Date/Time: Mon, 21 Apr 2025 18:04:49 +0000
Tool Drawings settings for 'Above' or 'Below' chart bars or other studies?
View Count: 114
[2025-02-17 15:49:39]
User501309 - Posts: 15
I run two instances of SC and I notice on the sub instance my chart tool drawings (Like Horizontal Lines) graphically appear below the chart bars and other studies while in the main instance the drawings appear 'on top'. Is there a way to setup tool drawings to always appear 'below' ?
[2025-02-17 18:28:32]
John - SC Support - Posts: 39380
Refer to the following setting and the one below it:
Chart Settings: Draw Highlight Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu)
Note that this is a per Chart setting, so you would need to check it for each chart.
