Date/Time: Mon, 21 Apr 2025 18:10:42 +0000
Run sierra on two PCs
View Count: 133
[2025-02-19 06:26:59] |
MattH - Posts: 31 |
I want to run sierra on two separate PCs that will be on different IP addresses. I believe I need a second denali data connection. Confirm how do I do this.
[2025-02-19 07:25:12] |
Sierra_Chart Engineering - Posts: 19289 |
First refer to: Sierra Chart Purchase and License Information: Licensing / Number of Systems And regarding the Denali Data Feed, refer to: Denali Exchange Data Feed: Connections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
