance | Received security definition for symbol NISS-NQ
2025-02-24 02:08:06.672 | DTC - Sub Instance | Setting external service identifier for symbol NVOL-NQ to 68
2025-02-24 02:08:06.672 | DTC - Sub Instance | Received security definition for symbol NVOL-NQ
2025-02-24 02:08:06.672 | DTC - Sub Instance | Setting external service identifier for symbol Tick-NQ to 54
2025-02-24 02:08:06.672 | DTC - Sub Instance | Received security definition for symbol Tick-NQ
2025-02-24 02:08:06.672 | DTC - Sub Instance | Setting external service identifier for symbol TRIN-NASDAQ to 38
2025-02-24 02:08:06.672 | DTC - Sub Instance | Received security definition for symbol TRIN-NASDAQ
2025-02-24 02:08:06.672 | DTC - Sub Instance | Setting external service identifier for symbol TRIN-NQ to 55
2025-02-24 02:08:06.672 | DTC - Sub Instance | Received security definition for symbol TRIN-NQ
2025-02-24 02:08:06.672 | DTC - Sub Instance | Setting external service identifier for symbol UDVR-NQ to 114
2025-02-24 02:08:06.672 | DTC - Sub Instance | Received security definition for symbol UDVR-NQ
2025-02-24 02:08:06.672 | DTC - Sub Instance | Setting external service identifier for symbol UDVR-SP to 110
2025-02-24 02:08:06.672 | DTC - Sub Instance | Received security definition for symbol UDVR-SP
2025-02-24 02:08:07.569 | HD Request # 2 | Decompressing data.
2025-02-24 02:08:07.571 | HD Request # 2 | Receiving historical Daily data for NQH25_FUT_CME starting at 2025-02-19.
2025-02-24 02:08:07.571 | HD Request # 2 | Writing historical Daily data to the file NQH25_FUT_CME.dly.
2025-02-24 02:08:07.573 | Socket (3) | CloseSocket call.
2025-02-24 02:08:07.573 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-02-24 02:08:07.574 | Historical data download thread signaled to stop.
2025-02-24 02:08:07.574 | HD Request # 2 | Received 3 Daily data records from 2025-02-19 00:00:00 to 2025-02-21 00:00:00 (3.0 days) and wrote 3 records for NQH25_FUT_CME
2025-02-24 02:08:07.574 | HD Request # 2 | Completion time: 1s.
2025-02-24 02:08:07.574 | HD Request # 2 | Daily data download complete for NQH25_FUT_CME. Unique request ID: 2
2025-02-24 02:08:07.574 | Removing historical data download ID 2.
2025-02-24 02:08:07.574 | Triggering next historical data download in queue.
2025-02-24 02:08:07.574 | Delaying start of download for TRIN-NASDAQ.
2025-02-24 02:08:07.575 | Socket (3) | Socket gracefully closed by remote side.
2025-02-24 02:08:07.575 | Socket (3) | Closed.
2025-02-24 02:08:07.756 | NQH25_FUT_CME [CB] 10 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2025-02-24 02:08:07.756 | NQH25_FUT_CME [CB] 10 Min #10 | Reloading chart.
2025-02-24 02:08:07.804 | NQH25_FUT_CME [CB] 5 Min #11 | Download is complete for all contract months in chart. Proceeding with data load.
2025-02-24 02:08:07.804 | NQH25_FUT_CME [CB] 5 Min #11 | Reloading chart.
2025-02-24 02:08:08.163 | NQH25_FUT_CME [CB] 10 Min #10 | Reloading chart.
2025-02-24 02:08:08.209 | NQH25_FUT_CME [CB] 5 Min #11 | Reloading chart.
2025-02-24 02:08:08.292 | NQH25_FUT_CME [CB] 10 Min #10 | Chart data loading complete.
2025-02-24 02:08:08.293 | NQH25_FUT_CME [CB] 5 Min #11 | Chart data loading complete.
2025-02-24 02:08:08.569 | DTC - Sub Instance | Starting real-time market data updates for: NQH25_FUT_CME. ID: 1
2025-02-24 02:08:08.569 | DTC - Sub Instance | Requesting security definition data for: NQH25_FUT_CME. ID: 1
2025-02-24 02:08:08.576 | DTC - Sub Instance | Setting external service identifier for symbol NQH25_FUT_CME to 10
2025-02-24 02:08:08.576 | DTC - Sub Instance | Received security definition for symbol NQH25_FUT_CME
2025-02-24 02:08:08.596 | DTC - Sub Instance | Setting external service identifier for symbol NQH25_FUT_CME to 42288528
2025-02-24 02:08:08.596 | DTC - Sub Instance | Received security definition for symbol NQH25_FUT_CME
2025-02-24 02:08:09.190 | DTC - Sub Instance | Real-time data for symbol NQH25_FUT_CME has been restored.
2025-02-24 02:08:09.191 | Added historical Intraday data request for NQH25_FUT_CME to the queue.
2025-02-24 02:08:09.191 | Intraday data recording state for symbol NQH25_FUT_CME is set to download 'Pending'.
2025-02-24 02:08:09.191 | Triggering next historical data download in queue.
2025-02-24 02:08:09.319 | DTC - Sub Instance | Setting external service identifier for symbol NQH25_FUT_CME to 42288528
2025-02-24 02:08:09.319 | DTC - Sub Instance | Received security definition for symbol NQH25_FUT_CME
2025-02-24 02:08:11.100 | HD Request # 3 | Downloading Intraday chart data for TRIN-NASDAQ to the file TRIN-NASDAQ.scid. Service: statscalc
2025-02-24 02:08:11.100 | HD Request # 3 | Download start date-time: 2025-02-21 23:59:59.000000. File last date-time: 2025-02-21 23:59:59.714001
2025-02-24 02:08:11.100 | HD Request # 3 | Using server: ds12.sierracharts.com port 10149
2025-02-24 02:08:11.101 | Socket (2) | Creating socket.
2025-02-24 02:08:11.101 | Socket (2) | New receive buffer size: 0
2025-02-24 02:08:11.101 | Socket (2) | Connecting to IP: 69.39.70.241.
2025-02-24 02:08:11.188 | HD Request # 3 | Setting DTC encoding to Binary VLS
2025-02-24 02:08:11.188 | HD Request # 3 | Sending historical data logon request message.
2025-02-24 02:08:11.258 | HD Request # 3 | Requesting Intraday data. Start date-time: 2025-02-21 23:59:59. Record interval: 0. Symbol: TRIN-NASDAQ
2025-02-24 02:08:11.296 | HD Request # 3 | Decompressing data.
2025-02-24 02:08:11.332 | HD Request # 3 | Receiving Intraday data for TRIN-NASDAQ starting at 2025-02-21 23:59:59.000000
2025-02-24 02:08:11.332 | Socket (2) | CloseSocket call.
2025-02-24 02:08:11.332 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-02-24 02:08:11.333 | Historical data download thread signaled to stop.
2025-02-24 02:08:11.333 | HD Request # 3 | Received 1 Intraday data record from 2025-02-21 23:59:59.000000 to 2025-02-21 23:59:59.000000 (0.0 seconds. Delay: 2.1 days) and wrote 0 records for TRIN-NASDAQ
2025-02-24 02:08:11.333 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2025-02-21 23:59:59.714001
2025-02-24 02:08:11.333 | HD Request # 3 | Completion time: 0s.
2025-02-24 02:08:11.333 | HD Request # 3 | Intraday data download complete for TRIN-NASDAQ. Unique request ID: 3
2025-02-24 02:08:11.333 | Removing historical data download ID 3.
2025-02-24 02:08:11.333 | Real-time Intraday chart data file updates started for TRIN-NASDAQ
2025-02-24 02:08:11.333 | Intraday chart data file opened for TRIN-NASDAQ
2025-02-24 02:08:11.333 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2025-02-24 02:08:11.333 | Triggering next historical data download in queue.
2025-02-24 02:08:11.333 | HD Request # 4 | Downloading Intraday chart data for NVOL-NQ to the file NVOL-NQ.scid. Service: statscalc
2025-02-24 02:08:11.333 | HD Request # 4 | Download start date-time: 2025-02-21 21:30:00.000000. File last date-time: 2025-02-21 21:30:00.955001
2025-02-24 02:08:11.333 | HD Request # 4 | Using server: ds4.sierracharts.com port 10150
2025-02-24 02:08:11.371 | Socket (2) | Socket gracefully closed by remote side.
2025-02-24 02:08:11.371 | Socket (2) | Closed.
2025-02-24 02:08:11.391 | Socket (3) | Creating socket.
2025-02-24 02:08:11.391 | Socket (3) | New receive buffer size: 0
2025-02-24 02:08:11.391 | Socket (3) | Connecting to IP: 64.152.155.113.
2025-02-24 02:08:11.478 | HD Request # 4 | Setting DTC encoding to Binary VLS
2025-02-24 02:08:11.478 | HD Request # 4 | Sending historical data logon request message.
2025-02-24 02:08:11.547 | HD Request # 4 | Requesting Intraday data. Start date-time: 2025-02-21 21:30:00. Record interval: 0. Symbol: NVOL-NQ
2025-02-24 02:08:11.587 | HD Request # 4 | Decompressing data.
2025-02-24 02:08:11.625 | HD Request # 4 | Receiving Intraday data for NVOL-NQ starting at 2025-02-21 21:30:00.000000
2025-02-24 02:08:11.625 | Socket (3) | CloseSocket call.
2025-02-24 02:08:11.625 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-02-24 02:08:11.626 | Historical data download thread signaled to stop.
2025-02-24 02:08:11.626 | HD Request # 4 | Received 1 Intraday data record from 2025-02-21 21:30:00.000000 to 2025-02-21 21:30:00.000000 (0.0 seconds. Delay: 2.2 days) and wrote 0 records for NVOL-NQ
2025-02-24 02:08:11.626 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2025-02-21 21:30:00.955001
2025-02-24 02:08:11.626 | HD Request # 4 | Completion time: 0s.
2025-02-24 02:08:11.626 | HD Request # 4 | Intraday data download complete for NVOL-NQ. Unique request ID: 4
2025-02-24 02:08:11.626 | Removing historical data download ID 4.
2025-02-24 02:08:11.626 | Real-time Intraday chart data file updates started for NVOL-NQ
2025-02-24 02:08:11.626 | Intraday chart data file opened for NVOL-NQ
2025-02-24 02:08:11.626 | HD Request # 4 | Enabling Intraday chart updating for symbol.
2025-02-24 02:08:11.626 | Triggering next historical data download in queue.
2025-02-24 02:08:11.626 | HD Request # 5 | Downloading Intraday chart data for Tick-NQ to the file Tick-NQ.scid. Service: statscalc
2025-02-24 02:08:11.626 | HD Request # 5 | Download start date-time: 2025-02-21 23:59:59.000000. File last date-time: 2025-02-21 23:59:59.714000
2025-02-24 02:08:11.627 | HD Request # 5 | Using server: ds12.sierracharts.com port 10149
2025-02-24 02:08:11.627 | Socket (2) | Creating socket.
2025-02-24 02:08:11.627 | Socket (2) | New receive buffer size: 0
2025-02-24 02:08:11.627 | Socket (2) | Connecting to IP: 69.39.70.241.
2025-02-24 02:08:11.661 | Socket (3) | Socket gracefully closed by remote side.
2025-02-24 02:08:11.661 | Socket (3) | Closed.
2025-02-24 02:08:11.712 | HD Request # 5 | Setting DTC encoding to Binary VLS
2025-02-24 02:08:11.713 | HD Request # 5 | Sending historical data logon request message.
2025-02-24 02:08:11.749 | HD Request # 5 | Requesting Intraday data. Start date-time: 2025-02-21 23:59:59. Record interval: 0. Symbol: Tick-NQ
2025-02-24 02:08:11.787 | HD Request # 5 | Decompressing data.
2025-02-24 02:08:11.823 | HD Request # 5 | Receiving Intraday data for Tick-NQ starting at 2025-02-21 23:59:59.000000
2025-02-24 02:08:11.823 | Socket (2) | CloseSocket call.
2025-02-24 02:08:11.824 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-02-24 02:08:11.825 | Historical data download thread signaled to stop.
2025-02-24 02:08:11.825 | HD Request # 5 | Received 1 Intraday data record from 2025-02-21 23:59:59.000000 to 2025-02-21 23:59:59.000000 (0.0 seconds. Delay: 2.1 days) and wrote 0 records for Tick-NQ
2025-02-24 02:08:11.825 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2025-02-21 23:59:59.714000
2025-02-24 02:08:11.825 | HD Request # 5 | Completion time: 0s.
2025-02-24 02:08:11.825 | HD Request # 5 | Intraday data download complete for Tick-NQ. Unique request ID: 5
2025-02-24 02:08:11.825 | Removing historical data download ID 5.
2025-02-24 02:08:11.825 | Real-time Intraday chart data file updates started for Tick-NQ
2025-02-24 02:08:11.825 | Intraday chart data file opened for Tick-NQ
2025-02-24 02:08:11.825 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2025-02-24 02:08:11.825 | Triggering next historical data download in queue.
2025-02-24 02:08:11.825 | HD Request # 6 | Downloading Intraday chart data for ADR-NQ to the file ADR-NQ.scid. Service: statscalc
2025-02-24 02:08:11.826 | HD Request # 6 | Download start date-time: 2025-02-21 23:59:59.000000. File last date-time: 2025-02-21 23:59:59.714000
2025-02-24 02:08:11.826 | HD Request # 6 | Using server: ds4.sierracharts.com port 10150
2025-02-24 02:08:11.826 | Socket (3) | Creating socket.
2025-02-24 02:08:11.826 | Socket (3) | New receive buffer size: 0
2025-02-24 02:08:11.826 | Socket (3) | Connecting to IP: 64.152.155.113.
2025-02-24 02:08:11.865 | Socket (2) | Socket gracefully closed by remote side.
2025-02-24 02:08:11.865 | Socket (2) | Closed.
2025-02-24 02:08:11.914 | HD Request # 6 | Setting DTC encoding to Binary VLS
2025-02-24 02:08:11.914 | HD Request # 6 | Sending historical data logon request message.
2025-02-24 02:08:11.952 | HD Request # 6 | Requesting Intraday data. Start date-time: 2025-02-21 23:59:59. Record interval: 0. Symbol: ADR-NQ
2025-02-24 02:08:11.953 | Chart #1 has tagged chart #12 for full recalculation. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:11.989 | HD Request # 6 | Decompressing data.
2025-02-24 02:08:12.027 | HD Request # 6 | Receiving Intraday data for ADR-NQ starting at 2025-02-21 23:59:59.000000
2025-02-24 02:08:12.027 | Socket (3) | CloseSocket call.
2025-02-24 02:08:12.028 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-02-24 02:08:12.028 | Historical data download thread signaled to stop.
2025-02-24 02:08:12.028 | HD Request # 6 | Received 1 Intraday data record from 2025-02-21 23:59:59.000000 to 2025-02-21 23:59:59.000000 (0.0 seconds. Delay: 2.1 days) and wrote 0 records for ADR-NQ
2025-02-24 02:08:12.028 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2025-02-21 23:59:59.714000
2025-02-24 02:08:12.028 | HD Request # 6 | Completion time: 1s.
2025-02-24 02:08:12.028 | HD Request # 6 | Intraday data download complete for ADR-NQ. Unique request ID: 6
2025-02-24 02:08:12.028 | Removing historical data download ID 6.
2025-02-24 02:08:12.028 | Real-time Intraday chart data file updates started for ADR-NQ
2025-02-24 02:08:12.028 | Intraday chart data file opened for ADR-NQ
2025-02-24 02:08:12.028 | HD Request # 6 | Enabling Intraday chart updating for symbol.
2025-02-24 02:08:12.028 | Triggering next historical data download in queue.
2025-02-24 02:08:12.029 | HD Request # 7 | Downloading Intraday chart data for NISS-NQ to the file NISS-NQ.scid. Service: statscalc
2025-02-24 02:08:12.029 | HD Request # 7 | Download start date-time: 2025-02-21 23:59:59.000000. File last date-time: 2025-02-21 23:59:59.714000
2025-02-24 02:08:12.029 | HD Request # 7 | Using server: ds12.sierracharts.com port 10149
2025-02-24 02:08:12.029 | Socket (2) | Creating socket.
2025-02-24 02:08:12.029 | Socket (2) | New receive buffer size: 0
2025-02-24 02:08:12.029 | Socket (2) | Connecting to IP: 69.39.70.241.
2025-02-24 02:08:12.064 | Socket (3) | Socket gracefully closed by remote side.
2025-02-24 02:08:12.064 | Socket (3) | Closed.
2025-02-24 02:08:12.114 | HD Request # 7 | Setting DTC encoding to Binary VLS
2025-02-24 02:08:12.114 | HD Request # 7 | Sending historical data logon request message.
2025-02-24 02:08:12.150 | HD Request # 7 | Requesting Intraday data. Start date-time: 2025-02-21 23:59:59. Record interval: 0. Symbol: NISS-NQ
2025-02-24 02:08:12.187 | HD Request # 7 | Decompressing data.
2025-02-24 02:08:12.223 | HD Request # 7 | Receiving Intraday data for NISS-NQ starting at 2025-02-21 23:59:59.000000
2025-02-24 02:08:12.223 | Socket (2) | CloseSocket call.
2025-02-24 02:08:12.223 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-02-24 02:08:12.225 | Historical data download thread signaled to stop.
2025-02-24 02:08:12.225 | HD Request # 7 | Received 1 Intraday data record from 2025-02-21 23:59:59.000000 to 2025-02-21 23:59:59.000000 (0.0 seconds. Delay: 2.1 days) and wrote 0 records for NISS-NQ
2025-02-24 02:08:12.225 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2025-02-21 23:59:59.714000
2025-02-24 02:08:12.225 | HD Request # 7 | Completion time: 0s.
2025-02-24 02:08:12.225 | HD Request # 7 | Intraday data download complete for NISS-NQ. Unique request ID: 7
2025-02-24 02:08:12.225 | Removing historical data download ID 7.
2025-02-24 02:08:12.225 | Real-time Intraday chart data file updates started for NISS-NQ
2025-02-24 02:08:12.225 | Intraday chart data file opened for NISS-NQ
2025-02-24 02:08:12.225 | HD Request # 7 | Enabling Intraday chart updating for symbol.
2025-02-24 02:08:12.225 | Triggering next historical data download in queue.
2025-02-24 02:08:12.225 | HD Request # 8 | Downloading Intraday chart data for TRIN-NQ to the file TRIN-NQ.scid. Service: statscalc
2025-02-24 02:08:12.226 | HD Request # 8 | Download start date-time: 2025-02-21 23:59:59.000000. File last date-time: 2025-02-21 23:59:59.714000
2025-02-24 02:08:12.226 | HD Request # 8 | Using server: ds4.sierracharts.com port 10150
2025-02-24 02:08:12.226 | Socket (3) | Creating socket.
2025-02-24 02:08:12.226 | Socket (3) | New receive buffer size: 0
2025-02-24 02:08:12.226 | Socket (3) | Connecting to IP: 64.152.155.113.
2025-02-24 02:08:12.260 | Socket (2) | Socket gracefully closed by remote side.
2025-02-24 02:08:12.260 | Socket (2) | Closed.
2025-02-24 02:08:12.314 | HD Request # 8 | Setting DTC encoding to Binary VLS
2025-02-24 02:08:12.314 | HD Request # 8 | Sending historical data logon request message.
2025-02-24 02:08:12.350 | TICK-NQ [CB-D] 10 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:12.351 | HD Request # 8 | Requesting Intraday data. Start date-time: 2025-02-21 23:59:59. Record interval: 0. Symbol: TRIN-NQ
2025-02-24 02:08:12.381 | Chart #5 has tagged chart #11 for full recalculation. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:12.381 | Chart #5 has tagged chart #7 for full recalculation. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:12.390 | HD Request # 8 | Decompressing data.
2025-02-24 02:08:12.426 | HD Request # 8 | Receiving Intraday data for TRIN-NQ starting at 2025-02-21 23:59:59.000000
2025-02-24 02:08:12.426 | Socket (3) | CloseSocket call.
2025-02-24 02:08:12.426 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-02-24 02:08:12.427 | Historical data download thread signaled to stop.
2025-02-24 02:08:12.427 | HD Request # 8 | Received 1 Intraday data record from 2025-02-21 23:59:59.000000 to 2025-02-21 23:59:59.000000 (0.0 seconds. Delay: 2.1 days) and wrote 0 records for TRIN-NQ
2025-02-24 02:08:12.427 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2025-02-21 23:59:59.714000
2025-02-24 02:08:12.427 | HD Request # 8 | Completion time: 0s.
2025-02-24 02:08:12.427 | HD Request # 8 | Intraday data download complete for TRIN-NQ. Unique request ID: 8
2025-02-24 02:08:12.427 | Removing historical data download ID 8.
2025-02-24 02:08:12.427 | Real-time Intraday chart data file updates started for TRIN-NQ
2025-02-24 02:08:12.427 | Intraday chart data file opened for TRIN-NQ
2025-02-24 02:08:12.427 | HD Request # 8 | Enabling Intraday chart updating for symbol.
2025-02-24 02:08:12.427 | Triggering next historical data download in queue.
2025-02-24 02:08:12.427 | HD Request # 9 | Downloading Intraday chart data for UDVR-NQ to the file UDVR-NQ.scid. Service: statscalc
2025-02-24 02:08:12.427 | HD Request # 9 | Download start date-time: 2025-02-21 23:59:59.000000. File last date-time: 2025-02-21 23:59:59.714000
2025-02-24 02:08:12.428 | HD Request # 9 | Using server: ds12.sierracharts.com port 10149
2025-02-24 02:08:12.428 | Socket (2) | Creating socket.
2025-02-24 02:08:12.428 | Socket (2) | New receive buffer size: 0
2025-02-24 02:08:12.428 | Socket (2) | Connecting to IP: 69.39.70.241.
2025-02-24 02:08:12.462 | Socket (3) | Socket gracefully closed by remote side.
2025-02-24 02:08:12.462 | Socket (3) | Closed.
2025-02-24 02:08:12.491 | Chart #2 has tagged chart #10 for full recalculation. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:12.491 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:12.491 | Chart #2 has tagged chart #8 for full recalculation. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:12.491 | Chart #2 has tagged chart #9 for full recalculation. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:12.491 | Chart #6 has tagged chart #11 for full recalculation. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:12.506 | UDVR-NQ [CB-D] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:12.506 | Chart #7 has tagged chart #11 for full recalculation. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:12.512 | HD Request # 9 | Setting DTC encoding to Binary VLS
2025-02-24 02:08:12.512 | HD Request # 9 | Sending historical data logon request message.
2025-02-24 02:08:12.549 | HD Request # 9 | Requesting Intraday data. Start date-time: 2025-02-21 23:59:59. Record interval: 0. Symbol: UDVR-NQ
2025-02-24 02:08:12.569 | UDVR-SP [CB-D] 5 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:12.588 | HD Request # 9 | Decompressing data.
2025-02-24 02:08:12.616 | ADR-SP [CB-D] 10 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:12.624 | HD Request # 9 | Receiving Intraday data for UDVR-NQ starting at 2025-02-21 23:59:59.000000
2025-02-24 02:08:12.624 | Socket (2) | CloseSocket call.
2025-02-24 02:08:12.625 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-02-24 02:08:12.625 | Historical data download thread signaled to stop.
2025-02-24 02:08:12.625 | HD Request # 9 | Received 1 Intraday data record from 2025-02-21 23:59:59.000000 to 2025-02-21 23:59:59.000000 (0.0 seconds. Delay: 2.1 days) and wrote 0 records for UDVR-NQ
2025-02-24 02:08:12.626 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2025-02-21 23:59:59.714000
2025-02-24 02:08:12.626 | HD Request # 9 | Completion time: 0s.
2025-02-24 02:08:12.626 | HD Request # 9 | Intraday data download complete for UDVR-NQ. Unique request ID: 9
2025-02-24 02:08:12.626 | Removing historical data download ID 9.
2025-02-24 02:08:12.626 | Real-time Intraday chart data file updates started for UDVR-NQ
2025-02-24 02:08:12.626 | Intraday chart data file opened for UDVR-NQ
2025-02-24 02:08:12.626 | HD Request # 9 | Enabling Intraday chart updating for symbol.
2025-02-24 02:08:12.626 | Triggering next historical data download in queue.
2025-02-24 02:08:12.626 | HD Request # 10 | Downloading Intraday chart data for UDVR-SP to the file UDVR-SP.scid. Service: statscalc
2025-02-24 02:08:12.627 | HD Request # 10 | Download start date-time: 2025-02-21 23:59:59.000000. File last date-time: 2025-02-21 23:59:59.714000
2025-02-24 02:08:12.627 | HD Request # 10 | Using server: ds4.sierracharts.com port 10150
2025-02-24 02:08:12.629 | Socket (3) | Creating socket.
2025-02-24 02:08:12.629 | Socket (3) | New receive buffer size: 0
2025-02-24 02:08:12.629 | Socket (3) | Connecting to IP: 64.152.155.113.
2025-02-24 02:08:12.661 | Socket (2) | Socket gracefully closed by remote side.
2025-02-24 02:08:12.662 | Socket (2) | Closed.
2025-02-24 02:08:12.662 | NQH25_FUT_CME [CB] 10 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:12.694 | NQH25_FUT_CME [CB] 5 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:12.711 | HD Request # 10 | Setting DTC encoding to Binary VLS
2025-02-24 02:08:12.711 | HD Request # 10 | Sending historical data logon request message.
2025-02-24 02:08:12.749 | HD Request # 10 | Requesting Intraday data. Start date-time: 2025-02-21 23:59:59. Record interval: 0. Symbol: UDVR-SP
2025-02-24 02:08:12.756 | TICK-NQ [CB-D] 10 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:12.785 | HD Request # 10 | Decompressing data.
2025-02-24 02:08:12.821 | HD Request # 10 | Receiving Intraday data for UDVR-SP starting at 2025-02-21 23:59:59.000000
2025-02-24 02:08:12.821 | Socket (3) | CloseSocket call.
2025-02-24 02:08:12.821 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-02-24 02:08:12.822 | Historical data download thread signaled to stop.
2025-02-24 02:08:12.822 | HD Request # 10 | Received 1 Intraday data record from 2025-02-21 23:59:59.000000 to 2025-02-21 23:59:59.000000 (0.0 seconds. Delay: 2.1 days) and wrote 0 records for UDVR-SP
2025-02-24 02:08:12.823 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2025-02-21 23:59:59.714000
2025-02-24 02:08:12.823 | HD Request # 10 | Completion time: 0s.
2025-02-24 02:08:12.823 | HD Request # 10 | Intraday data download complete for UDVR-SP. Unique request ID: 10
2025-02-24 02:08:12.823 | Removing historical data download ID 10.
2025-02-24 02:08:12.823 | Real-time Intraday chart data file updates started for UDVR-SP
2025-02-24 02:08:12.823 | Intraday chart data file opened for UDVR-SP
2025-02-24 02:08:12.823 | HD Request # 10 | Enabling Intraday chart updating for symbol.
2025-02-24 02:08:12.823 | Triggering next historical data download in queue.
2025-02-24 02:08:12.823 | HD Request # 11 | Downloading Intraday chart data for ADR-SP to the file ADR-SP.scid. Service: statscalc
2025-02-24 02:08:12.824 | HD Request # 11 | Download start date-time: 2025-02-21 23:59:59.000000. File last date-time: 2025-02-21 23:59:59.714000
2025-02-24 02:08:12.824 | HD Request # 11 | Using server: ds12.sierracharts.com port 10149
2025-02-24 02:08:12.824 | Socket (2) | Creating socket.
2025-02-24 02:08:12.824 | Socket (2) | New receive buffer size: 0
2025-02-24 02:08:12.824 | Socket (2) | Connecting to IP: 69.39.70.241.
2025-02-24 02:08:12.858 | Socket (3) | Socket gracefully closed by remote side.
2025-02-24 02:08:12.858 | Socket (3) | Closed.
2025-02-24 02:08:12.904 | HD Request # 11 | Setting DTC encoding to Binary VLS
2025-02-24 02:08:12.904 | HD Request # 11 | Sending historical data logon request message.
2025-02-24 02:08:12.913 | Chart #7 has tagged chart #11 for full recalculation. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:12.940 | HD Request # 11 | Requesting Intraday data. Start date-time: 2025-02-21 23:59:59. Record interval: 0. Symbol: ADR-SP
2025-02-24 02:08:12.977 | HD Request # 11 | Decompressing data.
2025-02-24 02:08:13.013 | HD Request # 11 | Receiving Intraday data for ADR-SP starting at 2025-02-21 23:59:59.000000
2025-02-24 02:08:13.013 | Socket (2) | CloseSocket call.
2025-02-24 02:08:13.013 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-02-24 02:08:13.014 | Historical data download thread signaled to stop.
2025-02-24 02:08:13.014 | HD Request # 11 | Received 1 Intraday data record from 2025-02-21 23:59:59.000000 to 2025-02-21 23:59:59.000000 (0.0 seconds. Delay: 2.1 days) and wrote 0 records for ADR-SP
2025-02-24 02:08:13.014 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2025-02-21 23:59:59.714000
2025-02-24 02:08:13.015 | HD Request # 11 | Completion time: 1s.
2025-02-24 02:08:13.015 | HD Request # 11 | Intraday data download complete for ADR-SP. Unique request ID: 11
2025-02-24 02:08:13.015 | Removing historical data download ID 11.
2025-02-24 02:08:13.015 | Real-time Intraday chart data file updates started for ADR-SP
2025-02-24 02:08:13.015 | Intraday chart data file opened for ADR-SP
2025-02-24 02:08:13.015 | HD Request # 11 | Enabling Intraday chart updating for symbol.
2025-02-24 02:08:13.015 | Triggering next historical data download in queue.
2025-02-24 02:08:13.015 | HD Request # 12 | Downloading Intraday chart data for NQH25_FUT_CME to the file NQH25_FUT_CME.scid. Service: cme
2025-02-24 02:08:13.015 | HD Request # 12 | Download start date-time: 2025-02-24 02:07:55.000000. File last date-time: 2025-02-24 02:07:55.048000
2025-02-24 02:08:13.015 | HD Request # 12 | Using server: ds32.sierracharts.com port 10150
2025-02-24 02:08:13.052 | Socket (2) | Socket gracefully closed by remote side.
2025-02-24 02:08:13.052 | Socket (2) | Closed.
2025-02-24 02:08:13.075 | Socket (3) | Creating socket.
2025-02-24 02:08:13.075 | Socket (3) | New receive buffer size: 0
2025-02-24 02:08:13.075 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-02-24 02:08:13.100 | NQH25_FUT_CME [CB] 5 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Best Volume Profiles.Cht
2025-02-24 02:08:13.156 | HD Request # 12 | Setting DTC encoding to Binary VLS
2025-02-24 02:08:13.156 | HD Request # 12 | Sending historical data logon request message.
2025-02-24 02:08:13.251 | HD Request # 12 | Requesting Intraday data. Start date-time: 2025-02-24 02:07:55. Record interval: 0. Symbol: NQH25
2025-02-24 02:08:13.290 | HD Request # 12 | Decompressing data.
2025-02-24 02:08:13.327 | HD Request # 12 | Receiving Intraday data for NQH25_FUT_CME starting at 2025-02-24 02:07:55.005000
2025-02-24 02:08:13.328 | Socket (3) | CloseSocket call.
2025-02-24 02:08:13.328 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-02-24 02:08:13.329 | Historical data download thread signaled to stop.
2025-02-24 02:08:13.329 | HD Request # 12 | Timestamp of first Intraday data file record written: 2025-02-24 02:07:55.708000.
2025-02-24 02:08:13.329 | HD Request # 12 | Received 4 Intraday data records from 2025-02-24 02:07:55.005000 to 2025-02-24 02:07:57.886000 (2.9 seconds. Delay: 15.4 seconds) and wrote 2 records for NQH25_FUT_CME
2025-02-24 02:08:13.342 | HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2025-02-24 02:07:57.886000
2025-02-24 02:08:13.342 | HD Request # 12 | Completion time: 0s.
2025-02-24 02:08:13.342 | HD Request # 12 | Intraday data download complete for NQH25_FUT_CME. Unique request ID: 12
2025-02-24 02:08:13.342 | Removing historical data download ID 12.
2025-02-24 02:08:13.342 | Real-time Intraday chart data file updates started for NQH25_FUT_CME
2025-02-24 02:08:13.342 | Intraday chart data file opened for NQH25_FUT_CME
2025-02-24 02:08:13.342 | HD Request # 12 | Enabling Intraday chart updating for symbol.
2025-02-24 02:08:13.342 | No download requests in the queue to start downloads for.
2025-02-24 02:08:13.370 | Socket (3) | Socket gracefully closed by remote side.
2025-02-24 02:08:13.370 | Socket (3) | Closed.
2025-02-24 02:08:13.804 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\ETFISv3.dll
2025-02-24 02:08:13.804 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\ETOFSv3.dll
2025-02-24 02:08:13.804 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\libzmq-mt-4_3.dll
2025-02-24 02:08:13.804 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\OctoPi_Trader.dll
2025-02-24 02:08:13.804 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE.dll
2025-02-24 02:08:13.804 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE_SWS.dll
2025-02-24 02:08:13.804 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE_ZZS.dll
2025-02-24 02:08:13.804 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\UserContributedStudies.dll
2025-02-24 02:08:13.806 | ETFISv3.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:08:13.808 | ETFISv3_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:08:13.808 | InternalVersionNumberToFileNameMap is empty for ETFISv3
2025-02-24 02:08:13.808 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\ETFISv3.dll returned empty result. *
2025-02-24 02:08:13.810 | ETOFSv3_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:08:13.810 | InternalVersionNumberToFileNameMap is empty for ETOFSv3
2025-02-24 02:08:13.810 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\ETOFSv3.dll returned empty result. *
2025-02-24 02:08:13.810 | InternalVersionNumberToFileNameMap is empty for libzmq-mt-4
2025-02-24 02:08:13.810 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\libzmq-mt-4_3.dll returned empty result. *
2025-02-24 02:08:13.810 | OctoPi_Trader_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:08:13.810 | InternalVersionNumberToFileNameMap is empty for OctoPi_Trader
2025-02-24 02:08:13.810 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\OctoPi_Trader.dll returned empty result. *
2025-02-24 02:08:13.812 | TWFX_FREE_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:08:13.812 | InternalVersionNumberToFileNameMap is empty for TWFX_FREE
2025-02-24 02:08:13.812 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE.dll returned empty result. *
2025-02-24 02:08:13.812 | TWFX_FREE_SWS_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:08:13.812 | InternalVersionNumberToFileNameMap is empty for TWFX_FREE_SWS
2025-02-24 02:08:13.812 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE_SWS.dll returned empty result. *
2025-02-24 02:08:13.813 | TWFX_FREE_ZZS_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:08:13.813 | InternalVersionNumberToFileNameMap is empty for TWFX_FREE_ZZS
2025-02-24 02:08:13.813 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE_ZZS.dll returned empty result. *
2025-02-24 02:08:13.815 | UserContributedStudies_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:08:13.815 | InternalVersionNumberToFileNameMap is empty for UserContributedStudies
2025-02-24 02:08:13.815 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\UserContributedStudies.dll returned empty result. *
2025-02-24 02:08:17.789 | Opened cached Intraday file: C:\SierraChartOctopi\SierraChartInstance_2\Data\NQH25_FUT_CME.scid. Thread ID: 10392
2025-02-24 02:09:39.101 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\ETFISv3.dll
2025-02-24 02:09:39.101 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\ETOFSv3.dll
2025-02-24 02:09:39.101 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\libzmq-mt-4_3.dll
2025-02-24 02:09:39.101 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\OctoPi_Trader.dll
2025-02-24 02:09:39.101 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE.dll
2025-02-24 02:09:39.101 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE_SWS.dll
2025-02-24 02:09:39.101 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE_ZZS.dll
2025-02-24 02:09:39.101 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\UserContributedStudies.dll
2025-02-24 02:09:39.103 | ETFISv3.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:09:39.105 | ETFISv3_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:09:39.105 | InternalVersionNumberToFileNameMap is empty for ETFISv3
2025-02-24 02:09:39.105 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\ETFISv3.dll returned empty result. *
2025-02-24 02:09:39.107 | ETOFSv3_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:09:39.107 | InternalVersionNumberToFileNameMap is empty for ETOFSv3
2025-02-24 02:09:39.107 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\ETOFSv3.dll returned empty result. *
2025-02-24 02:09:39.107 | InternalVersionNumberToFileNameMap is empty for libzmq-mt-4
2025-02-24 02:09:39.107 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\libzmq-mt-4_3.dll returned empty result. *
2025-02-24 02:09:39.107 | OctoPi_Trader_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:09:39.107 | InternalVersionNumberToFileNameMap is empty for OctoPi_Trader
2025-02-24 02:09:39.107 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\OctoPi_Trader.dll returned empty result. *
2025-02-24 02:09:39.109 | TWFX_FREE_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:09:39.109 | InternalVersionNumberToFileNameMap is empty for TWFX_FREE
2025-02-24 02:09:39.109 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE.dll returned empty result. *
2025-02-24 02:09:39.110 | TWFX_FREE_SWS_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:09:39.110 | InternalVersionNumberToFileNameMap is empty for TWFX_FREE_SWS
2025-02-24 02:09:39.110 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE_SWS.dll returned empty result. *
2025-02-24 02:09:39.110 | TWFX_FREE_ZZS_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:09:39.110 | InternalVersionNumberToFileNameMap is empty for TWFX_FREE_ZZS
2025-02-24 02:09:39.110 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE_ZZS.dll returned empty result. *
2025-02-24 02:09:39.112 | UserContributedStudies_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:09:39.112 | InternalVersionNumberToFileNameMap is empty for UserContributedStudies
2025-02-24 02:09:39.112 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\UserContributedStudies.dll returned empty result. *
2025-02-24 02:12:09.275 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\ETFISv3.dll
2025-02-24 02:12:09.275 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\ETOFSv3.dll
2025-02-24 02:12:09.275 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\libzmq-mt-4_3.dll
2025-02-24 02:12:09.275 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\OctoPi_Trader.dll
2025-02-24 02:12:09.275 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE.dll
2025-02-24 02:12:09.275 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE_SWS.dll
2025-02-24 02:12:09.275 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE_ZZS.dll
2025-02-24 02:12:09.275 | Found DLL: C:\SierraChartOctopi\SierraChartInstance_2\Data\UserContributedStudies.dll
2025-02-24 02:12:09.277 | ETFISv3.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:12:09.279 | ETFISv3_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:12:09.279 | InternalVersionNumberToFileNameMap is empty for ETFISv3
2025-02-24 02:12:09.279 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\ETFISv3.dll returned empty result. *
2025-02-24 02:12:09.280 | ETOFSv3_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:12:09.280 | InternalVersionNumberToFileNameMap is empty for ETOFSv3
2025-02-24 02:12:09.280 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\ETOFSv3.dll returned empty result. *
2025-02-24 02:12:09.281 | InternalVersionNumberToFileNameMap is empty for libzmq-mt-4
2025-02-24 02:12:09.281 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\libzmq-mt-4_3.dll returned empty result. *
2025-02-24 02:12:09.281 | OctoPi_Trader_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:12:09.281 | InternalVersionNumberToFileNameMap is empty for OctoPi_Trader
2025-02-24 02:12:09.281 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\OctoPi_Trader.dll returned empty result. *
2025-02-24 02:12:09.283 | TWFX_FREE_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:12:09.283 | InternalVersionNumberToFileNameMap is empty for TWFX_FREE
2025-02-24 02:12:09.283 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE.dll returned empty result. *
2025-02-24 02:12:09.283 | TWFX_FREE_SWS_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:12:09.283 | InternalVersionNumberToFileNameMap is empty for TWFX_FREE_SWS
2025-02-24 02:12:09.283 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE_SWS.dll returned empty result. *
2025-02-24 02:12:09.284 | TWFX_FREE_ZZS_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:12:09.284 | InternalVersionNumberToFileNameMap is empty for TWFX_FREE_ZZS
2025-02-24 02:12:09.284 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\TWFX_FREE_ZZS.dll returned empty result. *
2025-02-24 02:12:09.286 | UserContributedStudies_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application.
2025-02-24 02:12:09.286 | InternalVersionNumberToFileNameMap is empty for UserContributedStudies
2025-02-24 02:12:09.286 | Closest match search for: C:\SierraChartOctopi\SierraChartInstance_2\Data\UserContributedStudies.dll returned empty result. *
[2025-02-24 02:20:36]
cmet - Posts: 743
You have to put the .dll file in the data directory.
.cpp files contain the code you compile in Analysis > Build Custom Studies DLL.
If you compile the code it will place the dll in the data directory automatically.
Didn't realize the dll was private. Just changed it.
Date Time Of Last Edit: 2025-02-24 02:21:21
[2025-02-24 03:19:08]
cmack1011 - Posts: 201
Excellent - that worked!
However, I still get that error message every time I open the "Add Custom Studies" tab. I don't think it's related to the "PlotHist" file though?
[2025-02-24 12:29:43]
cmet - Posts: 743
Those errors are coming from these study dll's:
TWFX_FREE_ZZS
ETOFSv3
You'll have to ask the person that made those what's going on.
