Date/Time: Mon, 21 Apr 2025 18:16:45 +0000
value per tick not matching P/L
View Count: 146
[2025-02-20 18:36:09]
User449884 - Posts: 169
I have my value per tick for NQ at $5, but its seems to not be adding up properly on the trade window.
its seems to be confusing points with ticks. 35 pts profits and its calculating it as if it was 35 ticks with only 175$
and im not on micros, both symbol and trade current symbol are on NQ
[2025-02-20 20:21:02]
John - SC Support - Posts: 39381
We need images of what you are seeing so we can see exactly what the numbers are you are referring to. Please follow these instructions to get us images:
Also, you do not need to enter a "Trade and Current Quote Symbol" if the symbol is the same as the symbol of the chart.
[2025-02-20 23:31:39]
here are the screen shots. Ive taken a random trade on SIM to show the p/l
Private File
Private File
[2025-02-21 00:19:29]
Your "Tick Size" is set to "1.00", so points and ticks are the same thing. This is where the problem is.
Is there a reason you have the tick size set to 1.0?
[2025-02-21 05:17:46]
yes- i compress the NQ to 1.00 due to its volatily on the domS. Is there a way around this? a way to accurately see daily the real P/L?
[2025-02-21 14:49:09]
Sierra_Chart Engineering - Posts: 19289
Increase the Currency Value Per Tick by 4 times:
Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
Date Time Of Last Edit: 2025-02-21 14:49:22
[2025-02-21 16:30:56]
The above is one option, but if you are wanting to compress/consolidate the Market Depth data, then set your Tick Size back to 0.25 and use the following setting:
Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu)
You can also have the "Combine Increment in Ticks" apply to the "Recent Bid/Ask" if you are using those columns. Refer to the following setting for this:
Chart Settings: Apply Combine Increment in Ticks to Other Market Data Columns (Chart >> Chart Settings >> Market Depth menu)
