Date/Time: Mon, 21 Apr 2025 18:07:48 +0000
Using sierra for charting
View Count: 97
[2025-02-17 23:51:26] |
User341821 - Posts: 1 |
Hi. what is best way to use Sierraa for charting only with live data? Any broker recommendations or can we subscibe for this service without using a broker
[2025-02-18 15:31:47] |
John - SC Support - Posts: 39380 |
What exactly are you asking in terms of "what is best way to use Sierraa for charting only with live data?" This question is too broad. The only reason you would need a broker is if you are wanting data for the CME Group. Refer to the following: Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Apart from the CME Group, you can get the real-time data from us for EUREX, CFE, U.S. Equities, and CBOE Indices without the need of a broker. You just need to be on one of the Integrated packages to be able to get the data. Refer to the following: Description of Service Packages and Pricing: Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
