Date/Time: Sat, 19 Sep 2026 10:50:20 +0000
[Programming Help] - SOLVED Issue with function sc.GetOrderForSymbolAndAccountByIndex(...)
View Count: 1457
[2025-02-20 19:29:25]
LTSys - Posts: 68
Is this the best approach to check for new orders? I was looking for some order event I can listen for or subscribe to but I can't find anything like that in the docs.
TIA
bool firstFunctionCall = true;
char *tradeAccount; // global
SCSFExport scsf_MainFunction(SCStudyInterfaceRef sc) {
// some other code
if(firstFunctionCall) {
tradeAccount = accountInput.GetSelectedCustomString().GetChars();
firstFunctionCall = false;
int orderIndex = 0;
s_SCTradeOrder order;
while(sc.GetOrderForSymbolAndAccountByIndex(EMPTY_STRING, tradeAccount, orderIndex, order) != SCTRADING_ORDER_ERROR) {
orderIndex++;
// do something
Date Time Of Last Edit: 2025-02-25 12:36:41
[2025-02-21 14:42:47]
Sierra_Chart Engineering - Posts: 24890
Do you want to get orders, for the Symbol and Trade Account of the particular chart, or all of them?
[2025-02-21 14:57:38]
LTSys - Posts: 68
Hi, thanks for replying...
I'd like to get instant notification of any type of order action, for all symbols, for a specific account.
At the moment I just put the above study code on any chart... but I don't do any calculations or trade from the study so is a study the wrong approach?
TIA
Date Time Of Last Edit: 2025-02-21 19:47:09
[2025-02-24 18:21:14]
LTSys - Posts: 68
Hi, I noticed the "sc.GetOrderForSymbolAndAccountByIndex(...)" function will all of a sudden just stop looping through orders. If I play around with the chart update interval setting or the Minimum chart update interval setting for ACSIL UpdateAlways the orders will start looping again. Clicking the Apply All or the OK button in the chart settings also seems to get the loop working again. Anyone have any possible ideas why that is happening? Seems like a bug but perhaps some additional flags needs to be set in the default section of the study?
if(sc.SetDefaults) {
sc.AutoLoop = 0;
sc.UpdateAlways = 1;
TIA
Date Time Of Last Edit: 2025-02-24 18:50:46
[2025-02-24 19:20:48]
cmet - Posts: 743
In the Trade Service Log, do you see this error: SCTRADING_ORDER_ERROR?
[2025-02-24 19:59:46]
LTSys - Posts: 68
Hi, thanks for the reply. I don't see a file called "Trade Service Log"?
Date Time Of Last Edit: 2025-02-24 21:02:38
[2025-02-24 20:10:32]
cmet - Posts: 743
main menus Trade > Trade Service Log (Ctrl-Shift-L)
I'm sure there's better solutions but I gotta bail. Here's a couple things to look at:
Beginning from 0, you can increment the OrderIndex parameter by 1 and keep calling sc.GetOrderForSymbolAndAccountByIndex until the function returns SCTRADING_ORDER_ERROR indicating there are no more orders.
Options:
Add sc.RequestTradeOrders();
or maybe
sc.FlagFullRecalculate = 1;
Date Time Of Last Edit: 2025-02-24 20:31:59
[2025-02-24 20:42:13]
LTSys - Posts: 68
I added that flag to the defaults...
sc.AutoLoop = 0;
And I am now calling "sc.RequestTradeOrders();" before the loop containing "sc.GetOrderForSymbolAndAccountByIndex(...)".
It worked for about 5 loops and then it stopped looping.
Date Time Of Last Edit: 2025-02-24 20:58:28
[2025-02-24 21:01:31]
LTSys - Posts: 68
Look like the function doesn't like the trade account parameter.
If I change this...
To a hard coded trade account it works.
while(sc.GetOrderForSymbolAndAccountByIndex(EMPTY_STRING, "Sim1", orderIndex, order) != SCTRADING_ORDER_ERROR)
This isn't a solution but at least narrowed it down to where the problem is.
Date Time Of Last Edit: 2025-02-24 21:01:52
[2025-02-24 22:56:55]
cmet - Posts: 743
Can see if this keeps the loop from exiting. Other than that, I'm outta ideas. Maybe someone else will jump in.
SCSFExport scsf_PersistentOrderScan(SCStudyInterfaceRef& sc) {
if (sc.SetDefaults) {
sc.AutoLoop = 0;
return;
sc.RefreshTradeData();
int orderIndex = 0;
SCString emptyString;
bool ordersFound = false;
while (true) {
if (sc.GetOrderForSymbolAndAccountByIndex(emptyString, emptyString, orderIndex, order) == SCTRADING_ORDER_ERROR) {
if (!ordersFound) {
orderIndex = 0;
continue;
ordersFound = true;
orderIndex++;
[2025-02-24 23:11:42]
LTSys - Posts: 68
Thanks for your help, your ideas help me to find the issue.
The value of the global tradeAccount variable was being re-assigned a new value after a while. Hence why it worked sporadically and put me on this lost path trying to find the cause.
The fix was to do a new char[64], a memset, and a memcpy.
Appreciate your effort alot... hopefully I can return the effort some day.
Here is the code that fixed the issue...
char *tradeAccount = new char[128]; // global
// some other code
const char *tmp = accountInput.GetSelectedCustomString().GetChars();
memset(tradeAccount, 0x00, 128); // reset buffer
memcpy(tradeAccount, tmp, strlen(tmp));
// get orders loop...
Date Time Of Last Edit: 2025-02-25 12:37:13
[2025-02-25 06:29:11]
seandunaway - Posts: 398
that's really weird i've never seen an input value changing like that
when you step through it what are the tradeAccount and accountInput values changing to?
Date Time Of Last Edit: 2025-02-25 06:31:39
[2025-02-25 12:14:09]
LTSys - Posts: 68
The accountInput selected was always "Sim1" and assigned to tradeAccount (which I verified with a log message) but then tradeAccount would have a value of "Stop" or the path to the c++ notepad editor or some other value in memory. Playing around with the chart interval setting would get the function looping through orders again so I thought the issue was related to chart settings.
Date Time Of Last Edit: 2025-02-25 12:27:11
[2025-02-25 13:56:36]
sounds like your running off the stack frame or static space in your code
my guess is you're using globals instead of persistent variables and different instances of the code are overwriting the values
globals are shared across every instance of your study which is rarely a good idea
are you doing any weird pointer arithmetic (like tradeAccount++) or have dangling pointers?
edit: oh yeah also make sure your tradeAccount string is null terminated
Date Time Of Last Edit: 2025-02-25 14:31:11
[2025-02-26 17:01:18]
LTSys - Posts: 68
This was part of the issue as well. Allocating a buffer for tradeAccount and mem setting the buffer to null fixed it.
I've now taken an OOP approach and moved all logic into classes. The study is now very minimal with a single global variable pointer that points to a main class. If I put that pointer into a persistent variable it would only be visible to that study instance correct?
[2025-02-26 17:53:13]
correct!
here's a sierrachart snake game example showing similar, putting all variables into a struct (or class) and just persisting a pointer
attachmentsierrasnake.cpp - Attached On 2025-02-26 17:53:08 UTC - Size: 12.68 KB - 319 views
[2025-02-26 22:17:38]
LTSys - Posts: 68
Thanks, just the example I was looking for.
The game demo of what sierra chart can do was interesting.
I'm building a trade copier to copy to/from sierra chart to a bunch of other platforms.
https://lumens.llc/trade_copier_sierrachart.html
Date Time Of Last Edit: 2025-03-01 02:48:37
[2025-02-26 22:20:13]
looks great and i'm sure many people will find useful!
