Date/Time: Mon, 21 Apr 2025 18:16:45 +0000
can use chart replay feature
View Count: 149
[2025-02-20 04:56:49] |
William Cline - Posts: 21 |
currently trying to use chart replay feature but when i press play in the chart replay control panel nothing happens https://www.sierrachart.com/image.php?Image=1740027273867.png |
[2025-02-20 14:48:40] |
Sierra_Chart Engineering - Posts: 19289 |
Uncheck Use Start Date-Time: Replaying Charts: Use Start Date-Time And instead scroll the chart back, to where you want to start the replay.: Replaying Charts: Basic Chart Replay Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-02-20 14:58:12
[2025-02-20 16:28:56] |
John - SC Support - Posts: 39381 |
Also, you cannot run a replay on daily historical data. Refer to the following: Replaying Charts: Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-23 05:44:48] |
currently trying to backtest starting from august 24th 2024, 5 minute tpo data looks extremely strange and i dont understand why https://www.sierrachart.com/image.php?Image=1740289310435.png |
[2025-02-24 16:41:10] |
Your TPOs are setup to be 5 minute TPO profiles with a 1 second sub-period. Is that what you want?
