Date/Time: Mon, 21 Apr 2025 18:01:41 +0000
Bar Time Duration Study help. How do I remove these lines?
View Count: 97
[2025-02-19 02:35:15]
User429142 - Posts: 49
SOLVED MYSELF:
I have the countdown timer study active which shows a countdown to when the bar closes for the chart I'm looking at but I often forget what intraday bar period I'm looking at on each chart.
I found this bar time duration study and I think it's what I'm looking for because it says 30 in this attached image which is a 30min chart im looking at. But I don't like all of these extra tall green lines taking up a quarter of my chart.
How can I remove these green lines so that I only see the duration? Or maybe suggest a different way to do this.
My goal is just to be able to quickly glance at the chart and realize if I'm looking at a 5m,15m,30m,1h bar chart ect..
EDIT: I figured this one out by following these steps
1. Bar Time Duration. Make sure it's hidden.
2. Text Display For Study. Set the Study and Subgraph to Display to the Bar Time Duration study. Set Subgraph Columns Back to 1. Set the Value Format dropdown to Time.
Now adjust the location / color / size of the text as needed using the settings for the Text Display study.
Date Time Of Last Edit: 2025-02-19 03:06:58
imageScreenshot_1.jpg / V - Attached On 2025-02-19 02:28:11 UTC - Size: 496.88 KB - 39 views
