Date/Time: Fri, 25 Sep 2026 11:29:43 +0000
cannot connect to my apex evaluation account
View Count: 591
[2025-02-19 15:38:20]
User175124 - Posts: 6
2025-02-19 09:44:08.901 | Trade activity files set size: 141
2025-02-19 09:44:08.908 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-19 09:44:08.926 | Reading Internal Order ID file.
2025-02-19 09:44:08.927 | Reading Trade Orders file.
2025-02-19 09:44:08.927 | Reading Trade Positions file.
2025-02-19 09:44:08.927 | Reading Trade Account Data files.
2025-02-19 09:44:08.928 | Software version: 2695 64-bit
2025-02-19 09:44:08.928 | Primary Thread ID: 17444
2025-02-19 09:44:08.928 | Usage end date: 2025-02-28
2025-02-19 09:44:08.928 | Enabled for: Advanced Features 2.
2025-02-19 09:44:08.928 | Enabled for: Sierra Chart Historical Data Service.
2025-02-19 09:44:08.928 | Enabled for: Denali Real-Time Exchange Data Feed.
2025-02-19 09:44:08.928 | Enabled for: Delayed Denali Exchange Data Feed.
2025-02-19 09:44:08.928 | Enabled for exchange2: NYMEX
2025-02-19 09:44:08.928 | Allow Support for Sierra Chart Data Feeds is enabled.
2025-02-19 09:44:08.928 | Current selected Data/Trading service: Rithmic Direct - DTC
2025-02-19 09:44:08.928 | Custom symbol settings values: enabled
2025-02-19 09:44:08.928 | Chart Update Interval: 400
2025-02-19 09:44:08.928 | Intraday Data Storage Time Unit: 1
2025-02-19 09:44:08.928 | Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00)
2025-02-19 09:44:08.928 | 2025-02-19 14:44:08 Local computer time in UTC
2025-02-19 09:44:08.928 | 2025-02-19 09:44:08 Local computer time in SC Time Zone
2025-02-19 09:44:08.928 | 2025-02-19 14:44:09 Server time in UTC
2025-02-19 09:44:08.928 | Local computer UTC time and Server UTC time difference: 1 seconds.
2025-02-19 09:44:08.928 | Program path: C:\SierraChart\
2025-02-19 09:44:08.928 | Data Files path: C:\SierraChart\Data\
2025-02-19 09:44:08.928 | OS Version Number: 10.0
2025-02-19 09:44:08.928 | Locale Setting: C
2025-02-19 09:44:08.928 | DLLs: UserContributedStudies_64.dll
2025-02-19 09:44:08.928 | Allowed protected custom studies:
2025-02-19 09:44:08.928 | Crash reporter started: true
2025-02-19 09:44:08.940 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1.
2025-02-19 09:44:09.033 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:44:09.119 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2025-02-19 09:44:09.119 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0
2025-02-19 09:44:09.119 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130.
2025-02-19 09:44:09.239 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2025-02-19 09:44:09.239 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2025-02-19 09:44:09.645 | Received 5 login tokens.
2025-02-19 09:44:10.295 | Symbol settings MD5 received. Request ID: 1.
2025-02-19 09:44:10.295 | Symbol settings are up-to-date for rithmic_v2.trading.
2025-02-19 09:44:10.472 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-19 09:44:10.473 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-19 09:44:10.720 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call.
2025-02-19 09:44:10.720 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close.
2025-02-19 09:44:10.945 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side.
2025-02-19 09:44:10.945 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed.
2025-02-19 09:44:11.439 | Requested user files to download.
2025-02-19 09:44:13.441 |
2025-02-19 09:44:13.441 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:44:13.441 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:44:13.442 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:44:13.649 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:44:13.649 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:44:13.649 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:44:13.855 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:44:13.855 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:44:13.855 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:44:13.855 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:44:14.489 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:44:14.489 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:44:14.489 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:44:14.489 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:44:14.489 | Rithmic Direct - DTC | Failed connections: 1
2025-02-19 09:44:14.489 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:44:14.489 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:14.506 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:44:14.506 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:44:14.506 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:44:14.506 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:44:14.506 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:14.713 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:44:14.713 | DTC Client socket (1) | Closed.
2025-02-19 09:44:16.657 | Files to Open on Startup | File does not exist: C:\SierraChart\Data\ExampleChartbook.cht
2025-02-19 09:44:18.501 |
2025-02-19 09:44:18.501 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:44:18.501 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:44:18.501 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:44:18.502 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:44:18.502 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:44:18.502 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:44:18.705 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:44:18.705 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:44:18.705 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:44:18.705 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:44:19.320 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:44:19.320 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:44:19.320 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:44:19.320 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:44:19.320 | Rithmic Direct - DTC | Failed connections: 2
2025-02-19 09:44:19.320 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:44:19.320 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:19.333 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:44:19.333 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:44:19.333 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:44:19.333 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:44:19.333 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:19.537 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:44:19.537 | DTC Client socket (1) | Closed.
2025-02-19 09:44:23.328 |
2025-02-19 09:44:23.328 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:44:23.328 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:44:23.328 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:44:23.329 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:44:23.329 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:44:23.329 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:44:23.534 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:44:23.534 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:44:23.534 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:44:23.534 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:44:24.157 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:44:24.157 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:44:24.157 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:44:24.157 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:44:24.157 | Rithmic Direct - DTC | Failed connections: 3
2025-02-19 09:44:24.157 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:44:24.157 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:24.174 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:44:24.174 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:44:24.174 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:44:24.174 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:44:24.174 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:24.382 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:44:24.382 | DTC Client socket (1) | Closed.
2025-02-19 09:44:28.173 |
2025-02-19 09:44:28.173 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:44:28.173 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:44:28.173 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:44:28.174 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:44:28.174 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:44:28.174 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:44:28.380 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:44:28.380 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:44:28.380 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:44:28.380 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:44:29.008 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:44:29.008 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:44:29.008 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:44:29.008 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:44:29.008 | Rithmic Direct - DTC | Failed connections: 4
2025-02-19 09:44:29.008 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:44:29.008 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:29.017 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:44:29.017 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:44:29.017 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:44:29.017 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:44:29.017 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:29.223 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:44:29.223 | DTC Client socket (1) | Closed.
2025-02-19 09:44:33.016 |
2025-02-19 09:44:33.016 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:44:33.016 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:44:33.016 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:44:33.016 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:44:33.017 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:44:33.017 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:44:33.225 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:44:33.225 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:44:33.225 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:44:33.225 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:44:33.848 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:44:33.848 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:44:33.848 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:44:33.848 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:44:33.848 | Rithmic Direct - DTC | Failed connections: 5
2025-02-19 09:44:33.848 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:44:33.848 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:33.859 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:44:33.859 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:44:33.859 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:44:33.859 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:44:33.860 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:34.066 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:44:34.066 | DTC Client socket (1) | Closed.
2025-02-19 09:44:37.864 |
2025-02-19 09:44:37.864 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:44:37.864 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:44:37.864 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:44:37.864 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:44:37.864 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:44:37.864 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:44:38.070 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:44:38.070 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:44:38.070 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:44:38.070 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:44:38.696 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:44:38.696 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:44:38.696 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:44:38.696 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:44:38.696 | Rithmic Direct - DTC | Failed connections: 6
2025-02-19 09:44:38.696 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:44:38.696 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:38.704 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:44:38.705 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:44:38.705 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:44:38.705 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:44:38.705 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:38.912 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:44:38.912 | DTC Client socket (1) | Closed.
2025-02-19 09:44:42.703 |
2025-02-19 09:44:42.703 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:44:42.703 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:44:42.703 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:44:42.704 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:44:42.704 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:44:42.704 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:44:42.908 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:44:42.908 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:44:42.908 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:44:42.908 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:44:43.531 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:44:43.531 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:44:43.531 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:44:43.531 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:44:43.531 | Rithmic Direct - DTC | Failed connections: 7
2025-02-19 09:44:43.531 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:44:43.531 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:43.535 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:44:43.535 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:44:43.535 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:44:43.535 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:44:43.535 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:43.739 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:44:43.739 | DTC Client socket (1) | Closed.
2025-02-19 09:44:47.535 |
2025-02-19 09:44:47.535 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:44:47.535 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:44:47.535 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:44:47.535 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:44:47.536 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:44:47.536 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:44:47.738 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:44:47.738 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:44:47.738 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:44:47.738 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:44:48.350 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:44:48.350 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:44:48.350 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:44:48.350 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:44:48.350 | Rithmic Direct - DTC | Failed connections: 8
2025-02-19 09:44:48.350 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:44:48.350 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:48.360 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:44:48.360 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:44:48.360 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:44:48.360 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:44:48.360 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:48.563 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:44:48.563 | DTC Client socket (1) | Closed.
2025-02-19 09:44:52.362 |
2025-02-19 09:44:52.362 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:44:52.362 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:44:52.362 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:44:52.363 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:44:52.363 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:44:52.363 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:44:52.566 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:44:52.566 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:44:52.566 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:44:52.566 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:44:53.184 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:44:53.184 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:44:53.184 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:44:53.184 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:44:53.184 | Rithmic Direct - DTC | Failed connections: 9
2025-02-19 09:44:53.184 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:44:53.184 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:53.189 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:44:53.189 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:44:53.189 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:44:53.189 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:44:53.189 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:53.395 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:44:53.395 | DTC Client socket (1) | Closed.
2025-02-19 09:44:57.188 |
2025-02-19 09:44:57.188 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:44:57.188 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:44:57.188 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:44:57.188 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:44:57.188 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:44:57.188 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:44:57.394 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:44:57.394 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:44:57.394 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:44:57.394 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:44:58.017 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:44:58.017 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:44:58.017 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:44:58.017 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:44:58.017 | Rithmic Direct - DTC | Failed connections: 10
2025-02-19 09:44:58.017 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:44:58.017 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:58.032 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:44:58.032 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:44:58.032 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:44:58.032 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:44:58.032 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:44:58.239 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:44:58.239 | DTC Client socket (1) | Closed.
2025-02-19 09:45:02.031 |
2025-02-19 09:45:02.031 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:45:02.031 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:45:02.031 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:45:02.032 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:45:02.032 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:45:02.032 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:45:03.254 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:45:03.254 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:45:03.254 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:45:03.254 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:45:03.898 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:45:03.898 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:45:03.898 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:45:03.898 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:45:03.898 | Rithmic Direct - DTC | Failed connections: 11
2025-02-19 09:45:03.898 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:45:03.898 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:45:03.907 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:45:03.907 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:45:03.907 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:45:03.907 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:45:03.907 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:45:04.131 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:45:04.131 | DTC Client socket (1) | Closed.
2025-02-19 09:45:07.908 |
2025-02-19 09:45:07.908 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:45:07.908 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:45:07.908 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:45:07.908 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:45:07.908 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:45:07.908 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:45:08.115 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:45:08.115 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:45:08.115 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:45:08.115 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:45:08.740 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:45:08.740 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:45:08.740 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:45:08.740 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:45:08.740 | Rithmic Direct - DTC | Failed connections: 12
2025-02-19 09:45:08.740 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:45:08.740 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:45:08.751 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:45:08.751 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:45:08.751 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:45:08.751 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:45:08.751 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:45:08.958 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:45:08.958 | DTC Client socket (1) | Closed.
2025-02-19 09:45:12.751 |
2025-02-19 09:45:12.751 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:45:12.751 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:45:12.751 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:45:12.751 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:45:12.751 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:45:12.751 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:45:12.958 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:45:12.958 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:45:12.958 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:45:12.958 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:45:13.581 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:45:13.581 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:45:13.581 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:45:13.581 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:45:13.581 | Rithmic Direct - DTC | Failed connections: 13
2025-02-19 09:45:13.581 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:45:13.581 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:45:13.596 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:45:13.596 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:45:13.596 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:45:13.596 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:45:13.596 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:45:13.807 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:45:13.807 | DTC Client socket (1) | Closed.
2025-02-19 09:45:17.597 |
2025-02-19 09:45:17.597 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:45:17.597 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:45:17.597 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:45:17.598 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:45:17.598 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:45:17.598 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:45:17.801 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:45:17.801 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:45:17.801 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:45:17.801 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:45:33.570 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:45:33.570 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:45:33.570 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:45:33.570 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:45:33.570 | Rithmic Direct - DTC | Failed connections: 14
2025-02-19 09:45:33.570 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:45:33.570 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:45:33.580 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:45:33.581 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:45:33.581 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:45:33.581 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:45:33.581 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:45:33.785 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:45:33.785 | DTC Client socket (1) | Closed.
2025-02-19 09:45:37.580 |
2025-02-19 09:45:37.580 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:45:37.580 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:45:37.580 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:45:37.581 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:45:37.581 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:45:37.581 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:45:37.793 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:45:37.793 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:45:37.793 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:45:37.793 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:45:38.439 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:45:38.439 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:45:38.439 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:45:38.439 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:45:38.439 | Rithmic Direct - DTC | Failed connections: 15
2025-02-19 09:45:38.439 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:45:38.439 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:45:38.454 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:45:38.454 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:45:38.454 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:45:38.454 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:45:38.454 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:45:38.664 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:45:38.664 | DTC Client socket (1) | Closed.
2025-02-19 09:45:42.456 |
2025-02-19 09:45:42.456 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:45:42.456 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:45:42.456 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:45:42.457 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:45:42.457 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:45:42.457 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:45:42.663 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:45:42.663 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:45:42.663 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:45:42.663 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:45:43.287 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:45:43.287 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:45:43.287 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:45:43.287 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:45:43.288 | Rithmic Direct - DTC | Failed connections: 16
2025-02-19 09:45:43.288 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:45:43.288 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:45:43.302 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:45:43.302 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:45:43.302 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:45:43.302 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:45:43.302 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:45:43.509 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:45:43.509 | DTC Client socket (1) | Closed.
2025-02-19 09:45:47.297 |
2025-02-19 09:45:47.297 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:45:47.297 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:45:47.297 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:45:47.298 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:45:47.298 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:45:47.298 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:45:47.504 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:45:47.504 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:45:47.504 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:45:47.504 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:45:48.125 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:45:48.125 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:45:48.125 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:45:48.125 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:45:48.125 | Rithmic Direct - DTC | Failed connections: 17
2025-02-19 09:45:48.125 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:45:48.125 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:45:48.143 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:45:48.143 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:45:48.143 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:45:48.143 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:45:48.143 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:45:48.349 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:45:48.349 | DTC Client socket (1) | Closed.
2025-02-19 09:45:52.142 |
2025-02-19 09:45:52.142 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:45:52.142 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:45:52.142 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:45:52.143 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:45:52.143 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:45:52.143 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:45:52.348 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:45:52.348 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:45:52.348 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:45:52.348 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:45:52.970 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:45:52.970 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:45:52.970 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:45:52.970 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:45:52.970 | Rithmic Direct - DTC | Failed connections: 18
2025-02-19 09:45:52.970 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:45:52.970 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:45:52.987 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:45:52.987 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:45:52.987 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:45:52.987 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:45:52.987 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:45:53.193 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:45:53.193 | DTC Client socket (1) | Closed.
2025-02-19 09:45:56.985 |
2025-02-19 09:45:56.985 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:45:56.985 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:45:56.985 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:45:56.985 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:45:56.985 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:45:56.985 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:45:57.192 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:45:57.192 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:45:57.192 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:45:57.192 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:46:11.300 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:46:11.300 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:46:11.300 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:46:11.300 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:46:11.300 | Rithmic Direct - DTC | Failed connections: 19
2025-02-19 09:46:11.300 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:46:11.300 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:11.315 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:46:11.315 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:46:11.315 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:46:11.315 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:46:11.315 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:11.523 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:46:11.523 | DTC Client socket (1) | Closed.
2025-02-19 09:46:15.316 |
2025-02-19 09:46:15.316 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:46:15.316 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:46:15.316 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:46:15.317 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:46:15.317 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:46:15.317 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:46:15.548 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:46:15.548 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:46:15.548 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:46:15.548 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:46:16.176 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:46:16.176 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:46:16.176 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:46:16.176 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:46:16.176 | Rithmic Direct - DTC | Failed connections: 20
2025-02-19 09:46:16.176 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:46:16.176 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:16.190 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:46:16.190 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:46:16.190 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:46:16.190 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:46:16.190 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:16.398 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:46:16.398 | DTC Client socket (1) | Closed.
2025-02-19 09:46:20.189 |
2025-02-19 09:46:20.189 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:46:20.189 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:46:20.189 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:46:20.189 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:46:20.189 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:46:20.189 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:46:20.399 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:46:20.399 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:46:20.399 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:46:20.399 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:46:21.025 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:46:21.025 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:46:21.025 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:46:21.025 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:46:21.025 | Rithmic Direct - DTC | Failed connections: 21
2025-02-19 09:46:21.025 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:46:21.025 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:21.034 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:46:21.034 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:46:21.034 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:46:21.034 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:46:21.034 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:21.244 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:46:21.244 | DTC Client socket (1) | Closed.
2025-02-19 09:46:25.034 |
2025-02-19 09:46:25.034 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:46:25.034 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:46:25.034 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:46:25.035 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:46:25.035 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:46:25.035 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:46:25.240 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:46:25.240 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:46:25.240 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:46:25.240 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:46:25.865 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:46:25.865 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:46:25.865 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:46:25.865 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:46:25.865 | Rithmic Direct - DTC | Failed connections: 22
2025-02-19 09:46:25.865 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:46:25.865 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:25.875 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:46:25.876 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:46:25.876 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:46:25.876 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:25.876 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:46:26.082 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:46:26.082 | DTC Client socket (1) | Closed.
2025-02-19 09:46:29.880 |
2025-02-19 09:46:29.880 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:46:29.880 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:46:29.880 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:46:29.880 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:46:29.880 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:46:29.880 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:46:30.086 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:46:30.086 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:46:30.086 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:46:30.086 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:46:30.710 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:46:30.710 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:46:30.710 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:46:30.710 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:46:30.710 | Rithmic Direct - DTC | Failed connections: 23
2025-02-19 09:46:30.710 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:46:30.710 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:30.720 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:46:30.720 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:46:30.720 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:46:30.720 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:46:30.720 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:30.928 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:46:30.928 | DTC Client socket (1) | Closed.
2025-02-19 09:46:34.719 |
2025-02-19 09:46:34.719 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:46:34.719 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:46:34.719 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:46:34.719 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:46:34.719 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:46:34.719 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:46:34.921 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:46:34.921 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:46:34.921 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:46:34.921 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:46:35.537 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:46:35.537 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:46:35.537 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:46:35.537 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:46:35.537 | Rithmic Direct - DTC | Failed connections: 24
2025-02-19 09:46:35.537 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:46:35.537 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:35.549 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:46:35.549 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:46:35.549 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:46:35.549 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:46:35.549 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:35.754 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:46:35.754 | DTC Client socket (1) | Closed.
2025-02-19 09:46:39.547 |
2025-02-19 09:46:39.547 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:46:39.547 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:46:39.547 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:46:39.548 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:46:39.548 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:46:39.548 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:46:39.753 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:46:39.753 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:46:39.753 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:46:39.753 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:46:40.379 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:46:40.379 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:46:40.379 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:46:40.379 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:46:40.379 | Rithmic Direct - DTC | Failed connections: 25
2025-02-19 09:46:40.379 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:46:40.379 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:40.392 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:46:40.392 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:46:40.392 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:46:40.392 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:46:40.392 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:40.598 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:46:40.598 | DTC Client socket (1) | Closed.
2025-02-19 09:46:44.395 |
2025-02-19 09:46:44.395 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:46:44.395 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:46:44.395 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:46:44.395 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:46:44.395 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:46:44.395 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:46:44.602 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:46:44.602 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:46:44.602 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:46:44.602 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:46:45.225 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:46:45.225 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:46:45.225 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:46:45.225 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:46:45.225 | Rithmic Direct - DTC | Failed connections: 26
2025-02-19 09:46:45.225 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:46:45.225 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:45.237 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:46:45.237 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:46:45.237 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:46:45.237 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:46:45.237 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:45.444 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:46:45.444 | DTC Client socket (1) | Closed.
2025-02-19 09:46:49.235 |
2025-02-19 09:46:49.235 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:46:49.235 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:46:49.235 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:46:49.235 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:46:49.235 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:46:49.235 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:46:49.437 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:46:49.437 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:46:49.437 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:46:49.437 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:46:50.055 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:46:50.055 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:46:50.055 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:46:50.055 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:46:50.055 | Rithmic Direct - DTC | Failed connections: 27
2025-02-19 09:46:50.055 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:46:50.055 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:50.064 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:46:50.064 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:46:50.064 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:46:50.064 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:46:50.064 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:50.268 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:46:50.268 | DTC Client socket (1) | Closed.
2025-02-19 09:46:54.065 |
2025-02-19 09:46:54.065 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:46:54.065 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:46:54.065 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:46:54.066 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:46:54.066 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:46:54.066 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:46:54.269 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:46:54.269 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:46:54.269 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:46:54.269 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:46:54.880 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:46:54.880 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:46:54.880 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:46:54.880 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:46:54.880 | Rithmic Direct - DTC | Failed connections: 28
2025-02-19 09:46:54.880 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:46:54.880 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:54.891 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:46:54.891 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:46:54.892 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:46:54.892 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:46:54.892 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:55.096 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:46:55.096 | DTC Client socket (1) | Closed.
2025-02-19 09:46:58.893 |
2025-02-19 09:46:58.893 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:46:58.893 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:46:58.893 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:46:58.894 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:46:58.894 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:46:58.894 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:46:59.099 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:46:59.099 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:46:59.099 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:46:59.099 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:46:59.723 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:46:59.723 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:46:59.723 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:46:59.723 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:46:59.723 | Rithmic Direct - DTC | Failed connections: 29
2025-02-19 09:46:59.723 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:46:59.723 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:59.737 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:46:59.737 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:46:59.737 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:46:59.737 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:46:59.737 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:46:59.943 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:46:59.943 | DTC Client socket (1) | Closed.
2025-02-19 09:47:03.736 |
2025-02-19 09:47:03.737 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:47:03.737 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:47:03.737 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:47:03.737 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:47:03.737 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:47:03.737 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:47:03.942 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:47:03.942 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:47:03.942 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:47:03.942 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:47:04.579 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:47:04.579 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:47:04.579 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:47:04.579 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:47:04.579 | Rithmic Direct - DTC | Failed connections: 30
2025-02-19 09:47:04.579 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:47:04.579 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:04.596 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:47:04.596 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:47:04.596 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:47:04.596 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:47:04.596 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:04.804 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:47:04.804 | DTC Client socket (1) | Closed.
2025-02-19 09:47:08.595 |
2025-02-19 09:47:08.595 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:47:08.595 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:47:08.595 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:47:08.596 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:47:08.596 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:47:08.596 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:47:08.798 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:47:08.798 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:47:08.798 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:47:08.798 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:47:09.415 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:47:09.415 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:47:09.415 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:47:09.415 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:47:09.415 | Rithmic Direct - DTC | Failed connections: 31
2025-02-19 09:47:09.415 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:47:09.415 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:09.426 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:47:09.427 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:47:09.427 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:47:09.427 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:47:09.427 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:09.630 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:47:09.630 | DTC Client socket (1) | Closed.
2025-02-19 09:47:13.422 |
2025-02-19 09:47:13.422 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:47:13.422 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:47:13.423 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:47:13.423 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:47:13.423 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:47:13.423 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:47:13.625 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:47:13.625 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:47:13.625 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:47:13.625 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:47:14.238 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:47:14.238 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:47:14.238 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:47:14.238 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:47:14.238 | Rithmic Direct - DTC | Failed connections: 32
2025-02-19 09:47:14.238 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:47:14.238 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:14.251 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:47:14.251 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:47:14.251 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:47:14.252 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:47:14.252 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:14.457 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:47:14.457 | DTC Client socket (1) | Closed.
2025-02-19 09:47:18.253 |
2025-02-19 09:47:18.253 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:47:18.253 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:47:18.253 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:47:18.253 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:47:18.253 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:47:18.253 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:47:18.460 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:47:18.460 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:47:18.460 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:47:18.460 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:47:19.081 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:47:19.081 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:47:19.081 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:47:19.081 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:47:19.081 | Rithmic Direct - DTC | Failed connections: 33
2025-02-19 09:47:19.081 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:47:19.081 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:19.096 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:47:19.096 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:47:19.096 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:47:19.096 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:19.096 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:47:19.303 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:47:19.303 | DTC Client socket (1) | Closed.
2025-02-19 09:47:23.095 |
2025-02-19 09:47:23.095 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:47:23.095 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:47:23.095 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:47:23.096 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:47:23.096 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:47:23.096 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:47:23.304 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:47:23.304 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:47:23.304 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:47:23.304 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:47:23.935 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:47:23.935 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:47:23.935 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:47:23.935 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:47:23.935 | Rithmic Direct - DTC | Failed connections: 34
2025-02-19 09:47:23.935 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:47:23.935 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:23.942 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:47:23.942 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:47:23.942 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:47:23.942 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:47:23.942 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:24.149 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:47:24.149 | DTC Client socket (1) | Closed.
2025-02-19 09:47:27.942 |
2025-02-19 09:47:27.942 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:47:27.942 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:47:27.942 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:47:27.942 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:47:27.943 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:47:27.943 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:47:28.148 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:47:28.148 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:47:28.149 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:47:28.149 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:47:28.772 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:47:28.772 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:47:28.772 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:47:28.772 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:47:28.772 | Rithmic Direct - DTC | Failed connections: 35
2025-02-19 09:47:28.772 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:47:28.772 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:28.783 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:47:28.783 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:47:28.783 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:47:28.783 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:47:28.783 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:28.990 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:47:28.990 | DTC Client socket (1) | Closed.
2025-02-19 09:47:32.782 |
2025-02-19 09:47:32.782 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:47:32.782 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:47:32.782 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:47:32.783 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:47:32.783 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:47:32.783 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:47:32.988 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:47:32.988 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:47:32.988 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:47:32.988 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:47:33.615 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:47:33.615 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:47:33.615 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:47:33.615 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:47:33.615 | Rithmic Direct - DTC | Failed connections: 36
2025-02-19 09:47:33.615 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:47:33.615 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:33.629 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:47:33.629 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:47:33.629 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:47:33.629 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:47:33.629 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:33.835 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:47:33.835 | DTC Client socket (1) | Closed.
2025-02-19 09:47:37.625 |
2025-02-19 09:47:37.625 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:47:37.625 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:47:37.625 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:47:37.626 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:47:37.626 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:47:37.626 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:47:37.833 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:47:37.833 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:47:37.833 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:47:37.833 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:47:38.456 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:47:38.456 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:47:38.456 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:47:38.456 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:47:38.456 | Rithmic Direct - DTC | Failed connections: 37
2025-02-19 09:47:38.456 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:47:38.456 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:38.470 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:47:38.471 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:47:38.471 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:47:38.471 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:47:38.471 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:38.677 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:47:38.677 | DTC Client socket (1) | Closed.
2025-02-19 09:47:42.471 |
2025-02-19 09:47:42.471 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:47:42.471 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:47:42.471 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:47:42.471 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:47:42.471 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:47:42.471 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:47:42.677 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:47:42.677 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:47:42.677 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:47:42.677 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:47:43.302 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:47:43.302 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:47:43.302 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:47:43.302 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:47:43.302 | Rithmic Direct - DTC | Failed connections: 38
2025-02-19 09:47:43.302 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:47:43.302 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:43.316 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:47:43.316 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:47:43.316 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:47:43.316 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:47:43.316 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:43.523 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:47:43.523 | DTC Client socket (1) | Closed.
2025-02-19 09:47:47.314 |
2025-02-19 09:47:47.314 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:47:47.314 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:47:47.314 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:47:47.315 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:47:47.315 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:47:47.315 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:47:47.518 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:47:47.518 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:47:47.518 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:47:47.518 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:47:48.132 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:47:48.132 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:47:48.132 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:47:48.132 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:47:48.132 | Rithmic Direct - DTC | Failed connections: 39
2025-02-19 09:47:48.132 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:47:48.132 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:48.141 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:47:48.141 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:47:48.141 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:47:48.141 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:47:48.142 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:48.348 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:47:48.348 | DTC Client socket (1) | Closed.
2025-02-19 09:47:52.144 |
2025-02-19 09:47:52.144 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 09:47:52.144 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 09:47:52.144 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 09:47:52.144 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:47:52.144 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:47:52.144 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 09:47:52.357 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 09:47:52.357 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 09:47:52.357 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 09:47:52.357 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 09:47:52.993 | Rithmic Direct - DTC | Received logon response.
2025-02-19 09:47:52.993 | Rithmic Direct - DTC | Server Name: .
2025-02-19 09:47:52.993 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:47:52.993 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 09:47:52.993 | Rithmic Direct - DTC | Failed connections: 40
2025-02-19 09:47:52.993 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 09:47:52.993 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:53.002 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 09:47:53.002 | DTC Client socket (1) | CloseSocket call.
2025-02-19 09:47:53.002 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 09:47:53.002 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:47:53.002 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:53.212 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 09:47:53.213 | DTC Client socket (1) | Closed.
2025-02-19 09:47:54.822 | DTC Client socket (0) | CloseSocket call.
2025-02-19 09:47:54.822 | Rithmic Direct - DTC | Disconnected.
2025-02-19 09:47:54.841 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 2.
2025-02-19 09:47:54.841 | Current selected Data/Trading service: Teton CME Order Routing
2025-02-19 09:47:54.874 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 09:47:56.065 | Symbol settings MD5 received. Request ID: 2.
2025-02-19 09:47:56.065 | Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 3.
2025-02-19 09:47:56.861 |
2025-02-19 09:47:56.862 | Teton CME Order Routing | Firm: IronBeam
2025-02-19 09:47:56.863 | Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085
2025-02-19 09:47:56.879 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 09:47:56.879 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 09:47:56.879 | DTC Client socket (1) | Connecting to IP: 208.185.224.130.
2025-02-19 09:47:57.089 | Teton CME Order Routing | Network connection to server complete.
2025-02-19 09:47:57.089 | Teton CME Order Routing | Starting socket receive thread.
2025-02-19 09:47:57.089 | Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none
2025-02-19 09:47:57.725 | Teton CME Order Routing | Setting DTC encoding to Binary VLS
2025-02-19 09:47:57.725 | Teton CME Order Routing | Sending logon request message.
2025-02-19 09:47:57.737 | Symbol settings received. Request ID: 3.
2025-02-19 09:47:58.001 | Teton CME Order Routing | Received logon response.
2025-02-19 09:47:58.001 | Teton CME Order Routing | Server Name: SC DTC Server. Build=51528.
2025-02-19 09:47:58.001 | Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:47:58.001 | Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading.
2025-02-19 09:47:58.001 | Teton CME Order Routing | Trading is supported.
2025-02-19 09:47:58.001 | Teton CME Order Routing | Order cancel and replace is supported.
2025-02-19 09:47:58.001 | Teton CME Order Routing | OCO Orders supported.
2025-02-19 09:47:58.001 | Teton CME Order Routing | Bracket Orders supported.
2025-02-19 09:47:58.001 | Teton CME Order Routing | MarketDepthIsSupported: 1
2025-02-19 09:47:58.001 | Teton CME Order Routing | Connected to server complete.
2025-02-19 09:47:58.001 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-02-19 09:47:58.001 | Teton CME Order Routing | Performing query for most recent Order Activity Date-Time.
2025-02-19 09:47:58.002 | Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2025-02-19 14:04:52.018597
2025-02-19 09:47:58.211 | Updated verified funded futures trading account ending date to: 2025-03-21 14:47:58
2025-02-19 09:47:58.239 | Teton CME Order Routing | Received final trade activity snapshot. Count=2. TradeAccount=23149668
2025-02-19 09:48:01.344 | CLJ25_FUT_CME/MCLJ25_FUT_CME [CBV] #1 | Reloading chart.
2025-02-19 09:48:01.374 | Starting DelayedDownloadMonitoringTimer
2025-02-19 09:48:01.374 | Starting HDTimeoutTimer
2025-02-19 09:48:01.374 | Added historical Intraday data request for CLJ25_FUT_CME to the queue.
2025-02-19 09:48:01.375 | Triggering next historical data download in queue.
2025-02-19 09:48:01.499 | CLJ25_FUT_CME/MCLJ25_FUT_CME [CBV] #1 | Waiting for historical downloads to complete with the IDs: 1,
2025-02-19 09:48:01.518 | CLJ25_FUT_CME [CBV] 2000 Volume #3 | Reloading chart.
2025-02-19 09:48:01.579 | CLJ25_FUT_CME [CBV] 2000 Volume #3 | Waiting for historical downloads to complete with the IDs: 1,
2025-02-19 09:48:01.709 | CLJ25_FUT_CME/MCLJ25_FUT_CME [CBV] 700 Volume #4 | Reloading chart.
2025-02-19 09:48:01.772 | CLJ25_FUT_CME/MCLJ25_FUT_CME [CBV] 700 Volume #4 | Waiting for historical downloads to complete with the IDs: 1,
2025-02-19 09:48:01.797 | CLJ25_FUT_CME #5 | Reloading chart.
2025-02-19 09:48:01.830 | CLJ25_FUT_CME [CBV] 5 Min #6 | Reloading chart.
2025-02-19 09:48:01.840 | CLJ25_FUT_CME [CBV] 5 Min #6 | Waiting for historical downloads to complete with the IDs: 1,
2025-02-19 09:48:01.979 | CLJ25_FUT_CME/MCLJ25_FUT_CME Renko 7t #7 | Reloading chart.
2025-02-19 09:48:01.993 | Mapping CLH25_FUT_CME to CLH25. Service code: nymex
2025-02-19 09:48:01.993 | Using symbol data fast lookup vector
2025-02-19 09:48:01.993 | Denali Data Feed | Starting real-time market data updates for: CLH25_FUT_CME (CLH25). ID: 1 Service code: nymex
2025-02-19 09:48:01.994 | Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 443
2025-02-19 09:48:01.994 | DTC Client socket (2) | Creating socket.
2025-02-19 09:48:01.994 | DTC Client socket (2) | New receive buffer size: 0
2025-02-19 09:48:01.994 | DTC Client socket (2) | Connecting to IP: 64.152.155.17.
2025-02-19 09:48:01.995 | Denali Data Feed | Requesting security definition data for: CLH25_FUT_CME (CLH25). ID: 1
2025-02-19 09:48:01.995 | Mapping GCG25_FUT_CME to GCG25. Service code: comex
2025-02-19 09:48:01.995 | Delayed Data Feed | Starting real-time market data updates for: GCG25_FUT_CME (GCG25). ID: 2 Service code: comex
2025-02-19 09:48:01.996 | Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043
2025-02-19 09:48:01.996 | DTC Client socket (3) | Creating socket.
2025-02-19 09:48:01.996 | DTC Client socket (3) | New receive buffer size: 0
2025-02-19 09:48:01.996 | DTC Client socket (3) | Connecting to IP: 64.152.155.17.
2025-02-19 09:48:01.997 | Delayed Data Feed | Requesting security definition data for: GCG25_FUT_CME (GCG25). ID: 2
2025-02-19 09:48:01.997 | Mapping GCJ25_FUT_CME to GCJ25. Service code: comex
2025-02-19 09:48:01.997 | Delayed Data Feed | Starting real-time market data updates for: GCJ25_FUT_CME (GCJ25). ID: 3 Service code: comex
2025-02-19 09:48:01.997 | Delayed Data Feed | Requesting security definition data for: GCJ25_FUT_CME (GCJ25). ID: 3
2025-02-19 09:48:01.997 | Mapping CLJ25_FUT_CME to CLJ25. Service code: nymex
2025-02-19 09:48:01.997 | Denali Data Feed | Starting real-time market data updates for: CLJ25_FUT_CME (CLJ25). ID: 4 Service code: nymex
2025-02-19 09:48:01.997 | Denali Data Feed | Requesting security definition data for: CLJ25_FUT_CME (CLJ25). ID: 4
2025-02-19 09:48:02.001 | Delaying start of download for CLJ25_FUT_CME.
2025-02-19 09:48:02.003 | CLJ25_FUT_CME #5 | StartDateTimeForLoadingOrderFills: 2024-02-13 00:00:00
2025-02-19 09:48:02.003 | CLJ25_FUT_CME #5 | Chart data loading complete.
2025-02-19 09:48:02.021 | CLJ25_FUT_CME/MCLJ25_FUT_CME Renko 7t #7 | StartDateTimeForLoadingOrderFills: 2024-02-13 00:00:00
2025-02-19 09:48:02.032 | CLJ25_FUT_CME/MCLJ25_FUT_CME Renko 7t #7 | Chart data loading complete.
2025-02-19 09:48:02.200 | Denali Data Feed | Network connection to server complete.
2025-02-19 09:48:02.200 | Denali Data Feed | Starting socket receive thread.
2025-02-19 09:48:02.200 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-02-19 09:48:02.202 | Delayed Data Feed | Network connection to server complete.
2025-02-19 09:48:02.202 | Delayed Data Feed | Starting socket receive thread.
2025-02-19 09:48:02.202 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-02-19 09:48:02.205 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLH25_FUT_CME
2025-02-19 09:48:02.205 | Teton CME Order Routing | Setting external service identifier for symbol CLH25_FUT_CME to 37014
2025-02-19 09:48:02.205 | Teton CME Order Routing | Received security definition for symbol CLH25_FUT_CME
2025-02-19 09:48:02.207 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLJ25_FUT_CME
2025-02-19 09:48:02.207 | Teton CME Order Routing | Setting external service identifier for symbol CLJ25_FUT_CME to 625061
2025-02-19 09:48:02.207 | Teton CME Order Routing | Received security definition for symbol CLJ25_FUT_CME
2025-02-19 09:48:02.377 | Mapping MCLJ25_FUT_CME to MCLJ25. Service code: nymex
2025-02-19 09:48:02.377 | Denali Data Feed | Starting real-time market data updates for: MCLJ25_FUT_CME (MCLJ25). ID: 5 Service code: nymex
2025-02-19 09:48:02.377 | Denali Data Feed | Requesting security definition data for: MCLJ25_FUT_CME (MCLJ25). ID: 5
2025-02-19 09:48:02.422 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-02-19 09:48:02.422 | Denali Data Feed | Sending logon request message.
2025-02-19 09:48:02.422 | Delayed Data Feed | Setting DTC encoding to Binary VLS
2025-02-19 09:48:02.422 | Delayed Data Feed | Sending logon request message.
2025-02-19 09:48:02.587 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MCLJ25_FUT_CME
2025-02-19 09:48:02.587 | Teton CME Order Routing | Setting external service identifier for symbol MCLJ25_FUT_CME to 42025716
2025-02-19 09:48:02.587 | Teton CME Order Routing | Received security definition for symbol MCLJ25_FUT_CME
2025-02-19 09:48:02.954 | Delayed Data Feed | Received logon response.
2025-02-19 09:48:02.954 | Delayed Data Feed | Server Name: SC Realtime Server.
2025-02-19 09:48:02.954 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:48:02.954 | Delayed Data Feed | Successfully connected.
2025-02-19 09:48:02.954 | Delayed Data Feed | Trading is not supported.
2025-02-19 09:48:02.954 | Delayed Data Feed | MarketDepthIsSupported: 1
2025-02-19 09:48:02.954 | Delayed Data Feed | Restarting real-time data updates for symbol: GCG25_FUT_CME -> GCG25
2025-02-19 09:48:02.954 | Delayed Data Feed | Restarting real-time data updates for symbol: GCJ25_FUT_CME -> GCJ25
2025-02-19 09:48:02.985 | Denali Data Feed | Received logon response.
2025-02-19 09:48:02.985 | Denali Data Feed | Server Name: SC Realtime Server.
2025-02-19 09:48:02.985 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-02-19 09:48:02.985 | Denali Data Feed | Successfully connected.
2025-02-19 09:48:02.985 | Denali Data Feed | Trading is not supported.
2025-02-19 09:48:02.985 | Denali Data Feed | MarketDepthIsSupported: 1
2025-02-19 09:48:02.985 | Denali Data Feed | Restarting real-time data updates for symbol: CLH25_FUT_CME -> CLH25
2025-02-19 09:48:02.985 | Denali Data Feed | Restarting real-time data updates for symbol: CLJ25_FUT_CME -> CLJ25
2025-02-19 09:48:02.985 | Denali Data Feed | Restarting real-time data updates for symbol: MCLJ25_FUT_CME -> MCLJ25
2025-02-19 09:48:03.003 | Requesting market depth updates for: CLJ25_FUT_CME if supported. NumLevels=100
2025-02-19 09:48:03.265 | Delayed Data Feed | Setting external service identifier for symbol GCG25_FUT_CME to 1551
2025-02-19 09:48:03.265 | Delayed Data Feed | Received security definition for symbol GCG25_FUT_CME
2025-02-19 09:48:03.265 | Delayed Data Feed | Setting external service identifier for symbol GCJ25_FUT_CME to 19604
2025-02-19 09:48:03.265 | Delayed Data Feed | Received security definition for symbol GCJ25_FUT_CME
2025-02-19 09:48:03.299 | Denali Data Feed | Clearing market depth for CLJ25_FUT_CME
2025-02-19 09:48:03.299 | Denali Data Feed | Setting external service identifier for symbol CLH25_FUT_CME to 37014
2025-02-19 09:48:03.299 | Denali Data Feed | Received security definition for symbol CLH25_FUT_CME
2025-02-19 09:48:03.299 | Denali Data Feed | Setting external service identifier for symbol CLJ25_FUT_CME to 625061
2025-02-19 09:48:03.299 | Denali Data Feed | Received security definition for symbol CLJ25_FUT_CME
2025-02-19 09:48:03.299 | Denali Data Feed | Setting external service identifier for symbol MCLJ25_FUT_CME to 42025716
2025-02-19 09:48:03.299 | Denali Data Feed | Received security definition for symbol MCLJ25_FUT_CME
2025-02-19 09:48:08.363 | HD Request # 1 | Downloading Intraday chart data for CLJ25_FUT_CME to the file CLJ25_FUT_CME.scid. Service: nymex
2025-02-19 09:48:08.363 | HD Request # 1 | Download start date-time: 2025-02-19 09:06:06.000000. File last date-time: 2025-02-19 09:06:06.000000
2025-02-19 09:48:08.363 | HD Request # 1 | Using server: ds28.sierracharts.com port 10149
2025-02-19 09:48:08.364 | Socket (4) | Creating socket.
2025-02-19 09:48:08.364 | Socket (4) | New receive buffer size: 0
2025-02-19 09:48:08.364 | Socket (4) | Connecting to IP: 67.214.125.5.
2025-02-19 09:48:08.788 | HD Request # 1 | Setting DTC encoding to Binary VLS
2025-02-19 09:48:08.788 | HD Request # 1 | Sending historical data logon request message.
2025-02-19 09:48:09.045 | HD Request # 1 | Requesting Intraday data. Start date-time: 2025-02-19 09:06:06. Record interval: 1. Symbol: CLJ25
2025-02-19 09:48:09.255 | HD Request # 1 | Decompressing data.
2025-02-19 09:48:09.480 | HD Request # 1 | Receiving Intraday data for CLJ25_FUT_CME starting at 2025-02-19 09:06:06.681000
2025-02-19 09:48:09.481 | Socket (4) | CloseSocket call.
2025-02-19 09:48:09.481 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-02-19 09:48:09.481 | Historical data download thread signaled to stop.
2025-02-19 09:48:09.481 | HD Request # 1 | Timestamp of first Intraday data file record written: 2025-02-19 09:06:06.681000.
2025-02-19 09:48:09.481 | HD Request # 1 | Received 1280 Intraday data records from 2025-02-19 09:06:06.681000 to 2025-02-19 09:48:06.340000 (42.0 minutes. Delay: 3.1 seconds) and wrote 1280 records for CLJ25_FUT_CME
2025-02-19 09:48:09.487 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2025-02-19 14:48:06.340000
2025-02-19 09:48:09.487 | Added 2 Time and Sales records to Intraday data file for CLJ25_FUT_CME after download.
2025-02-19 09:48:09.487 | HD Request # 1 | Completion time: 1s.
2025-02-19 09:48:09.487 | HD Request # 1 | Intraday data download complete for CLJ25_FUT_CME. Unique request ID: 1
2025-02-19 09:48:09.487 | Removing historical data download ID 1.
2025-02-19 09:48:09.487 | Real-time Intraday chart data file updates started for CLJ25_FUT_CME
2025-02-19 09:48:09.490 | Opened cached Intraday file: C:\SierraChart\Data\CLJ25_FUT_CME.scid. Thread ID: 17444
2025-02-19 09:48:09.491 | Intraday chart data file opened for CLJ25_FUT_CME
2025-02-19 09:48:09.491 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2025-02-19 09:48:09.491 | No download requests in the queue to start downloads for.
2025-02-19 09:48:09.548 | CLJ25_FUT_CME [CBV] 5 Min #6 | Download is complete for all contract months in chart. Proceeding with data load.
2025-02-19 09:48:09.548 | CLJ25_FUT_CME [CBV] 5 Min #6 | Reloading chart.
2025-02-19 09:48:09.639 | CLJ25_FUT_CME [CBV] 5 Min #6 | StartDateTimeForLoadingOrderFills: 2024-02-13 00:00:00
2025-02-19 09:48:09.643 | CLJ25_FUT_CME [CBV] 5 Min #6 | Chart data loading complete.
2025-02-19 09:48:09.643 | CLJ25_FUT_CME [CBV] 2000 Volume #3 | Download is complete for all contract months in chart. Proceeding with data load.
2025-02-19 09:48:09.644 | CLJ25_FUT_CME [CBV] 2000 Volume #3 | Reloading chart.
2025-02-19 09:48:09.693 | Socket (4) | Socket gracefully closed by remote side.
2025-02-19 09:48:09.693 | Socket (4) | Closed.
2025-02-19 09:48:10.237 | CLJ25_FUT_CME/MCLJ25_FUT_CME [CBV] 700 Volume #4 | Download is complete for all contract months in chart. Proceeding with data load.
2025-02-19 09:48:10.237 | CLJ25_FUT_CME/MCLJ25_FUT_CME [CBV] 700 Volume #4 | Reloading chart.
2025-02-19 09:48:10.815 | CLJ25_FUT_CME [CBV] 2000 Volume #3 | Chart data loading complete.
2025-02-19 09:48:10.817 | CLJ25_FUT_CME/MCLJ25_FUT_CME [CBV] #1 | Download is complete for all contract months in chart. Proceeding with data load.
2025-02-19 09:48:10.818 | CLJ25_FUT_CME/MCLJ25_FUT_CME [CBV] #1 | Reloading chart.
2025-02-19 09:48:12.263 | CLJ25_FUT_CME/MCLJ25_FUT_CME [CBV] 700 Volume #4 | StartDateTimeForLoadingOrderFills: 2024-02-13 00:00:00
2025-02-19 09:48:12.380 | CLJ25_FUT_CME/MCLJ25_FUT_CME [CBV] 700 Volume #4 | Chart data loading complete.
2025-02-19 09:48:12.496 | CLJ25_FUT_CME [CBV] 5 Min #6 | Reloading chart.
2025-02-19 09:48:12.597 | CLJ25_FUT_CME [CBV] 2000 Volume #3 | Reloading chart.
2025-02-19 09:48:13.245 | CLJ25_FUT_CME [CBV] 5 Min #6 | StartDateTimeForLoadingOrderFills: 2024-02-13 00:00:00
2025-02-19 09:48:13.249 | CLJ25_FUT_CME [CBV] 5 Min #6 | Chart data loading complete.
2025-02-19 09:48:13.258 | CLJ25_FUT_CME/MCLJ25_FUT_CME [CBV] 700 Volume #4 | Reloading chart.
2025-02-19 09:48:13.909 | CLJ25_FUT_CME [CBV] 2000 Volume #3 | Chart data loading complete.
2025-02-19 09:48:13.912 | CLJ25_FUT_CME/MCLJ25_FUT_CME [CBV] #1 | Reloading chart.
2025-02-19 09:48:15.703 | CLJ25_FUT_CME/MCLJ25_FUT_CME [CBV] #1 | Chart data loading complete.
2025-02-19 09:48:15.704 | CLJ25_FUT_CME/MCLJ25_FUT_CME [CBV] 700 Volume #4 | StartDateTimeForLoadingOrderFills: 2024-02-13 00:00:00
2025-02-19 09:48:15.818 | CLJ25_FUT_CME/MCLJ25_FUT_CME [CBV] 700 Volume #4 | Chart data loading complete.
2025-02-19 09:48:18.203 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request.
2025-02-19 09:48:19.144 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2025-03-19"}. Success=true
2025-02-19 09:52:04.977 | CLJ25_FUT_CME[M] #5 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-19 09:52:04.977 | CLJ25_FUT_CME [CBV][M] 5 Min #6 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-19 09:52:04.988 | CLJ25_FUT_CME/MCLJ25_FUT_CME[M] Renko 7t #7 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-19 09:52:05.222 | CLJ25_FUT_CME/MCLJ25_FUT_CME [CBV][M] 700 Volume #4 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-19 10:33:39.413 | Teton CME Order Routing | Waiting for socket receive thread to end
2025-02-19 10:33:39.413 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:33:39.413 | DTC Client socket (1) | Max send buffers used during socket life: 4
2025-02-19 10:33:39.413 | DTC Client socket (1) | Max send buffer size during socket life: 246
2025-02-19 10:33:39.413 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:33:39.413 | Denali Data Feed | Waiting for socket receive thread to end
2025-02-19 10:33:39.413 | DTC Client socket (2) | CloseSocket call.
2025-02-19 10:33:39.413 | DTC Client socket (2) | Max send buffers used during socket life: 3
2025-02-19 10:33:39.413 | DTC Client socket (2) | Max send buffer size during socket life: 258
2025-02-19 10:33:39.413 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-02-19 10:33:39.413 | Denali Data Feed | Disconnected from the server.
2025-02-19 10:33:39.413 | Delayed Data Feed | Waiting for socket receive thread to end
2025-02-19 10:33:39.414 | DTC Client socket (3) | CloseSocket call.
2025-02-19 10:33:39.414 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-02-19 10:33:39.414 | Delayed Data Feed | Disconnected from the server.
2025-02-19 10:33:39.414 | Teton CME Order Routing | Disconnected.
2025-02-19 10:33:39.420 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-19 10:33:39.457 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 4.
2025-02-19 10:33:39.457 | Current selected Data/Trading service: Rithmic Direct - DTC
2025-02-19 10:33:39.620 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-02-19 10:33:39.620 | DTC Client socket (3) | Closed.
2025-02-19 10:33:39.624 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:33:39.624 | DTC Client socket (1) | Closed.
2025-02-19 10:33:39.857 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-02-19 10:33:39.857 | DTC Client socket (2) | Closed.
2025-02-19 10:33:40.507 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2025-02-19 10:33:40.508 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0
2025-02-19 10:33:40.508 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130.
2025-02-19 10:33:41.674 | Symbol settings MD5 received. Request ID: 4.
2025-02-19 10:33:41.674 | Requested symbol settings for service code rithmic_v2.trading. Request ID: 5.
2025-02-19 10:33:41.882 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-19 10:33:41.883 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-19 10:33:42.126 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call.
2025-02-19 10:33:42.126 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close.
2025-02-19 10:33:42.353 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side.
2025-02-19 10:33:42.353 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed.
2025-02-19 10:33:43.298 | Symbol settings received. Request ID: 5.
2025-02-19 10:33:44.456 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:33:44.465 | CLJ5.NYMEX[M] #5 | Reloading chart.
2025-02-19 10:33:44.469 | Mapping CLJ5.NYMEX to CLJ25. Service code: nymex
2025-02-19 10:33:44.469 | Added historical Intraday data request for CLJ5.NYMEX to the queue.
2025-02-19 10:33:44.469 | Intraday data recording state for symbol CLJ5.NYMEX is set to download 'Pending'.
2025-02-19 10:33:44.469 | Triggering next historical data download in queue.
2025-02-19 10:33:44.469 | HD Request # 2 | Downloading Intraday chart data for CLJ5.NYMEX to the file CLJ5.NYMEX.scid. Service: nymex
2025-02-19 10:33:44.469 | HD Request # 2 | Download start date-time: 2025-02-19 09:14:28.000000. File last date-time: 2025-02-19 09:14:28.980000
2025-02-19 10:33:44.470 | HD Request # 2 | Using server: ds32.sierracharts.com port 10150
2025-02-19 10:33:44.470 | Socket (1) | Creating socket.
2025-02-19 10:33:44.470 | Socket (1) | New receive buffer size: 0
2025-02-19 10:33:44.470 | Socket (1) | Connecting to IP: 67.214.125.3.
2025-02-19 10:33:44.507 | CLJ5.NYMEX[M] #5 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-19 10:33:44.507 | CLJ5.NYMEX[M] #5 | Chart data loading complete.
2025-02-19 10:33:44.537 | CLJ5.NYMEX/MCLJ5.NYMEX [CBV][M] 700 Volume #4 | Reloading chart.
2025-02-19 10:33:44.686 | Historical Intraday data request, start 00:00:00.000, for CLJ5.NYMEX is discarded because a matching download is in progress and the new one is not for earlier data.
2025-02-19 10:33:44.747 | CLJ5.NYMEX/MCLJ5.NYMEX [CBV][M] 700 Volume #4 | Waiting for historical downloads to complete with the IDs: 2,
2025-02-19 10:33:44.750 | CLJ5.NYMEX [CBV][M] 5 Min #6 | Reloading chart.
2025-02-19 10:33:44.759 | CLJ5.NYMEX [CBV][M] 5 Min #6 | Waiting for historical downloads to complete with the IDs: 2,
2025-02-19 10:33:44.760 | CLJ5.NYMEX/MCLJ5.NYMEX[M] Renko 7t #7 | Reloading chart.
2025-02-19 10:33:44.764 | CLJ5.NYMEX [CBV][M] 2000 Volume #3 | Reloading chart.
2025-02-19 10:33:44.826 | CLJ5.NYMEX [CBV][M] 2000 Volume #3 | Waiting for historical downloads to complete with the IDs: 2,
2025-02-19 10:33:44.827 | CLJ5.NYMEX/MCLJ5.NYMEX[M] Renko 7t #7 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-19 10:33:44.832 | CLJ5.NYMEX/MCLJ5.NYMEX[M] Renko 7t #7 | Chart data loading complete.
2025-02-19 10:33:44.840 | CLJ5.NYMEX/MCLJ5.NYMEX [CBV][M] #1 | Reloading chart.
2025-02-19 10:33:44.905 | HD Request # 2 | Setting DTC encoding to Binary VLS
2025-02-19 10:33:44.905 | HD Request # 2 | Sending historical data logon request message.
2025-02-19 10:33:45.172 | HD Request # 2 | Requesting Intraday data. Start date-time: 2025-02-19 09:14:28. Record interval: 1. Symbol: CLJ25
2025-02-19 10:33:45.181 | CLJ5.NYMEX/MCLJ5.NYMEX [CBV][M] #1 | Waiting for historical downloads to complete with the IDs: 2,
2025-02-19 10:33:45.188 | Mapping CLH5.NYMEX to CLH25. Service code: nymex
2025-02-19 10:33:45.190 | Mapping MCLJ5.NYMEX to MCLJ25. Service code: nymex
2025-02-19 10:33:45.385 | HD Request # 2 | Decompressing data.
2025-02-19 10:33:45.828 | HD Request # 2 | Receiving Intraday data for CLJ5.NYMEX starting at 2025-02-19 09:14:28.980000
2025-02-19 10:33:45.829 | Socket (1) | CloseSocket call.
2025-02-19 10:33:45.829 | Socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:33:45.829 | Historical data download thread signaled to stop.
2025-02-19 10:33:45.829 | HD Request # 2 | Timestamp of first Intraday data file record written: 2025-02-19 09:14:28.980000.
2025-02-19 10:33:45.829 | HD Request # 2 | Received 2453 Intraday data records from 2025-02-19 09:14:28.980000 to 2025-02-19 10:33:42.375000 (79.2 minutes. Delay: 3.5 seconds) and wrote 2453 records for CLJ5.NYMEX
2025-02-19 10:33:45.829 | HD Request # 2 | Completion time: 1s.
2025-02-19 10:33:45.829 | HD Request # 2 | Intraday data download complete for CLJ5.NYMEX. Unique request ID: 2
2025-02-19 10:33:45.829 | Removing historical data download ID 2.
2025-02-19 10:33:45.829 | Real-time Intraday chart data file updates started for CLJ5.NYMEX
2025-02-19 10:33:45.835 | Opened cached Intraday file: C:\SierraChart\Data\CLJ5.NYMEX.scid. Thread ID: 17444
2025-02-19 10:33:45.835 | Intraday chart data file opened for CLJ5.NYMEX
2025-02-19 10:33:45.835 | HD Request # 2 | Enabling Intraday chart updating for symbol.
2025-02-19 10:33:45.835 | No download requests in the queue to start downloads for.
2025-02-19 10:33:45.835 | Historical data for CLJ5.NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-02-19 10:33:45.954 | CLJ5.NYMEX [CBV][M] 5 Min #6 | Download is complete for all contract months in chart. Proceeding with data load.
2025-02-19 10:33:45.954 | CLJ5.NYMEX [CBV][M] 5 Min #6 | Reloading chart.
2025-02-19 10:33:46.039 | CLJ5.NYMEX [CBV][M] 2000 Volume #3 | Download is complete for all contract months in chart. Proceeding with data load.
2025-02-19 10:33:46.039 | CLJ5.NYMEX [CBV][M] 2000 Volume #3 | Reloading chart.
2025-02-19 10:33:46.044 | Socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:33:46.044 | Socket (1) | Closed.
2025-02-19 10:33:46.617 | CLJ5.NYMEX [CBV][M] 5 Min #6 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-19 10:33:46.622 | CLJ5.NYMEX [CBV][M] 5 Min #6 | Chart data loading complete.
2025-02-19 10:33:46.633 | CLJ5.NYMEX/MCLJ5.NYMEX [CBV][M] #1 | Download is complete for all contract months in chart. Proceeding with data load.
2025-02-19 10:33:46.633 | CLJ5.NYMEX/MCLJ5.NYMEX [CBV][M] #1 | Reloading chart.
2025-02-19 10:33:48.039 | CLJ5.NYMEX [CBV][M] 2000 Volume #3 | Chart data loading complete.
2025-02-19 10:33:48.043 | CLJ5.NYMEX/MCLJ5.NYMEX [CBV][M] 700 Volume #4 | Download is complete for all contract months in chart. Proceeding with data load.
2025-02-19 10:33:48.043 | CLJ5.NYMEX/MCLJ5.NYMEX [CBV][M] 700 Volume #4 | Reloading chart.
2025-02-19 10:33:48.653 | CLJ5.NYMEX [CBV][M] 5 Min #6 | Reloading chart.
2025-02-19 10:33:48.749 | CLJ5.NYMEX [CBV][M] 2000 Volume #3 | Reloading chart.
2025-02-19 10:33:49.488 | CLJ5.NYMEX [CBV][M] 5 Min #6 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-19 10:33:49.493 | CLJ5.NYMEX [CBV][M] 5 Min #6 | Chart data loading complete.
2025-02-19 10:33:49.514 | CLJ5.NYMEX/MCLJ5.NYMEX [CBV][M] #1 | Reloading chart.
2025-02-19 10:33:51.119 | CLJ5.NYMEX [CBV][M] 2000 Volume #3 | Chart data loading complete.
2025-02-19 10:33:51.267 | CLJ5.NYMEX/MCLJ5.NYMEX [CBV][M] #1 | Chart data loading complete.
2025-02-19 10:33:51.268 | CLJ5.NYMEX/MCLJ5.NYMEX [CBV][M] 700 Volume #4 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-19 10:33:51.375 | CLJ5.NYMEX/MCLJ5.NYMEX [CBV][M] 700 Volume #4 | Chart data loading complete.
2025-02-19 10:33:51.481 | CLJ5.NYMEX/MCLJ5.NYMEX [CBV][M] 700 Volume #4 | Reloading chart.
2025-02-19 10:33:52.117 |
2025-02-19 10:33:52.117 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:33:52.117 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:33:52.118 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:33:52.328 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:33:52.328 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:33:52.328 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:33:52.537 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:33:52.537 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:33:52.537 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:33:52.537 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:33:53.171 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:33:53.171 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:33:53.171 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:33:53.171 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:33:53.171 | Rithmic Direct - DTC | Failed connections: 1
2025-02-19 10:33:53.171 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:33:53.171 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:33:53.185 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:33:53.186 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:33:53.186 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:33:53.186 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:33:53.186 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:33:53.395 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:33:53.396 | DTC Client socket (1) | Closed.
2025-02-19 10:33:53.518 | CLJ5.NYMEX/MCLJ5.NYMEX [CBV][M] 700 Volume #4 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-19 10:33:53.623 | CLJ5.NYMEX/MCLJ5.NYMEX [CBV][M] 700 Volume #4 | Chart data loading complete.
2025-02-19 10:33:57.207 |
2025-02-19 10:33:57.207 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:33:57.207 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:33:57.207 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:33:57.208 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:33:57.208 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:33:57.208 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:33:57.411 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:33:57.411 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:33:57.411 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:33:57.411 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:33:58.025 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:33:58.025 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:33:58.025 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:33:58.025 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:33:58.025 | Rithmic Direct - DTC | Failed connections: 2
2025-02-19 10:33:58.025 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:33:58.025 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:33:58.032 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:33:58.032 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:33:58.032 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:33:58.032 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:33:58.032 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:33:58.237 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:33:58.237 | DTC Client socket (1) | Closed.
2025-02-19 10:34:02.036 |
2025-02-19 10:34:02.036 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:34:02.036 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:34:02.036 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:34:02.036 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:34:02.036 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:34:02.036 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:34:02.246 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:34:02.246 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:34:02.246 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:34:02.246 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:34:02.893 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:34:02.893 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:34:02.893 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:34:02.893 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:34:02.893 | Rithmic Direct - DTC | Failed connections: 3
2025-02-19 10:34:02.893 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:34:02.893 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:34:02.908 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:34:02.908 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:34:02.908 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:34:02.908 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:34:02.908 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:34:03.123 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:34:03.123 | DTC Client socket (1) | Closed.
2025-02-19 10:34:06.908 |
2025-02-19 10:34:06.908 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:34:06.908 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:34:06.908 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:34:06.908 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:34:06.908 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:34:06.908 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:34:07.117 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:34:07.117 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:34:07.117 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:34:07.117 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:34:07.774 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:34:07.774 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:34:07.774 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:34:07.774 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:34:07.774 | Rithmic Direct - DTC | Failed connections: 4
2025-02-19 10:34:07.774 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:34:07.774 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:34:07.788 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:34:07.788 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:34:07.788 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:34:07.788 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:34:07.788 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:34:07.998 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:34:07.998 | DTC Client socket (1) | Closed.
2025-02-19 10:34:11.782 |
2025-02-19 10:34:11.782 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:34:11.782 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:34:11.782 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:34:11.783 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:34:11.783 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:34:11.783 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:34:11.989 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:34:11.989 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:34:11.989 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:34:11.989 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:34:12.642 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:34:12.642 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:34:12.642 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:34:12.642 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:34:12.642 | Rithmic Direct - DTC | Failed connections: 5
2025-02-19 10:34:12.642 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:34:12.642 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:34:12.657 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:34:12.657 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:34:12.657 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:34:12.657 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:34:12.657 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:34:12.863 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:34:12.863 | DTC Client socket (1) | Closed.
2025-02-19 10:34:16.660 |
2025-02-19 10:34:16.660 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:34:16.660 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:34:16.660 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:34:16.661 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:34:16.661 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:34:16.661 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:34:16.863 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:34:16.863 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:34:16.863 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:34:16.863 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:34:17.480 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:34:17.480 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:34:17.480 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:34:17.480 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:34:17.480 | Rithmic Direct - DTC | Failed connections: 6
2025-02-19 10:34:17.480 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:34:17.480 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:34:17.485 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:34:17.485 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:34:17.485 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:34:17.485 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:34:17.485 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:34:17.688 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:34:17.688 | DTC Client socket (1) | Closed.
2025-02-19 10:34:21.578 |
2025-02-19 10:34:21.578 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:34:21.578 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:34:21.578 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:34:21.578 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:34:21.578 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:34:21.578 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:34:41.565 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2.
2025-02-19 10:34:41.565 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | New receive buffer size: 0
2025-02-19 10:34:41.565 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Connecting to IP: 216.66.0.130.
2025-02-19 10:34:42.620 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-19 10:34:42.620 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:34:42.620 | Rithmic Direct - DTC | Failed connections: 7
2025-02-19 10:34:42.620 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:34:42.620 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:34:42.620 | DTC Client socket (1) | Closed.
2025-02-19 10:34:42.628 | DTC Client socket (0) | CloseSocket call.
2025-02-19 10:34:42.628 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:34:42.628 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:34:42.921 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-19 10:34:42.922 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-19 10:34:43.173 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | CloseSocket call.
2025-02-19 10:34:43.173 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close.
2025-02-19 10:34:43.397 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Socket gracefully closed by remote side.
2025-02-19 10:34:43.397 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Closed.
2025-02-19 10:34:46.626 |
2025-02-19 10:34:46.626 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:34:46.626 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:34:46.626 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:34:46.627 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:34:46.627 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:34:46.627 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:34:46.830 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:34:46.830 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:34:46.830 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:34:46.830 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:34:47.447 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:34:47.447 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:34:47.447 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:34:47.447 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:34:47.447 | Rithmic Direct - DTC | Failed connections: 8
2025-02-19 10:34:47.447 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:34:47.447 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:34:47.453 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:34:47.454 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:34:47.454 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:34:47.454 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:34:47.454 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:34:47.658 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:34:47.658 | DTC Client socket (1) | Closed.
2025-02-19 10:34:51.455 |
2025-02-19 10:34:51.455 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:34:51.455 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:34:51.455 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:34:51.455 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:34:51.455 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:34:51.455 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:34:51.658 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:34:51.658 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:34:51.659 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:34:51.659 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:34:52.273 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:34:52.273 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:34:52.273 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:34:52.273 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:34:52.273 | Rithmic Direct - DTC | Failed connections: 9
2025-02-19 10:34:52.273 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:34:52.273 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:34:52.281 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:34:52.281 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:34:52.281 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:34:52.281 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:34:52.281 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:34:52.485 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:34:52.485 | DTC Client socket (1) | Closed.
2025-02-19 10:34:56.284 |
2025-02-19 10:34:56.284 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:34:56.284 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:34:56.284 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:34:56.285 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:34:56.285 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:34:56.285 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:34:56.516 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:34:56.516 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:34:56.516 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:34:56.516 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:34:57.143 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:34:57.143 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:34:57.143 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:34:57.143 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:34:57.143 | Rithmic Direct - DTC | Failed connections: 10
2025-02-19 10:34:57.143 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:34:57.143 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:34:57.156 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:34:57.156 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:34:57.156 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:34:57.156 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:34:57.156 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:34:57.364 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:34:57.364 | DTC Client socket (1) | Closed.
2025-02-19 10:35:01.158 |
2025-02-19 10:35:01.158 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:35:01.158 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:35:01.158 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:35:01.158 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:35:01.158 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:35:01.158 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:35:01.398 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:35:01.398 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:35:01.398 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:35:01.398 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:35:02.023 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:35:02.023 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:35:02.023 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:35:02.023 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:35:02.023 | Rithmic Direct - DTC | Failed connections: 11
2025-02-19 10:35:02.023 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:35:02.023 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:02.034 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:35:02.034 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:35:02.034 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:35:02.034 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:35:02.034 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:02.242 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:35:02.242 | DTC Client socket (1) | Closed.
2025-02-19 10:35:06.032 |
2025-02-19 10:35:06.032 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:35:06.032 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:35:06.032 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:35:06.033 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:35:06.033 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:35:06.033 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:35:06.267 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:35:06.267 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:35:06.267 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:35:06.267 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:35:06.892 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:35:06.892 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:35:06.892 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:35:06.892 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:35:06.892 | Rithmic Direct - DTC | Failed connections: 12
2025-02-19 10:35:06.892 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:35:06.892 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:06.911 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:35:06.911 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:35:06.911 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:35:06.911 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:35:06.911 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:07.118 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:35:07.118 | DTC Client socket (1) | Closed.
2025-02-19 10:35:10.910 |
2025-02-19 10:35:10.911 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:35:10.911 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:35:10.911 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:35:10.911 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:35:10.911 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:35:10.911 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:35:11.140 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:35:11.140 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:35:11.140 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:35:11.140 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:35:11.755 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:35:11.755 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:35:11.755 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:35:11.755 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:35:11.755 | Rithmic Direct - DTC | Failed connections: 13
2025-02-19 10:35:11.755 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:35:11.755 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:11.775 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:35:11.775 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:35:11.776 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:35:11.776 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:35:11.776 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:11.979 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:35:11.980 | DTC Client socket (1) | Closed.
2025-02-19 10:35:15.769 |
2025-02-19 10:35:15.769 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:35:15.769 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:35:15.769 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:35:15.769 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:35:15.769 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:35:15.769 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:35:15.972 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:35:15.972 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:35:15.972 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:35:15.972 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:35:16.589 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:35:16.589 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:35:16.589 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:35:16.589 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:35:16.589 | Rithmic Direct - DTC | Failed connections: 14
2025-02-19 10:35:16.589 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:35:16.589 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:16.595 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:35:16.596 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:35:16.596 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:35:16.596 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:35:16.596 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:16.800 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:35:16.800 | DTC Client socket (1) | Closed.
2025-02-19 10:35:20.596 |
2025-02-19 10:35:20.596 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:35:20.596 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:35:20.596 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:35:20.596 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:35:20.596 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:35:20.597 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:35:20.799 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:35:20.799 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:35:20.799 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:35:20.799 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:35:21.411 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:35:21.411 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:35:21.411 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:35:21.411 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:35:21.411 | Rithmic Direct - DTC | Failed connections: 15
2025-02-19 10:35:21.411 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:35:21.411 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:21.425 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:35:21.425 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:35:21.425 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:35:21.425 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:35:21.425 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:21.629 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:35:21.629 | DTC Client socket (1) | Closed.
2025-02-19 10:35:25.423 |
2025-02-19 10:35:25.424 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:35:25.424 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:35:25.424 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:35:25.424 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:35:25.424 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:35:25.424 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:35:25.633 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:35:25.633 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:35:25.633 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:35:25.633 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:35:26.290 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:35:26.290 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:35:26.290 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:35:26.290 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:35:26.290 | Rithmic Direct - DTC | Failed connections: 16
2025-02-19 10:35:26.290 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:35:26.290 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:26.297 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:35:26.297 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:35:26.297 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:35:26.297 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:35:26.297 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:26.507 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:35:26.507 | DTC Client socket (1) | Closed.
2025-02-19 10:35:30.298 |
2025-02-19 10:35:30.298 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:35:30.298 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:35:30.298 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:35:30.299 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:35:30.299 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:35:30.299 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:35:30.505 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:35:30.505 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:35:30.505 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:35:30.505 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:35:31.133 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:35:31.133 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:35:31.133 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:35:31.133 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:35:31.133 | Rithmic Direct - DTC | Failed connections: 17
2025-02-19 10:35:31.133 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:35:31.133 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:31.141 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:35:31.142 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:35:31.142 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:35:31.142 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:35:31.142 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:31.360 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:35:31.360 | DTC Client socket (1) | Closed.
2025-02-19 10:35:35.141 |
2025-02-19 10:35:35.141 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:35:35.141 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:35:35.141 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:35:35.142 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:35:35.142 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:35:35.142 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:35:35.349 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:35:35.349 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:35:35.349 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:35:35.349 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:35:35.969 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:35:35.969 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:35:35.969 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:35:35.969 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:35:35.969 | Rithmic Direct - DTC | Failed connections: 18
2025-02-19 10:35:35.969 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:35:35.969 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:35.985 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:35:35.985 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:35:35.985 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:35:35.985 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:35:35.985 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:36.189 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:35:36.189 | DTC Client socket (1) | Closed.
2025-02-19 10:35:39.986 |
2025-02-19 10:35:39.986 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:35:39.986 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:35:39.986 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:35:39.986 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:35:39.986 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:35:39.986 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:35:40.195 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:35:40.195 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:35:40.195 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:35:40.195 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:35:40.826 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:35:40.826 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:35:40.826 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:35:40.826 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:35:40.826 | Rithmic Direct - DTC | Failed connections: 19
2025-02-19 10:35:40.826 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:35:40.826 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:40.829 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:35:40.829 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:35:40.829 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:35:40.829 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:35:40.829 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:41.039 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:35:41.039 | DTC Client socket (1) | Closed.
2025-02-19 10:35:44.860 |
2025-02-19 10:35:44.861 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:35:44.861 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:35:44.861 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:35:44.861 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:35:44.861 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:35:44.861 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:35:45.064 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:35:45.064 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:35:45.064 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:35:45.064 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:35:45.679 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:35:45.679 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:35:45.679 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:35:45.679 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:35:45.679 | Rithmic Direct - DTC | Failed connections: 20
2025-02-19 10:35:45.679 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:35:45.679 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:45.690 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:35:45.690 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:35:45.690 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:35:45.690 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:35:45.690 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:45.894 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:35:45.894 | DTC Client socket (1) | Closed.
2025-02-19 10:35:49.691 |
2025-02-19 10:35:49.691 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:35:49.691 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:35:49.691 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:35:49.691 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:35:49.691 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:35:49.691 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:35:49.898 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:35:49.898 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:35:49.898 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:35:49.898 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:35:50.548 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:35:50.548 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:35:50.548 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:35:50.548 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:35:50.548 | Rithmic Direct - DTC | Failed connections: 21
2025-02-19 10:35:50.548 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:35:50.548 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:50.563 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:35:50.563 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:35:50.563 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:35:50.563 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:35:50.563 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:50.770 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:35:50.770 | DTC Client socket (1) | Closed.
2025-02-19 10:35:54.567 |
2025-02-19 10:35:54.567 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:35:54.567 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:35:54.567 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:35:54.567 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:35:54.567 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:35:54.567 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:35:54.779 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:35:54.779 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:35:54.779 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:35:54.779 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:35:55.419 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:35:55.419 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:35:55.419 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:35:55.419 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:35:55.419 | Rithmic Direct - DTC | Failed connections: 22
2025-02-19 10:35:55.419 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:35:55.419 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:55.424 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:35:55.424 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:35:55.424 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:35:55.424 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:35:55.424 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:35:55.634 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:35:55.634 | DTC Client socket (1) | Closed.
2025-02-19 10:35:59.425 |
2025-02-19 10:35:59.425 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:35:59.425 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:35:59.425 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:35:59.425 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:35:59.426 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:35:59.426 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:35:59.634 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:35:59.634 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:35:59.634 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:35:59.634 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:36:00.299 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:36:00.299 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:36:00.299 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:36:00.299 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:36:00.299 | Rithmic Direct - DTC | Failed connections: 23
2025-02-19 10:36:00.299 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:36:00.299 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:00.315 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:36:00.315 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:36:00.315 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:36:00.315 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:36:00.315 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:00.530 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:36:00.530 | DTC Client socket (1) | Closed.
2025-02-19 10:36:04.312 |
2025-02-19 10:36:04.313 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:36:04.313 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:36:04.313 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:36:04.313 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:36:04.313 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:36:04.313 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:36:04.520 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:36:04.520 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:36:04.520 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:36:04.520 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:36:05.173 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:36:05.173 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:36:05.173 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:36:05.173 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:36:05.173 | Rithmic Direct - DTC | Failed connections: 24
2025-02-19 10:36:05.173 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:36:05.173 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:05.189 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:36:05.190 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:36:05.190 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:36:05.190 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:36:05.190 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:05.397 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:36:05.397 | DTC Client socket (1) | Closed.
2025-02-19 10:36:09.189 |
2025-02-19 10:36:09.189 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:36:09.189 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:36:09.189 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:36:09.189 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:36:09.190 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:36:09.190 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:36:09.395 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:36:09.395 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:36:09.395 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:36:09.395 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:36:10.050 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:36:10.050 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:36:10.050 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:36:10.050 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:36:10.050 | Rithmic Direct - DTC | Failed connections: 25
2025-02-19 10:36:10.050 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:36:10.050 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:10.064 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:36:10.064 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:36:10.064 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:36:10.064 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:36:10.064 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:10.271 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:36:10.271 | DTC Client socket (1) | Closed.
2025-02-19 10:36:14.065 |
2025-02-19 10:36:14.065 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:36:14.065 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:36:14.065 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:36:14.065 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:36:14.066 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:36:14.066 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:36:14.269 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:36:14.269 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:36:14.269 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:36:14.269 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:36:14.922 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:36:14.922 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:36:14.922 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:36:14.922 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:36:14.922 | Rithmic Direct - DTC | Failed connections: 26
2025-02-19 10:36:14.922 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:36:14.922 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:14.925 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:36:14.925 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:36:14.925 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:36:14.925 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:36:14.925 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:15.129 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:36:15.129 | DTC Client socket (1) | Closed.
2025-02-19 10:36:18.922 |
2025-02-19 10:36:18.922 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:36:18.922 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:36:18.922 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:36:18.922 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:36:18.922 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:36:18.922 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:36:19.127 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:36:19.127 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:36:19.127 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:36:19.127 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:36:19.809 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:36:19.809 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:36:19.809 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:36:19.809 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:36:19.809 | Rithmic Direct - DTC | Failed connections: 27
2025-02-19 10:36:19.809 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:36:19.809 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:19.813 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:36:19.813 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:36:19.813 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:36:19.813 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:36:19.813 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:20.020 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:36:20.020 | DTC Client socket (1) | Closed.
2025-02-19 10:36:23.816 |
2025-02-19 10:36:23.816 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:36:23.816 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:36:23.816 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:36:23.816 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:36:23.816 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:36:23.816 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:36:24.022 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:36:24.022 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:36:24.022 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:36:24.022 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:36:24.671 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:36:24.671 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:36:24.671 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:36:24.671 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:36:24.671 | Rithmic Direct - DTC | Failed connections: 28
2025-02-19 10:36:24.671 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:36:24.671 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:24.675 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:36:24.675 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:36:24.675 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:36:24.675 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:36:24.675 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:24.884 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:36:24.884 | DTC Client socket (1) | Closed.
2025-02-19 10:36:28.672 |
2025-02-19 10:36:28.672 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:36:28.672 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:36:28.672 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:36:28.673 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:36:28.673 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:36:28.673 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:36:28.880 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:36:28.880 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:36:28.881 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:36:28.881 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:36:29.545 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:36:29.545 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:36:29.545 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:36:29.545 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:36:29.545 | Rithmic Direct - DTC | Failed connections: 29
2025-02-19 10:36:29.545 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:36:29.545 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:29.550 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:36:29.550 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:36:29.550 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:36:29.550 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:36:29.550 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:29.758 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:36:29.758 | DTC Client socket (1) | Closed.
2025-02-19 10:36:33.550 |
2025-02-19 10:36:33.550 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:36:33.550 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:36:33.550 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:36:33.550 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:36:33.551 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:36:33.551 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:36:33.755 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:36:33.755 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:36:33.755 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:36:33.755 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:36:34.371 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:36:34.371 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:36:34.371 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:36:34.371 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:36:34.371 | Rithmic Direct - DTC | Failed connections: 30
2025-02-19 10:36:34.371 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:36:34.371 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:34.375 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:36:34.375 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:36:34.375 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:36:34.375 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:36:34.375 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:34.579 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:36:34.579 | DTC Client socket (1) | Closed.
2025-02-19 10:36:38.376 |
2025-02-19 10:36:38.376 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:36:38.376 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:36:38.376 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:36:38.377 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:36:38.377 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:36:38.377 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:36:38.583 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:36:38.583 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:36:38.583 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:36:38.583 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:36:39.204 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:36:39.204 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:36:39.204 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:36:39.204 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:36:39.204 | Rithmic Direct - DTC | Failed connections: 31
2025-02-19 10:36:39.204 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:36:39.204 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:39.222 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:36:39.222 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:36:39.222 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:36:39.222 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:36:39.222 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:39.428 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:36:39.428 | DTC Client socket (1) | Closed.
2025-02-19 10:36:43.222 |
2025-02-19 10:36:43.223 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:36:43.223 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:36:43.223 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:36:43.223 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:36:43.223 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:36:43.223 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:36:43.432 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:36:43.432 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:36:43.432 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:36:43.432 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:36:44.081 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:36:44.081 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:36:44.081 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:36:44.081 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:36:44.081 | Rithmic Direct - DTC | Failed connections: 32
2025-02-19 10:36:44.081 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:36:44.081 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:44.095 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:36:44.095 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:36:44.095 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:36:44.095 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:36:44.095 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:44.302 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:36:44.302 | DTC Client socket (1) | Closed.
2025-02-19 10:36:48.094 |
2025-02-19 10:36:48.094 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:36:48.094 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:36:48.094 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:36:48.095 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:36:48.095 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:36:48.095 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:36:48.301 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:36:48.301 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:36:48.302 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:36:48.302 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:36:48.929 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:36:48.929 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:36:48.929 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:36:48.929 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:36:48.929 | Rithmic Direct - DTC | Failed connections: 33
2025-02-19 10:36:48.929 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:36:48.929 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:48.938 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:36:48.938 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:36:48.938 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:36:48.938 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:36:48.938 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:49.146 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:36:49.146 | DTC Client socket (1) | Closed.
2025-02-19 10:36:52.941 |
2025-02-19 10:36:52.941 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:36:52.941 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:36:52.941 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:36:52.941 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:36:52.941 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:36:52.941 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:36:53.146 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:36:53.146 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:36:53.146 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:36:53.146 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:36:53.761 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:36:53.761 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:36:53.761 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:36:53.761 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:36:53.761 | Rithmic Direct - DTC | Failed connections: 34
2025-02-19 10:36:53.761 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:36:53.761 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:53.773 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:36:53.773 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:36:53.773 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:36:53.773 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:36:53.773 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:53.976 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:36:53.976 | DTC Client socket (1) | Closed.
2025-02-19 10:36:57.766 |
2025-02-19 10:36:57.766 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:36:57.766 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:36:57.766 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:36:57.767 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:36:57.767 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:36:57.767 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:36:57.984 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:36:57.984 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:36:57.984 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:36:57.984 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:36:58.614 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:36:58.614 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:36:58.614 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:36:58.614 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:36:58.614 | Rithmic Direct - DTC | Failed connections: 35
2025-02-19 10:36:58.614 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:36:58.614 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:58.638 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:36:58.639 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:36:58.639 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:36:58.639 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:36:58.639 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:36:58.846 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:36:58.846 | DTC Client socket (1) | Closed.
2025-02-19 10:37:02.627 |
2025-02-19 10:37:02.627 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-19 10:37:02.627 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-19 10:37:02.627 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-19 10:37:02.628 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-19 10:37:02.628 | DTC Client socket (1) | New receive buffer size: 0
2025-02-19 10:37:02.628 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-19 10:37:02.858 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-19 10:37:02.858 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-19 10:37:02.858 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-19 10:37:02.858 | Rithmic Direct - DTC | Sending logon request message.
2025-02-19 10:37:03.484 | Rithmic Direct - DTC | Received logon response.
2025-02-19 10:37:03.484 | Rithmic Direct - DTC | Server Name: .
2025-02-19 10:37:03.484 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-19 10:37:03.484 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-19 10:37:03.484 | Rithmic Direct - DTC | Failed connections: 36
2025-02-19 10:37:03.484 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-19 10:37:03.484 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:37:03.503 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-19 10:37:03.503 | DTC Client socket (1) | CloseSocket call.
2025-02-19 10:37:03.503 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-19 10:37:03.503 | Rithmic Direct - DTC | Disconnected.
2025-02-19 10:37:03.503 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-19 10:37:03.710 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-19 10:37:03.710 | DTC Client socket (1) | Closed.
images1.PNG / V - Attached On 2025-02-19 15:37:55 UTC - Size: 167.52 KB - 167 views
[2025-02-19 17:47:26]
John - SC Support - Posts: 48003
Refer to the following:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
