Date/Time: Mon, 21 Apr 2025 18:16:45 +0000
new version
View Count: 104
[2025-02-17 15:05:34] |
User257481 - Posts: 38 |
i cant download a new version what i need to do ? thanks
![]() Attachment Deleted. |
[2025-02-17 18:26:39] |
John - SC Support - Posts: 39381 |
You would need to use the Zip installer since there is an issue with the path on the system. Refer to the following: Software Download: Sierra Chart Zip Installer For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
