Date/Time: Mon, 21 Apr 2025 18:07:47 +0000
Spreadsheet fior trading Buy Entry TRUE being ignored
View Count: 95
[2025-02-22 05:39:13] |
User745789 - Posts: 374 |
I have this working easily in multiple spreadsheets. Today I created a new spreadsheet and can not get it to work. Using cells K3 and M3 my spreadsheet should simultaneously create a buy stop entry above the current price and a sell stop entry below the current price at a certain time. Both cells K3 and M3 switch from 0 to 1 at the correct moment. But only the sell order is created in replay. There is no buy order. If I disable column M for Sell Entry and replay, I get the correct buy entry order being created. So the K3 buy entry logic is correct. But if I re-enable M3, I no longer get the set of buy and sell stop entries. I only get the sell stop entry. Something is stopping the pair of orders simultaneously being created. There is nothing in the Trade Services Log I have triple checked and spreadsheet for trading study line 23 "Allow Opposite Entry with Opposing Position or Orders" is set to Yes. Date Time Of Last Edit: 2025-02-22 06:07:12
[2025-02-24 15:49:03] |
John - SC Support - Posts: 39380 |
We really do not know, there must be something about what you are doing and the particular settings that is causing this. We are a bit surprised that there is no information in the Trade Service Log regarding this. Check the Message Log to see if there is anything in there. The only other item that we can think to check is the Input for "Maximum Position Allowed". Be sure this is high enough to cover the total quantity you could potentially have. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
