Date/Time: Mon, 21 Apr 2025 17:43:43 +0000
Re: Sierra Chart:TRADE ISSUES
View Count: 107
[2025-02-19 18:34:18]
User705483 - Posts: 1
when I place a trade on my chart, I do not see the lines which usually come with my SL, Entry and TP.
Find attached of the situation below
imageScreenshot 2025-02-19 042857.png / V - Attached On 2025-02-19 18:34:03 UTC - Size: 173.75 KB - 29 views
[2025-02-19 18:36:55]
John - SC Support - Posts: 39380
The Position and Order Lines are set to display on the right side of your chart, and we see them there in the image you provided (right next to the Price Ladder).
If you want to move them to the left, then refer to the following setting and the three below it:
Chart Settings: Align Order Cancel (X) Button to Right (Chart >> Chart Settings >> Trading menu)
