Date/Time: Mon, 21 Apr 2025 17:52:47 +0000
Chart Calculator Tool Vertical Alignment 'Edge' cut off in 2737
View Count: 124
[2025-02-17 12:17:53]
brianmonagha - Posts: 5
I utilize chart calculator tool with vertical alignment 'Edge'. Once I have updated to version 2737 part of the label text is off the screen. I have revered to version to 'Previous Version' 2726 and it works fine again. The settings of my tool are this:
Here is the image showing it working fine in version 2726
https://www.sierrachart.com/image.php?Image=1739794420255.png
Here is the image showing it in version 2741 where it is cut off
https://www.sierrachart.com/image.php?Image=1739794541607.png
Horizontal Alignment (List): Right
Vertical Alignment (List): Edge
Text Opaque: Y
Show Tick Difference: Y
Show Currency Value: N
Show Price Diff: Y
Show Percent Change: N
Show Time Difference: Y
Show Number Of Bars: Y
Show Angle: N
Show End Point Price: Y
Multiline Label: Y
Snow Volume: N
Show Ask Bid Diff Volume: N
Draw Text At End: Y
Line Style (List): Solid
Line Width: 2
imagetool-prop.png / V - Attached On 2025-02-17 12:16:29 UTC - Size: 43.47 KB - 38 views
[2025-02-18 06:45:10]
Sierra_Chart Engineering - Posts: 19289
We apologize for this. We are correcting it today.
