Date/Time: Mon, 21 Apr 2025 18:07:48 +0000
DOM Bars
View Count: 212
[2025-02-17 17:10:06]
User229477 - Posts: 41
These bars do not accurately represent correct size. Please see recent bid 23 vs recent ask 7. The 23 should be at least 3x width of 7
Date Time Of Last Edit: 2025-02-17 17:12:53
imageRecent bid ask.png / V - Attached On 2025-02-17 17:07:31 UTC - Size: 5.88 KB - 46 views
imageRecent bid ask.png / V - Attached On 2025-02-17 17:09:26 UTC - Size: 5.88 KB - 37 views
[2025-02-17 18:17:49]
Sébastien - Posts: 58
To fix that, go to :
Global Settings => Chart DOM Settings => Recent/Current Volume Bars Length Relative to Bid and Ask => YES
[2025-02-18 14:38:02]
Thank you Sébastien.
[2025-02-19 22:04:09]
The attached pic shows "recent bid" on left, "stacking/pulling" in the middle, "recent ask" on right. In the blue circle you see the red volume "stacking/pulling" bar at 40 larger than green volume "recent ask" bar at 47. How can we make this relative?
imageStacking vs recent.png / V - Attached On 2025-02-19 22:03:42 UTC - Size: 11.1 KB - 30 views
[2025-02-19 22:47:19]
John - SC Support - Posts: 39380
There is no option to have the Pulling/Stacking volume bars length relative to both the Bid and Ask Pulling/Stacking.
[2025-02-19 22:57:48]
Is there a workaround you can suggest?
[2025-02-19 23:00:43]
If we had one, we would have already suggested it.
We have noted this as a feature request, but we cannot say when we would get to any particular request.
