Date/Time: Mon, 21 Apr 2025 17:52:47 +0000
file is not opening
View Count: 109
[2025-02-20 07:51:48] |
User446912 - Posts: 1 |
i have trouble to open this chartbook so please guide me step by step and in this file there is footprint file for eurusd
[2025-02-20 15:12:39] |
John - SC Support - Posts: 39380 |
If this is an old chartbook, then refer to the following: Chartbooks (Workspaces): Opening Older Chartbooks Otherwise, the file is corrupted for some reason. In this case, you would need to go to the backups to recover a copy. Refer to the following: Chartbooks (Workspaces): Accessing a Backup Chartbook File For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
