Date/Time: Mon, 15 Dec 2025 09:11:49 +0000
How to Retrieve the Asset's Original Tick Size and Its Monetary Value in ACSIL?
View Count: 477
[2025-02-21 08:48:40]
User299099 - Posts: 13
I’m developing an indicator in ACSIL and need to retrieve the tick size and its monetary value for the asset displayed on a chart. However, I can only get the tick size configured in the chart, not the asset’s original tick size. This is an issue because the user may have set a different tick size in the chart settings.
Additionally, I would like to enforce at least two decimal places for both the price and the tick size.
Does anyone know how I can correctly obtain these two values?
Thanks!
Date Time Of Last Edit: 2025-02-21 08:51:50
[2025-02-21 14:07:07]
Sierra_Chart Engineering - Posts: 21843
You cannot. It is not supported.
