Date/Time: Mon, 21 Apr 2025 04:41:22 +0000
2 minute candle starts on odd number
View Count: 113
[2025-02-17 14:21:49] |
User120393 - Posts: 1 |
I have a two minute chart that open on 1, 3, 5,7, 9 minutes. I would expect the candle to open on 0, 2, 4, 6... The issue is that this one chart is then out of sync with all the other charts. How can I correct this? |
[2025-02-17 18:20:52] |
John - SC Support - Posts: 39362 |
You need to look at the Session Times for that chart. The Start Time must be set to a 1 minute time (like 09:01:00). Refer to the following: Chart Session Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
