Date/Time: Mon, 21 Apr 2025 23:30:17 +0000
Changing Font size in DOM
View Count: 103
[2025-02-17 11:59:21]
User367161 - Posts: 19
Hi. I have following setup and problem:
https://www.sierrachart.com/image.php?Image=1739792439996.png
Starting from a footprint chart, I added a DOM. Trying to configure it, I can't find anywhere to change the font +++ size +++ in the DOM. I have spent some time in various documentations and clips to not find that out. So my question is:
- How can I change the font size in the DOM to match it to the main chart?
Best regards.
[2025-02-17 13:54:04]
Sébastien - Posts: 58
To change the font size of the Chart DOM, you need to go to :
Global settings => Graphics Settings - Global => Fonts => DOM Quantities/Sizes Global
