Date/Time: Mon, 21 Apr 2025 18:10:42 +0000
Disable crosshair when moving drawing
View Count: 144
[2025-02-21 01:08:38] |
ntintel - Posts: 20 |
Is there a way to disable crosshair when I create or move drawings? The crosshair makes it quite harder to see vertical lines (see attached "crosshair overlay.PNG") Thanks in advance. |
[2025-02-21 16:09:06] |
John - SC Support - Posts: 39380 |
Refer to the following setting that controls how the crosshairs act when dealing with drawings: Chart Drawing Tools: Action When Other Tools Selected (Global Settings >> Tool Settings >> Chart Values >> Chart Values) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-23 06:39:31] |
Thank you!
