Date/Time: Tue, 25 Mar 2025 21:59:09 +0000
Market Depth Data for ZNH25_FUT_CME
View Count: 149
[2025-02-20 11:26:42]
User306018 - Posts: 6
I am trying to get 180 days of market depth data to load on my chart but even though I have set the Max Historical Market Depth Days to Load to 180 I cannot get it to load past about 90 days. I can go into the data folder and see the market depth data files for days all the way back to August, but I can only get the data from about 90 days to load on my chart. Is there something I am missing? Does this have to do with it being a different contract? Can I manually load the data files into the chart, forcing it? Thanks.
[2025-02-20 15:17:39]
John - SC Support - Posts: 38945
Make sure the following setting is set high enough for what you want:
Sierra Chart Server Settings: Maximum Historical Market Depth Days to Download (Global Settings >> Sierra Chart Server Settings >> General >> General)
But, if you are using a Continuous Futures Contract, then the system will not download data for previous contract. To get the historical market depth data for previous contract, you need to open a chart for that specific contract and then force the download for the historical market depth data for that contract. Then it will be available in the Continuous Futures Contract chart.
[2025-03-22 14:02:45]
Thanks John,
I am able to force download market depth data for beyond 180 days as you can see in the attached file. Does sierra chart create a file with nothing in it because when I run the continuous contract I do not see market depth for these respective dates. I am wondering if the files are just empty or is there a setting that I am missing. Even if I run the chart for the ZNZ24_FUT_CME symbol I am still not able to get the market depth data to load.
imagemarketdepthdatafiles.png / V - Attached On 2025-03-22 13:59:16 UTC - Size: 63.28 KB - 15 views
[2025-03-22 21:43:27]
Sierra_Chart Engineering - Posts: 18944
During the month of June 2024 the December 2024 contract was not active. This is why the market depth data files are small.
