Date/Time: Mon, 21 Apr 2025 17:52:48 +0000
Cannot display Daily Chart from imported intraday data
View Count: 134
[2025-02-18 09:43:47]
ntintel - Posts: 20
Hi there,
I can import and display intraday charts from minute to hourly charts, but when I change Bar Period to Daily, the chart just goes blank as seen the attached file (Daily Chart.PNG). Is there a way to configure Sierra to draw up daily chart from imported intraday data?
I've also attached sample 1Min Data in DTOHLCV format for you to try it out.
Thanks.
Date Time Of Last Edit: 2025-02-19 00:32:13
imagedaily chart.png / V - Attached On 2025-02-18 09:42:55 UTC - Size: 5.31 KB - 27 views
Private File
[2025-02-18 16:29:14]
Sierra_Chart Engineering - Posts: 19289
Set this setting to Intraday Chart Only:
Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method menu)
Date Time Of Last Edit: 2025-02-18 16:29:44
[2025-02-19 00:32:52]
ntintel - Posts: 20
Ahhh thanks. It works with you solution now.
