Date/Time: Mon, 21 Apr 2025 18:01:41 +0000
Only show multiple specificized time and date
View Count: 116
[2025-02-21 11:13:33] |
OperatorProfile - Posts: 2 |
Hello, How can I get Sierra to show me on multiple different specific times and days on a single chart? For example: June 15th / 13:45 - 13:59 December 4th / 15:39 - 16:00 The chart would only show the above data, and nothing else. Thanks. |
[2025-02-21 16:16:53] |
John - SC Support - Posts: 39380 |
The only way to do this would be to specify all the dates you do not want to show as excluded from the chart. Refer to the following: Chart Settings: Set Dates To Exclude (Button) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) We really recommend using two different charts, each one setup to show the specific day and time. You can set the specific day and time by using the "Date Range From/To" options in "Chart >> Chart Settings >> Data Limiting" and then set the times through the Session Times. Refer to the following: Chart Settings: Load Data Limiting Method: Date Range >> Date Range From / To (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Date Range menu) Chart Settings: Session Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-02-21 16:19:36
[2025-02-21 16:33:14] |
Okay thanks
