Date/Time: Mon, 15 Dec 2025 09:09:40 +0000
Teton Futures Order Routing inquries
View Count: 1749
| [2025-02-22 19:12:44] |
| lovelivelaught - Posts: 70 |
Hello I read about your Teton Futures Order Routing and I an not completely understand it. Please clarify and explain it it for me So I use Rithmic and my clearing firm is Ironbean and my broker is Discount Trading. If I switch to Teton Futures Order Routing, will my Rithmic be cancelled? Or I still have to pay connection fee to Rithmic? I am with Rithmic only because of their low margin. Will my margin change? I just want to know what changes/cost I will have (like fees, margins, exchange fees and etc) after switching to Teton Futures Order Routing. Thank you in advance! |
| [2025-02-22 21:53:45] |
| Sierra_Chart Engineering - Posts: 21843 |
Yes in this case you would not need to use Rithmic: If I switch to Teton Futures Order Routing, will my Rithmic be cancelled?
You will not need Rithmic anymore and regarding margins we cannot answer any questions about that. Those are controlled by the broker. We cannot also answer any questions about fees other than there are no transaction fees that Teton order routing has. But you need to ask your broker what fees they will charge. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
