Date/Time: Mon, 21 Apr 2025 18:10:43 +0000
Option to only show values for last Vol profile - similar behavior to POC & others
View Count: 127
[2025-02-20 16:14:39]
JohnR - User831573 - Posts: 330
I have charts with longer time frames which then has multiple profiles. Each has the valley marker values at the EOD. Which is the same space used by the the next day's profile. Hopefully the image explains it well.
Is there an option to only have the values from Valleys and I presume others, on the screen only for the current / last one?
All help is appreciated.
JohnR
imageSCScreenCap_2025-02-20_11-01-53.jpg / V - Attached On 2025-02-20 16:10:46 UTC - Size: 179.53 KB - 28 views
[2025-02-20 16:42:07]
John - SC Support - Posts: 39380
There is not an option to only have the most recent profile showing the Peaks and Valleys.
But, given what you are showing in your image, you should change the Value Label "Horizontal Align" to be "Left" rather than "Right". This will move the labels to be before the next profile, instead of in it.
[2025-02-20 17:22:41]
Thanks for the time to answer - As always, there is a way to do everything in here -- SC --.
JohnR
