Date/Time: Tue, 15 Sep 2026 15:18:29 +0000
Forex intraday data
View Count: 647
| [2025-02-21 21:59:11] |
| gz6969 - Posts: 51 |
Hi, I see Forex intraday data like EURUSD or GBPUSD only back a few days although I use 365 days to load for intraday chart type. Why? Daily or weekly data of the same symbol is available since 1995. https://www.sierrachart.com/image.php?Image=174017462865.png |
| [2025-02-21 22:05:47] |
| John - SC Support - Posts: 47895 |
Refer to the following: Loading More Or Less Data into an Intraday Chart Also, set "Chart >> Chart Settings >> Symbol >> Continuous Futures Contract" to "None" for the chart you show in the image and any other FOREX charts, as these do not use this feature. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-02-23 16:13:27] |
But Continuous Futures Contract is set to none and I use 365 days to load for intraday chart type. Even Delete All Data and Download does not help When you compare both charts I'm now even missing a bit more data at the left compared to my first screenshot https://www.sierrachart.com/image.php?Image=174032690875.png How does it look on your side? Do you see data beyond 2-13? for EURUSD? 40 days of data to load should be enough to see data before 2-13 |
| [2025-02-24 16:53:00] |
Did you follow the link in the link we gave previously? In other words, did you go through the items at the following link: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-02-28 14:30:42] |
Sorry my fault! I thought the "1-Tick Data" setting in the global settings is the initial limiting factor for new charts and with "days to load for intraday chart type" I can overrule the global setting on indiviual charts. But it seems if "1-Tick Data" is set to eg. 10 days you cannot go beyond this value on indiviual charts regardless what you define in "days to load for intraday chart type". Correct?
| [2025-02-28 16:13:37] |
Your initial thoughts were correct. The "Days to Load for Intraday Chart Type" is the amount of data initially downloaded for a symbol that has not already had data downloaded. After the initial download, you would need to change the "Date Range in File From" to the date at which you want the data downloaded. Note that this is not true for Continuous Futures contracts, as the "Date Range in File From" only applies to the current contract. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
