Date/Time: Mon, 21 Apr 2025 18:04:49 +0000
increase tpo candle look back
View Count: 129
[2025-02-18 21:53:54] |
William Cline - Posts: 21 |
i have notice that the candles of NQ go back quite a but but the tpo candles only go back 21 candles regardless of the timeframe. i need a way to fix this because my trading requires the nearest value area above the current daily price action and this level is often more than 21 candles away
[2025-02-18 23:05:54] |
John - SC Support - Posts: 39380 |
We really do not understand what you are trying to state. What do you mean by "tpo candles only go back 21 candles"? What are these candles? What is the bar period? What are you trying to do?
[2025-02-19 07:40:45] |
bar period: daily pair:ESH25-CME current study: TPO Profile Chart i am trying to say that i have a much shorter lookback when using tpo candles compared to standard daily candles with no study applied. i get 27 days of data and cannot drag the profile back any further than that when using the tpo study. i have left 2 photos for comparison. https://www.sierrachart.com/image.php?Image=1739949932971.png https://www.sierrachart.com/image.php?Image=1739950058396.png |
[2025-02-19 07:49:05] |
Sierra_Chart Engineering - Posts: 19289 |
These two charts are of a different data type. One is based on Intraday data with the TPO profile. The other is Historical Daily data. Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
