Date/Time: Mon, 21 Apr 2025 18:01:41 +0000
how to edit arrow text?
View Count: 134
[2025-02-18 09:48:58]
User59879 - Posts: 77
I cannot seem to figure out how to edit text to my arrows.
In the configuration box, I use the "Prompt For Text" option, a box pops up when I create an arrow, and I can enter text.
However, I can't figure out how to edit this text later and modify it.
Also, I am trying to figure out where to change the font/size for that arrow-text, is it in the Graphics Settings? And if so, which one under Fonts does it use?
[2025-02-18 16:23:24]
Sierra_Chart Engineering - Posts: 19289
Right-click over the Arrow chart drawing and select Modify Text and enter the text and press OK.
If you do not see that command, then add it:
Chart Drawing Tools: Customizing Chart Drawing Shortcut Menu
Date Time Of Last Edit: 2025-02-18 16:23:33
[2025-02-18 16:45:09]
oh! it's right there! ... I totally overlooked that, sorry & ty (blush)
but which font setting does Arrow text use?
I need to make the size of the text bigger, but I cannot figure out where to change the font size for Arrows
[2025-02-18 17:12:05]
John - SC Support - Posts: 39380
If the properties for a drawing does not have controls for the text size, then this is controlled through the Global Chart Drawing Font. Refer to the following:
Chart Drawing Tools: Global Chart Drawing Font (Global Settings >> Tool Settings >> General >> Drawing Font)
[2025-02-18 17:21:10]
found it ... ty!
