Date/Time: Mon, 21 Apr 2025 18:04:48 +0000
I Can't see Recent bid/ask volume column in DOM
View Count: 103
[2025-02-18 14:18:38] |
User279562 - Posts: 1 |
Current traded volume works fine but recent bid/ask volume is not working, i can't see values when i choose to display these columns. I check and i am quite sure it is not a graphic setting issue . Thank you for support
[2025-02-18 16:16:33] |
Sierra_Chart Engineering - Posts: 19289 |
Go to the chart and in Trade >> Customize Chart/Trade DOM Columns. Set a Custom Title for those columns. Refer to: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) Once that is done: Provide an image of the chart or Trade DOM, by following these *exact* instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-02-18 16:16:55
