Date/Time: Mon, 21 Apr 2025 18:16:44 +0000
Australian Dollars Futures Data
View Count: 89
[2025-02-19 18:27:46] |
Nitish Kakkar - Posts: 2 |
Hi, I used to trade ES before, but now i want to trade AUD/USD and AUD/JPY forex pair as i am based in Australia. For that I need Australian Futures data coming to my Sierra Chart Platform. I have tried to set my charts to 6AH25-CME but i am not getting anything. See Screenshot attached for TPO and DayVWAP charts. I am currently on service 11 package i think. I want to practise first trading using Australian Dollars Futures data, so i am happy with delayed data. I am currently using SC Data- All services. Can you please help me setting up my 6AH25-CME chart correctly. Date Time Of Last Edit: 2025-02-19 18:28:04
[2025-02-19 18:30:04] |
John - SC Support - Posts: 39381 |
First, reset the scales. For some reason the scales are expanded out and are even showing negative values. If the above does not fix it, then there must be a study that is causing the scales to be the way they are. We recommend duplicating the chart and then removing the studies one-by-one to find the culprit. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
