Date/Time: Mon, 21 Apr 2025 18:16:44 +0000
Custom Symbol issue
View Count: 112
[2025-02-17 20:08:37]
User626318 - Posts: 15
I have created a custom Symbol but have to recreate every day as it does not save in the list.Also when this is created each day I get an error message in terms of getting historical data as there is no file for this.please see the attached files below and could you recommned a fix?
imageT5 ERROR.PNG / V - Attached On 2025-02-17 20:06:39 UTC - Size: 12.96 KB - 29 views
[2025-02-17 22:52:25]
Sierra_Chart Engineering - Posts: 19289
When you add this symbol to Global Settings >> Symbol Settings and press OK, check the Window >> Message Log for any error message writing to the file.
The error message in the screenshot indicates it is not configured correctly. To do it correctly, refer to the instructions here:
Custom Calculated Symbols: Instructions
Date Time Of Last Edit: 2025-02-17 22:52:48
